Appears I F*cked up the upload on my site.....
marc.hull
Ya know why red necks have their name on the back of their belts ? So they can remember their name when they pull their head of of their asses. I guess I need to get a belt with my name on it....
The MARVIN file I posted on my site was a preliminary version from a couple of months ago. Not what I intended to post. Sorry for the inconvenience. Hope you at least get a laugh on my dime.
The completed demo is now posted. MARVINDEMO is the correct file.
I am going to go and patch my self esteem back up and have a beer. Please download the correct files and forgive me my blunder.
Hull
Hi Marc, I can't control that ship at all! I press up on joystick to thrust and it moves up slightly then explodes (I'm using Classic99) what am I doing wrong?
Sounds like a Classic 99 issue. Try it on real hardware or maybe MESS.
Have'nt got any real hardware, does'nt start up in MESS at all, don't think it's specifically a Classic99 issue as the previous demo version worked ok.
Hmmmm.
I'm in Dallas for the weekend so I can't look at it till sunday but I am just really sure it runs on a TI.
the demo loaded and ran fine from a TI99 using the following loaders...
MENU program loader
DM2k program loader
FW opt 3 loader
EA Module opt 5 loader
and
TIW utility loader.
I even loaded and ran it on a Geneve although there is a joystick issue (I think because of direct CRU testing.)
Sorry, it appears to be an emulator problem.
MENU program loader
DM2k program loader
FW opt 3 loader
and
TIW utility loader.
I'm running it through EA 5 on Classic99 and the ship instantly explodes on game startup, so what is this joystick issue? Does it need solving at your end or the emulator as I've ran hundreds of games through my Gamebase project on Classic99 and not had the same problem.
MENU program loader
DM2k program loader
FW opt 3 loader
and
TIW utility loader.
Joystick issue only exists on the Geneve Computer, Unrelated to emulation.
The problem you are getting is related to Classic 99. I suspect it is either how the address >8802 is treated or the VDP interrupt state at start up. At any rate there isn't anything I can do about it. I work with real hardware only and have no experience (or very little anyhow) with emulators. Sorry...
MENU program loader
DM2k program loader
FW opt 3 loader
and
TIW utility loader.
Hmmn, I suspect this isn't the case as I previously stated that over 2000 games in my Gamebase project http://www.atariage.com/forums/topic/191033-gamebase-ti994a-v10-is-finished/ never complained of such a problem, Over to you Tursi?
Edited by OX.
Hmmn, I suspect this isn't the case as I previously stated that over 2000 games in my Gamebase project http://www.atariage....10-is-finished/ never complained of such a problem, Over to you Tursi?
(Beats head on wall.)
Hehe really ??
1) Runs on the real gear (important term there !)
2) Runs on Fred's Emu....
3) Doesn't run on Mike's Emu
Add that up again ;-).
As always, the real hardware is my benchline, if it runs there, then that's the right answer. ;)
I took a quick look at it. It smelled like timing, and ultimately, yes, it is.
Marc is using a very clever technique that does background character collision detection by creating an additional sprite whose pattern matches the background, and letting the hardware handle comparing the actual pixels (it's fun to watch the VDP table change for that). Thus, if any two sprites collide, you die. This actually works fine.
The ship is made of more than one sprite (colors), and can't by definition move all at the same time - one sprite has to move before the other. That's just how the VDP memory access works. Since everything is synchronized to the vertical blank, there is a known amount of time during which it's safe to move the sprites.
However, in Classic99 the screen draw and the vertical blank were not quite right. So what happens here is that you live only until Classic99 does a screen draw with only one of the sprites moved, and overlapping the other by a single pixel. The sprite collision flag gets set, and you die without visible cause.
There was no good reason for this, save inexperience - I was using the interrupt bit to trigger the screen draw, instead of the other way around, and putting off any fixes for some future date when I did a scanline-based VDP. But this turned out to be pretty easy to fix (as noted above - draw the screen, then set the interrupt flag, not the other way around). So I'll put out a new build with this fix and the TurboForth blocks file fix. The reason most titles had no problem with this is that it's actually unusual for an assembly game to use the sprite collision bit, most do it themselves.
Hehe really ??
My apologies good sir, anyway if it was'nt for you "bug" :grin: Tursi would have been none the wiser with his joystick control code.
The game is fantastic by the way, really addictive.
Thanks Marc, Thanks Tursi.
Edited by OX.
I guess it's time to try CL99.
A question Mike...
When CL99 loads an EA5 executable does it turn the VDP interrupt off ? I ask because I know you don't yet use the FDC DSR and am unsure where the zero mask is made.
Hehe really ??
No apologies necessary OX.....
The joystick error only exists on the Geneve (which is an entirely different computer and not emulation) and unrelated to the past CL99 problem.
I actually found it kind of funny that you were using the tail to wag the dog on this one. No harm done and lord knows I have done a bit of the wagging myself ;-).
Hull.
I tried the game w/Classic99 but cannot get past the title screen. I played around with the joystick/keyboard setting options without any success. Suggestions, anyone? :)
I'm gonna say that this may be a bit above your head captain Geneve......... Stick with your simple DSR's and OpSys's. Hate to see you get hurt hehe..
Har har.
Willsy & Sometimes were right on target -- I was using the wrong keypresses ("Q" versus "TAB") in C99. So much for feigning my thorough read of Tursi's documentation ;)
hehe. Marc's reading the joystick directly, the 'Q' being the same code as Joystick 1 Fire is actually a KSCAN artifact.
The Classic99 DSR doesn't touch the system state, so it depends on the loader you use. Editor/Assembler starts an E/A #5 program with the 9900 interrupt mask at 0 (no interrupts). Since most programs assume that I'm not aware of any loaders that have interrupts enabled at startup.
Oh yea? Well, I hacked your joystick code now Mad Marvin has a new home on my Geneve. Put that in your pipe and smoke it. Or did you quit smoking after the last 9901 burnout? hehehe
