xxl Posted January 3, 2012 Share Posted January 3, 2012 Hi, is there a way (loader) to load binary file like this: org $2000 sei lda #0 sta nmien sta dmactl lda #$fe sta portb ;ROM OFF; BASIC OFF rts ini $2000 org $0000 ; PAGE 00 :255 .byte $ff org $c000 ; UNDER ROM :255 .byte $ff org $FFFF ; .byte $ff Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted January 3, 2012 Share Posted January 3, 2012 depends on your EXE loader? it could work if you copy OS ROM to RAM and then switch off? otherwise you would need to write your own... so when loading 128/256 bytes then you move them manually under ROM. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 3, 2012 Share Posted January 3, 2012 Not really. It'll probably work in emulation, unsure about Altirra but Atari800Win+ injects binaries into RAM even if the overlaying ROM is switched in. Best method is to use .SET 6 or whatever relocation directive for the Assembler in use. Then have the "under OS" code loaded early in the process and moved into place. Page zero stuff should work, but there can be the risk that the loader itself might be using the same locations. Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 4, 2012 Share Posted January 4, 2012 This will not work on Altirra 2.0. The program loader writes several zero page locations to mimic the activity of a boot loader, so locations $09 (BOOT_) and $30 (STATUS) will be trashed after the zero page segment loads. It also reads POKMSK ($10) and so the result will be all timer IRQs being turned on when the next segment loads. AUDC1-4, IRQEN, and AUDCTL are also hit for each segment. PBCTL is written as well although the I/O and DDR registers are not currently changed. Current 2.10 test versions also require the known RTS ROM location ($E4C0). Altirra also does not allow you to load directly into RAM since the program loader uses the same mapping tables as the CPU -- the writes will get intercepted by the ROM, by hardware devices, or just go nowhere if RAM is not mapped at the target load location. In short, don't do it. Relocate after all segments have loaded as Rybags suggests. There's no point in writing a program only for an emulator -- if we were doing that, the first thing I'd add is a 68000 CPU. Quote Link to comment Share on other sites More sharing options...
xxl Posted January 21, 2012 Author Share Posted January 21, 2012 > the first thing I'd add is a 68000 CPU maybe you should as part of vbxe core :-) Quote Link to comment Share on other sites More sharing options...
funkheld Posted January 27, 2012 Share Posted January 27, 2012 Site for the graphics 23 is the 3840byte an for the graphics 7 is the 3200byte For the XFORTH is the, GRAPHIC 7/23 is the screen from the start DpLIST 36960. Start with the XFORTH is : READFILE" D:TEST.IMG 36960 CONSTANT SCREEN0 3840 VARIABLE BYTEGRAPHIC : READFILE" FILE" R/O OPEN-FILE 128 < IF SOURCE-ID ! SCREEN0 BYTEGRAPHIC @ SOURCE-ID @ READ-FILE SOURCE-ID @ CLOSE-FILE 0 SOURCE-ID ! ELSE ." Error open file" THEN ; Quote Link to comment Share on other sites More sharing options...
