moulinaie Posted January 9, 2012 Share Posted January 9, 2012 (edited) Hello, I have added the file access instructions: FOPEN, FCLOSE, FREAD, FWRITE, FDELETE, FSCRATCH, FSAVE, FLOAD, FRESTORE, FSTATUS. To show this, I have made a program that replays a very little movie direct from disk: http://youtu.be/JiV_egW8C8I Note that the first screen with scrolling title is in extended Basic and you'll notice the speed display when it goes to the Assembly routine for the animation. Note 2: the FastLoader has been upgraded, you can see that at the very beginning, only few seconds are required to load and compile. Here is the source code: 100 CALL CLEAR::DIM A$(60) $MLC X 110 10 3000 300 GOSUB 1500::CALL CHAR(48,"7EFFFFFFFFFFFF7E") 330 CALL CLEAR::CALL LINK("TINTIN",Z) 335 CALL CLEAR::PRINT "THE END..."::END ; ; here define theborder for the film effect ; 1500 CALL CHAR(96,"C0C0C0FFFFFFFFFF060606FEFEFEFEFEC0C0C0C0C0C0C0C00606060606060606") ; ; borders white on black ; and text yellow on black ; 1510 RESTORE 2000::CALL CLEAR::CALL SCREEN(2)::CALL COLOR(9,16,2) 1515 FOR I=1 TO 8::CALL COLOR(I,12,2)::NEXT I ; ; display text with borders and centers ; 1520 READ R$::I=LEN(R$)::J=INT(I/2)::IF I=0 THEN RETURN 1530 PRINT "`a"&RPT$(" ",12-J)&R$&RPT$(" ",12+J-I)&"`a"; 1540 READ R$::I=LEN(R$)::J=INT(I/2)::IF I=0 THEN RETURN 1550 PRINT "bc"&RPT$(" ",12-J)&R$&RPT$(" ",12+J-I)&"bc";::GOTO 1520 2000 DATA " "," ","WELCOME TO A NEW WORLD" 2010 DATA " "," "," "," " 2020 DATA "NO 3D EFFECT"," "," "," " 2030 DATA "NO SOUND"," "," "," " 2040 DATA "NO COLOR"," "," "," " 2050 DATA "NO STORY"," "," "," " 2060 DATA "NO SPEILBERG"," "," "," " 2070 DATA " " 2080 DATA "ONLY..." 2090 DATA " "," "," "," "," "," "," "," "," "," "," "," ","" ; ; here MLC routine TINTIN ; $TINTIN HIGHMEM 0 SCREEN 1 ; black background FOR I 12 15 COLOR I 16 1 ; white on black for the "movie" NEXT FOR I 4 11 COLOR I 3 1 ; green for text NEXT COLOR 6 4 1 ; light green for great title STARTDATA STRING " PURE... " STRING " " STRING " 0 0 0 00 0 0 0 00 " STRING "000 00 0 000 00 0 " STRING " 0 0 0 0 0 0 0 0 " STRING " 0 0 0 0 0 0 0 0 " STRING " 0 0 0 0 0 0 0 0 0 0 " STRING " 00 00 000 000 00 00 000 000" STRING " " STRING " `flrx " STRING " agmsy " STRING " bhntz " STRING " ciou{ " STRING " djpv| " STRING " ekqw} " STRING " " STRING " DIRECT STREAM FROM DISK! " STRING " (MY LITTLE COMPILER) " ENDDATA M ; ; this assembly routine turns every ASCII char to ; its screen equivalent: ASCII+96 ; $[ mov @M,r0 ; points to text bloc li r1,>6060 ; offset for XB characters on screen li r2,288 ; 18 lines with 16 words ; here a r1,*r0+ ; add offset to chars dec r2 ; counter jne -3 ; jump "here" if not finished $] BMOVECTOV M 576 96 ; copy text to third screen line STARTDATA ; prepares the PAB for file access BYTE 0 ; no Opcode for now FLAGS sequential, internal, fixed, input WORD 1536 ; address for definition of char 96 and followings BYTE 240 ; max length BYTE 240 ; length WORD 0 ; no rec number for sequential BYTE 0 ; offset unused BYTE 10 ; name is 10 bytes long STRING "DSK1.VIDEO" ENDDATA A LET B &h831A GETTABLE B(0) P ; peek(831A) = VDP address of free space SUB P 22 ; place for PAB so P = PAB ADDRESS BMOVECTOV A 22 P ; copy PAB to VDP Ram FOPEN P ; open the file IF= ; if OK, go on! REPEAT FRESTORE P ; to beginning of file NDO N 5 ; five images PUTTABLE P(5) 240 ; size to read. FREAD P ; read 240 bytes into char defs NDO X 3000 ; little wait loop NLOOP NLOOP KEY 0 ; a key pressed? UNTIL>= ; if no, go on ENDIF PUTPARAM 1 Z ; return Z, the file error code (if any) $$ $END Guillaume. Edited January 9, 2012 by moulinaie 1 Quote Link to comment Share on other sites More sharing options...
unhuman Posted January 10, 2012 Share Posted January 10, 2012 Wow. The sound is amazing! Quote Link to comment Share on other sites More sharing options...
+RXB Posted January 10, 2012 Share Posted January 10, 2012 Very cool work. Nicely done. Quote Link to comment Share on other sites More sharing options...
moulinaie Posted January 10, 2012 Author Share Posted January 10, 2012 Wow. The sound is amazing! Unfortunately, it's not the TI that plays the sound! It is the music from a serie of cartoons with all the original adventures of Tintin. Guillaume. Quote Link to comment Share on other sites More sharing options...
moulinaie Posted January 10, 2012 Author Share Posted January 10, 2012 Very cool work. Nicely done. Thanks!!! As the replay is from disk, the number of images is not limited by the amount of RAM. And the CF7 is so fast that I had to include a loop delay between every frame. The limitation comes from the file size (is there a limit for a file?). Every frame uses a rectangle of 5*6 characters, this is 30*8=240 bytes. Guillaume. Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted January 10, 2012 Share Posted January 10, 2012 Ah! Great Funny Effect ! :-) Quote Link to comment Share on other sites More sharing options...
eck Posted January 10, 2012 Share Posted January 10, 2012 127 files on TI-formatted disks is the maximum, I think. Your work looks very promising. Quote Link to comment Share on other sites More sharing options...
moulinaie Posted January 10, 2012 Author Share Posted January 10, 2012 127 files on TI-formatted disks is the maximum, I think. Your work looks very promising. Thanks! 127 files looks enough for such a system... I was thinking about the limit for the size of ONE file? According to the E/A manual, a record number can be from 0 to 32767, and a record can be 255 bytes long (a quarter of KB) so it's close to 8192KB, in other words, 8MB ?? Guillaume. Quote Link to comment Share on other sites More sharing options...
moulinaie Posted January 10, 2012 Author Share Posted January 10, 2012 Hi, Everything is on my pages with the new files and the TINTIN example http://gtello.pagesperso-orange.fr/mlc_e.htm (english) http://gtello.pagesperso-orange.fr/mlc_f.htm (français) Guillaume. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted January 10, 2012 Share Posted January 10, 2012 I was thinking about the limit for the size of ONE file? According to the E/A manual, a record number can be from 0 to 32767, and a record can be 255 bytes long (a quarter of KB) so it's close to 8192KB, in other words, 8MB ?? Guillaume. The actual file size for a single file with fixed-length records occupying all the available space on a TI-99/4A disk depends on the smaller of two numbers, viz., 32768 X 256 = 8MB (as you concluded) and the size of the disk less disk overhead (usually much smaller). If you actually had enough space for an 8MB file with 32767 records of 255 bytes each + 1 sector for its FDR, you will have 8,388,608 bytes allocated but will waste one byte per sector of the 32767 records or 32767 bytes (32K - 1 bytes); and, of course, you cannot use the FDR for your data. So, the actual amount of space for data is 8,388,608 - 32767 - 256 = 8,355,585 bytes. Fixed-length records are stored as an integral number of records per sector. That's the reason for the wasted byte in each sector noted above. However, if you use 128-byte records, you can use every byte of available space with 2 records/sector on a 4MB disk or smaller. On a DSDD disk (360KB total disk space) with one file occupying all available space, all but 3 sectors (768 bytes) for the VIB, the FDIR and the FDR for the lone file, can be filled with data. That is a file with only 2874 records of 128 bytes each. ...lee Quote Link to comment Share on other sites More sharing options...
marc.hull Posted January 13, 2012 Share Posted January 13, 2012 You really seem to have a good grasp of what is going on and I appreciate you passion as far as providing avenues for people goes but.....You are rather talented and I would like to see your efforts on games for the TI.... TinTin didn't appear in the fog on your mirror ya know..... I'd like to see you stretch your coding a bit more...... Might be kinda kewl.... Quote Link to comment Share on other sites More sharing options...
