funkheld Posted January 10, 2012 Share Posted January 10, 2012 (edited) Altirra or orig. ATARI800XL . VOLKSFORTH with DPL ( GRAFIK 160x80 with 4 text line by ) and PM collision. ATR start : FTH.COM then: INCLUDE" D:XJOYTEX1.f then: INIT then: 100 BEWEGE (RETURN) 100 pixels with the joystick or 10x collision then ended. or 160 BEWEGE (Return)...or....10x collision then ended. HEX 9FFF SP! 9FFF S0 ! 022F CONSTANT SDMCTL 026F CONSTANT GPRIOR D000 CONSTANT HPOS0 D01D CONSTANT GRACTL D407 CONSTANT PMBASE 230 CONSTANT SDLSTL D40B CONSTANT VCOUNT A000 CONSTANT SCREEN0 BF60 CONSTANT SCREEN1 02C0 CONSTANT PCOLR0 02C4 CONSTANT COLOR0 02C5 CONSTANT COLOR1 02C6 CONSTANT COLOR2 02C8 CONSTANT COLOR4 0278 CONSTANT STICK0 D004 CONSTANT P0PF D01E CONSTANT HITCLR VARIABLE XPOS VARIABLE YPOS VARIABLE TESTXY VARIABLE MILLI VARIABLE ODLIST VARIABLE COLOR0O VARIABLE COLOR1O VARIABLE COLOR2O VARIABLE COLOR4O VARIABLE ZC VARIABLE ZZ VARIABLE ZA VARIABLE ZA1 VARIABLE DLIST -2 ALLOT 70 C, 70 C, 70 C, 4D C, SCREEN0 , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D C, 42 C, SCREEN1 , 0202 , 02 C, 41 C, DLIST , VARIABLE SPRITE0 9 ALLOT FF SPRITE0 C! 81 SPRITE0 1 + C! 81 SPRITE0 2 + C! 81 SPRITE0 3 + C! 81 SPRITE0 4 + C! 81 SPRITE0 5 + C! 81 SPRITE0 6 + C! 81 SPRITE0 7 + C! FF SPRITE0 8 + C! : GCLS SCREEN0 C80 0 FILL ; : READ-DAT SCREEN0 C80 SOURCE-ID @ READ-FILE SOURCE-ID @ CLOSE-FILE ; : INCLUDED-DAT SOURCE-ID @ >R R/O OPEN-FILE DUP $80 < IF DROP SOURCE-ID ! READ-DAT ELSE ." FEHLER:" . ABORT THEN R> SOURCE-ID ! ; : FILE-DAT" FNBUF $50 BL FILL HERE $50 BL FILL ASCII " WORD COUNT FNBUF SWAP CMOVE FNBUF 0 INCLUDED-DAT ; : FILE-DAT FNBUF $50 BL FILL " D:MULBI.BIN" COUNT FNBUF SWAP CMOVE FNBUF 0 INCLUDED-DAT ; : INITPM SDMCTL C@ 1C OR SDMCTL C! 3 GRACTL C! 1 GPRIOR C! B0 PMBASE C! ; : DELAY ZZ @ 0 DO LOOP ; : PM0POS B400 FF 0 FILL SPRITE0 B400 YPOS C@ + 9 MOVE SPRITE0 B400 YPOS C@ + C + 9 MOVE XPOS C@ HPOS0 C! DELAY ; : BEWEGE PAGE ZA1 ! BEGIN FF ZZ ! STICK0 C@ DUP 0E = IF YPOS C@ 1 - YPOS C! 1 TESTXY C! 1 ZA @ + DUP ZA ! . CR PM0POS THEN DUP 0D = IF YPOS C@ 1 + YPOS C! 2 TESTXY C! 1 ZA @ + DUP ZA ! . CR PM0POS THEN DUP 07 = IF XPOS C@ 1 + XPOS C! 3 TESTXY C! 1 ZA @ + DUP ZA ! . CR PM0POS THEN 0B = IF XPOS C@ 1 - XPOS C! 4 TESTXY C! 1 ZA @ + DUP ZA ! . CR PM0POS THEN P0PF C@ 0 > IF 500 ZZ ! TESTXY C@ 1 = IF YPOS C@ 4 + YPOS C! 1 ZC @ + ZC ! PM0POS THEN TESTXY C@ 2 = IF YPOS C@ 4 - YPOS C! 1 ZC @ + ZC ! PM0POS THEN TESTXY C@ 3 = IF XPOS C@ 4 - XPOS C! 1 ZC @ + ZC ! PM0POS THEN TESTXY C@ 4 = IF XPOS C@ 4 + XPOS C! 1 ZC @ + ZC ! PM0POS THEN THEN ZC @ A = IF ZA1 @ ZA ! THEN 1 HITCLR C! 0 TESTXY C! ZA @ ZA1 @ = UNTIL 0 ZC ! 0 ZA ! 0 ZA1 ! PAGE ." wegpunkte/colli erreicht ! " CR ; : INIT INITPM 4 2BF C! 70 PCOLR0 C! 94 COLOR2 C! 0C COLOR4 C! DLIST SDLSTL ! FILE-DAT 32 DUP XPOS C! YPOS C! PM0POS 0 ZC ! 0 ZA ! 0 ZA1 ! FILE-DAT DECIMAl ; VOLKSFORTH: http://sourceforge.n...lksforth/files/ forth.atr Edited January 10, 2012 by funkheld Quote Link to comment Share on other sites More sharing options...
funkheld Posted January 10, 2012 Author Share Posted January 10, 2012 VOLKSFORTH with DPL ( GRAFIK 160x80 with 4 text line by line ) and PM collision. ATR start : FTH.COM then: INCLUDE "D: XJOYTEX1.f then: 100 BEWEGE (RETURN) 100 pixels with the joystick or 10x collision then ended. or 160 BEWEGE (Return)... makeATR.exe for the ATR-File. GRUSS Quote Link to comment Share on other sites More sharing options...
candle Posted January 10, 2012 Share Posted January 10, 2012 it should be INCLUDE" D:FJOYTEX1.F" Quote Link to comment Share on other sites More sharing options...
funkheld Posted January 11, 2012 Author Share Posted January 11, 2012 (edited) it should be INCLUDE" D:FJOYTEX1.F" > no..no this it is : INCLUDE"_D:FJOYTEX1.F this is blank: _ gruss Edited January 11, 2012 by funkheld Quote Link to comment Share on other sites More sharing options...
funkheld Posted January 11, 2012 Author Share Posted January 11, 2012 this it is : INCLUDE"_D:FJOYTEX1.F or this it is : INCLUDE"_D:FJOYTEX1.F" gruss Quote Link to comment Share on other sites More sharing options...
candle Posted January 11, 2012 Share Posted January 11, 2012 either way not D:XJOYTEX1.F i was able to run it using your instruction, and i understad its about collision detection, but that when my understanding ends Quote Link to comment Share on other sites More sharing options...
funkheld Posted January 11, 2012 Author Share Posted January 11, 2012 (edited) no spaces in between : D:FJOYTEX1.F it is ok. then : INIT forth.atr Edited January 11, 2012 by funkheld Quote Link to comment Share on other sites More sharing options...
funkheld Posted January 12, 2012 Author Share Posted January 12, 2012 The VOLKSFORTH is in a better memory management as the XFORTH. When VOLKSFORTH can customize the storage area of the graph (DPL). When XFORTH you can not. gruss Quote Link to comment Share on other sites More sharing options...
