funkheld Posted January 11, 2012 Share Posted January 11, 2012 here is the xforth at X : http://atariwiki.strotmann.de/wiki/Wiki.jsp?page=Index and her: http://atariwiki.strotmann.de/wiki/Wiki.jsp?page=X-FORTH xforth_11c.asm and the xforth1.atr!!! asm you can compile with atasm.exe here is my xforth.atr with compilat fth.65o from atasm.exe (xforth_11c.asm) start: FTH.65o then: INCLUDE"_D:XJOYTEX.F ("_" is the blank) then: INIT then text : 100 BEWEGE an with joystick going 100 or 10x Collision then end. the programm for xforth: HEX 022F CONSTANT SDMCTL 026F CONSTANT GPRIOR D000 CONSTANT HPOS0 D01D CONSTANT GRACTL D407 CONSTANT PMBASE 230 CONSTANT SDLSTL D40B CONSTANT VCOUNT 9000 CONSTANT SCREEN0 BF60 CONSTANT SCREEN1 02C0 CONSTANT PCOLR0 02C4 CONSTANT COLOR0 02C5 CONSTANT COLOR1 02C6 CONSTANT COLOR2 02C8 CONSTANT COLOR4 0278 CONSTANT STICK0 D004 CONSTANT P0PF D01E CONSTANT HITCLR 00 VARIABLE XPOS 00 VARIABLE YPOS 00 VARIABLE TESTXY 00 VARIABLE MILLI 00 VARIABLE ODLIST 00 VARIABLE COLOR0O 00 VARIABLE COLOR1O 00 VARIABLE COLOR2O 00 VARIABLE COLOR4O 00 VARIABLE ZC 00 VARIABLE ZZ 00 VARIABLE ZA 00 VARIABLE ZA1 00 VARIABLE DLIST -2 ALLOT 70 C, 70 C, 70 C, 4D C, SCREEN0 , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D0D , 0D C, 42 C, SCREEN1 , 0202 , 02 , 41 C, DLIST , 00 VARIABLE SPRITE0 9 ALLOT FF SPRITE0 C! 81 SPRITE0 1 + C! 81 SPRITE0 2 + C! 81 SPRITE0 3 + C! 81 SPRITE0 4 + C! 81 SPRITE0 5 + C! 81 SPRITE0 6 + C! 81 SPRITE0 7 + C! FF SPRITE0 8 + C! : GCLS SCREEN0 C80 0 FILL ; : INITPM SDMCTL C@ 1C OR SDMCTL C! 3 GRACTL C! 1 GPRIOR C! 88 PMBASE C! ; : DELAY ZZ @ 0 DO LOOP ; : PM0POS 8C00 FF 0 FILL SPRITE0 8C00 YPOS C@ + 9 CMOVE XPOS C@ HPOS0 C! DELAY ; : ["] ( -- addr len ) R COUNT DUP 1+ R> + >R ; : " ( -- addr len ) 22 STATE @ IF COMPILE ["] WORD C@ 1+ ALLOT ELSE WORD DUP C@ 1+ PAD SWAP CMOVE PAD COUNT THEN ; IMMEDIATE : CLS 7D EMIT ; : READFILE" FILE" R/O OPEN-FILE 128 < IF SOURCE-ID ! SCREEN0 C80 SOURCE-ID @ READ-FILE SOURCE-ID @ CLOSE-FILE 0 SOURCE-ID ! ELSE ." Error open file" THEN ; : READFILE " D:MULBI.BIN" R/O OPEN-FILE 128 < IF SOURCE-ID ! SCREEN0 C80 SOURCE-ID @ READ-FILE SOURCE-ID @ CLOSE-FILE 0 SOURCE-ID ! ELSE ." Error open file" THEN ; : LOADPIC " D:MULBI.BIN" R/O OPEN-FILE DUP IF ." Pic Open Error " . CR ELSE DROP DUP SCREEN0 C80 ROT READ-FILE DUP IF ." Pic Load Error " . . CR ELSE DROP DROP CLOSE-FILE DROP THEN THEN ; : BEWEGE ZA1 ! BEGIN FF ZZ ! STICK0 C@ DUP 0E = IF YPOS C@ 1 - YPOS C! 1 TESTXY C! 1 ZA @ + DUP ZA ! . CR PM0POS THEN DUP 0D = IF YPOS C@ 1 + YPOS C! 2 TESTXY C! 1 ZA @ + DUP ZA ! . CR PM0POS THEN DUP 07 = IF XPOS C@ 1 + XPOS C! 3 TESTXY C! 1 ZA @ + DUP ZA ! . CR PM0POS THEN 0B = IF XPOS C@ 1 - XPOS C! 4 TESTXY C! 1 ZA @ + DUP ZA ! . CR PM0POS THEN P0PF C@ 0 > IF 500 ZZ ! TESTXY C@ 1 = IF YPOS C@ 4 + YPOS C! 1 ZC @ + ZC ! PM0POS THEN TESTXY C@ 2 = IF YPOS C@ 4 - YPOS C! 1 ZC @ + ZC ! PM0POS THEN TESTXY C@ 3 = IF XPOS C@ 4 - XPOS C! 1 ZC @ + ZC ! PM0POS THEN TESTXY C@ 4 = IF XPOS C@ 4 + XPOS C! 1 ZC @ + ZC ! PM0POS THEN THEN ZC @ A = IF ZA1 @ ZA ! THEN 1 HITCLR C! 0 TESTXY C! ZA @ ZA1 @ = UNTIL 0 ZC ! 0 ZA ! 0 ZA1 ! ." wegpunkte/colli erreicht ! " CR ; : INIT INITPM 70 PCOLR0 C! 0C COLOR4 C! 94 COLOR2 C! DLIST SDLSTL ! 4 2BF C! READFILE 32 DUP XPOS C! YPOS C! PM0POS 0 ZC ! 0 ZA ! 0 ZA1 ! ; gruss xforth.atr Quote Link to comment Share on other sites More sharing options...
Sub(Function(:)) Posted January 11, 2012 Share Posted January 11, 2012 so X forth seems faster than volks forth. do you know which forth works best with SpartaDOS X? I see that volks forth seems to have problems when you go back to DOS Quote Link to comment Share on other sites More sharing options...
funkheld Posted January 11, 2012 Author Share Posted January 11, 2012 (edited) I will not take the spartados. I always take one dos, which is as small as possible. when 8bitter is only one obstacle and no dos working tool. I see that volks forth seems to have problems when you go back to DOS VOLKSFORTH : back to dos with : BYE its ok. XFORTH : back to dos with : MON its ok. Edited January 11, 2012 by funkheld Quote Link to comment Share on other sites More sharing options...
