+Vorticon Posted March 14 Share Posted March 14 1 minute ago, TheBF said: Very neat! I have been distracted lately by another hobby but I really want to make one of these too. So you are sending at 1200 bps with TerraTerm character delay set to zero? Sending works at 2400bps. Receive struggles above 1200bps. I did not know there was a character delay option with Teraterm. I'll check it out. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 14 Share Posted March 14 Unfortunately it has a minimum 1mS delay so it really slows things down. However it let's you use higher baud rates. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 14 Share Posted March 14 1 hour ago, TheBF said: Unfortunately it has a minimum 1mS delay so it really slows things down. However it let's you use higher baud rates. I tried it with a 1 msec delay and now it can receive at 2400bps. Thanks for the tip! I simplified the xmodem code a bit. Here's the updated listing and attached disk image. Spoiler {$i-} (* xmodem file transfer utility *) (* xmodem checksum only. xmodem crc not supported *) (* by walid maalouli *) (* march 2024 *) program xmodem; label 1; type byte = 0..255; byteword = record case boolean of true : (value : integer); false : (bytes : packed array[0..1] of byte); end; longint = record case boolean of true : (value : integer[4]); false : (intval : packed array[0..1] of integer); end; var key, d : integer; send, timeout : boolean; fname : string; tfile : file; function getkey : integer; external; procedure setrs232(base : integer); external; procedure getbyte(var n, flag : integer); external; procedure sendbyte(n : integer); external; procedure sendfile; label 1; var i, j, flag, blocksin, buffloc, packet, tdata, comcode : integer; stime, itime : longint; block : array[0..131] of integer; buffer : array[0..255] of byteword; begin (* sendfile *) packet := 1; buffloc := 0; while (not(eof(tfile))) or ((eof(tfile)) and (buffloc < 255) and (buffer[buffloc].bytes[0] <> 26)) do begin if buffloc = 0 then begin fillchar(buffer, 512, chr(26)); {fill buffer with padding character} blocksin := blockread(tfile, buffer, 1); buffloc := 0; end; (* set up transmission packet *) tdata := 0; block[0] := 1; {soh} block[1] := packet; {transmitted packet number} block[2] := 255 - packet; j := 3; while j < 131 do begin block[j] := buffer[buffloc].bytes[0]; tdata := tdata + block[j]; block[j + 1] := buffer[buffloc].bytes[1]; tdata := tdata + block[j + 1]; j := j + 2; buffloc := succ(buffloc); if buffloc > 255 then if not(eof(tfile)) then buffloc := 0 else buffloc := 255; end; block[j] := tdata mod 256; {checksum} (* send transmission packet *) 1: for i := 0 to 131 do sendbyte(block[i]); time(stime.intval[0], stime.intval[1]); {start time} repeat getbyte(comcode, flag); {wait for remote ack or nak code} time(itime.intval[0], itime.intval[1]); {interval time} if (itime.value - stime.value) > 35 then {20 second timeout} begin timeout := true; exit(sendfile); end; until comcode in[6, 21]; if comcode = 21 then {resend block if nak received} goto 1; gotoxy(15, 23); write(packet); packet := succ(packet); end; sendbyte(4); {send eot code} time(stime.intval[0], stime.intval[1]); {start time} repeat getbyte(comcode, flag); {wait for ack code} time(itime.intval[0], itime.intval[1]); {interval time} if (itime.value - stime.value) > 35 then {20 second timeout} begin timeout := true; exit(sendfile); end; until comcode = 6; end; (* sendfile *) procedure recvfile; label 1; var i, flag, packet, tdata, buffloc, blocksin, errcount, comcode, data : integer; recerr, eotcode : boolean; block : array[0..127] of integer; buffer : array[0..255] of byteword; begin (* recvfile *) (* receive packet *) recerr := false; eotcode := false; buffloc := 0; errcount := 0; 1: sendbyte(21); {send nak code} getbyte(comcode, flag); {receive soh code} if comcode <> 1 then recerr := true; repeat if buffloc = 0 then fillchar(buffer, 512, chr(26)); {fill buffer with padding character} tdata := 0; getbyte(data, flag); {receive packet number} packet := data; getbyte(data, flag); {receive inverse packet number} if (255 - packet) <> data then recerr := true; for i := 0 to 127 do begin getbyte(data, flag); {receive data segment} block[i] := data; tdata := tdata + block[i]; end; getbyte(data, flag); {receive checksum} if (tdata mod 256) <> data then recerr := true; if recerr then begin errcount := succ(errcount); if errcount > 10 then begin timeout := true; exit(recvfile); end else begin recerr := false; goto 1; end; end; (* process packet *) i := 0; while i < 128 do begin buffer[buffloc].bytes[0] := block[i]; buffer[buffloc].bytes[1] := block[i + 1]; i := i + 2; buffloc := succ(buffloc); end; if buffloc > 255 then begin buffloc := 0; blocksin := blockwrite(tfile, buffer, 1); end; gotoxy(18, 23); write(packet); errcount := 0; sendbyte(6); {send ack code} getbyte(comcode, flag); {receive soh or eot code} if comcode = 4 then eotcode := true else if comcode <> 1 then begin timeout := true; exit(recvfile); end; until eotcode; sendbyte(6); {send ack code} end; (* recvfile *) begin (* xmodem *) 1: page(output); writeln('(R)eceive file'); writeln('(S)end file'); writeln('(Q)uit program', chr(7)); repeat key := getkey; until key in[81, 82, 83]; case key of 81 : exit(program); 82 : begin writeln('receive mode'); send := false; end; 83 : begin writeln('send mode'); send := true; end; end; repeat gotoxy(0, 5); writeln('enter filename:', chr(7)); readln(fname); if send then reset(tfile, fname) else rewrite(tfile, fname); until ioresult = 0; writeln(chr(10), chr(7), '1: rs232/1 2: rs232/2'); repeat key := getkey; until key in[49, 50]; if key = 49 then begin setrs232(1); writeln('using rs232/1'); end else begin setrs232(2); writeln('using rs232/2'); end; writeln(chr(10), chr(7), 'press any key to start transfer...'); repeat until getkey <> 255; timeout := false; if send then begin gotoxy(0, 23); write('packets sent: '); sendfile; end else begin gotoxy(0, 23); write('packets received: '); recvfile; end; if timeout then begin gotoxy(0, 21); writeln(chr(7), 'transfer error!'); for d := 1 to 2000 do begin end; timeout := false; close(tfile); goto 1; end; gotoxy(0, 13); writeln('transfer complete!', chr(7)); writeln('press any key'); if send then close(tfile) else close(tfile, lock); repeat until getkey <> 255; goto 1; end. (* xmodem *) xmodem.mp4 RSUTIL.dsk 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 14 Share Posted March 14 Very nice. For perspective on potential speed of the hardware, using assembler for the primitive that reads the character like you have, with RTS/CTS handshaking I can send at 4800 bps to Forth and it echoes each character back. I set Teraterm to put a 100mS delay after each linefeed to give the compiler time to swallow the line. It has never missed a character at that speed. If I am just stuffing each character into a buffer, using Forth I can't quite do 9600. It misses a character now and then, but in Assembler it seems pretty solid at 19.2Kbps All this is without interrupts, just polling like you are doing. All that to say, if you created an assembly language "accept_chars" thing, that just stuffs characters into a buffer and keeps track of the length you can receive at up to 19,200 bps and never miss a character. And then with handshaking, I think Pascal could take care of processing each block at its own time. That's all I got. 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 15 Share Posted March 15 7 hours ago, TheBF said: All that to say, if you created an assembly language "accept_chars" thing, that just stuffs characters into a buffer and keeps track of the length you can receive at up to 19,200 bps and never miss a character. And then with handshaking, I think Pascal could take care of processing each block at its own time. Brilliant idea! I tried doing that but I can't seem to get it to work with any setting, so I must be doing something wrong. I need to make sure the assembly routine I called GETPACKET is valid. Since I am sending an array as a parameter to that routine, I am assuming that the pointer to the array passed to the routine is pointing to element 0 and that each subsequent memory word is pointing to the next element. That's probably an @apersson850 question. Here is the relevant part of the routine. Interestingly, when I tried to add it to the RS232UTIL library, I got the error TOO MANY PROCEDURES, so I had to create a separate library for it. That one is new to me... mov *r10+,r1 ;get array pointer li r2,132 ;size of packet sbz -27 ;activate cts line chkbuf tb 21 ;check if receive buffer is empty jne chkbuf clr r6 stcr r6,8 ;get byte sbz 18 ;reset buffer swpb r6 mov r6,*r1+ ;store byte in array dec r2 jne chkbuf sbo -27 ;inactivate cts 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 You might not need this with the xmodem protocol but what I did was make a "timed" getchar loop that waits for each character but not forever. That way when the data stream stops the code jumps straight into code that ends the communication. Just a thought. Something to consider. You can STCR directly into the buffer using indirect auto-inc. addressing and save instructions. mov *r10+,r1 ;get array pointer li r2,132 ;size of packet sbz -27 ;activate cts line chkbuf tb 21 ;check if receive buffer is empty jne chkbuf stcr *r1+,8 ;get byte directly into buffer, inc address sbz 18 ;reset buffer dec r2 jne chkbuf sbo -27 ;inactivate cts Here is what I am using. I realize it's quite a different looking assembler but maybe you can find something useful. ?? The IF statements can get confusing. When translating them to Jumps the logic is usually opposite so: EQ IF is really JNE instruction. Make sense? Spoiler \ STRAIGHT a word from PolyForth to accept chars fast, no echo \ Tested at 19.2Kbps with NEW H/W Handshake Dec 22, 2020 \ The TMS9900 is pretty slow so it is unreliable above 9600 without RTS/CTS control MARKER /STRAIGHT HEX CREATE ENDTRX \ NATIVE SUB-ROUTINE C320 , CARD , \ CARD @@ R12 MOV, \ select card 1E05 , \ 5 SBZ, \ CTS LOW, clear to send 1D07 , \ 7 SBO, \ LED OFF 0300 , 0002 , \ 2 LIMI, C101 , \ R1 TOS MOV, NEXT, .( .) HEX \ ** decimal numbers used for UART bit no.s CODE READCOM ( addr n -- n' ) 0300 , 0000 , \ 0 LIMI, \ full attention C236 , \ *SP+ W MOV, \ addr ->W (ie: R8) A108 , \ W TOS ADD, \ calc last address ->TOS 0700 , \ R0 SETO, \ set timeout register >FFFF 04C1 , \ R1 CLR, \ reset char counter \ BEGIN, \ * handshake hardware ON * C320 , CARD , \ CARD @@ R12 MOV, \ select card 1E05 , \ 5 SBZ, \ CTS LOW, clear to send 1D07 , \ 7 SBO, \ led ON A320 , UART , \ UART @@ R12 ADD, \ >1300+>40 = UART CRU 1F15 , \ 21 TB, \ test if char in uart 1609 , \ EQ IF, 3638 , \ *W+ 8 STCR, \ char to buff & inc buff 1D12 , \ 18 SBO, \ clr UART rcv buffer \ * handshake hardware off * C320 , CARD , \ CARD @@ R12 MOV, \ select card 1D05 , \ 5 SBO, \ CTS line HIGH. I am busy! 1E07 , \ 7 SBZ, \ led OFF 0700 , \ R0 SETO, \ reset timeout to 0FFFF 0581 , \ R1 INC, \ count char 1004 , \ ELSE, 0600 , \ R0 DEC, \ no char, dec TIMEDOUT 1602 , \ EQ IF, \ expired? 0460 , ENDTRX , \ ENDTRX @@ B, \ ENDIF, \ ENDIF, 8108 , \ W TOS CMP, \ W = end of buffer? 16E9 , \ EQ UNTIL, 0460 , ENDTRX , \ ENDTRX @@ B, ENDCODE .( .) HEX \ STRAIGHT from PolyForth. Read n chars into addr or timeout : STRAIGHT ( addr len -- n) CR ." Waiting..." 1 /STRING OVER 1- ( -- addr+1 len' addr) KEY SWAP C! \ WAIT for 1st Char & store READCOM CR ." Done! " OPEN-TTY KEY? DROP \ serial port gets weird after fast upload ? ; Quote Link to comment Share on other sites More sharing options...
apersson850 Posted March 15 Author Share Posted March 15 (edited) 10 hours ago, Vorticon said: Since I am sending an array as a parameter to that routine, I am assuming that the pointer to the array passed to the routine is pointing to element 0 and that each subsequent memory word is pointing to the next element. That's probably an @apersson850 question. Here is the relevant part of the routine. mov *r10+,r1 ;get array pointer li r2,132 ;size of packet sbz -27 ;activate cts line chkbuf tb 21 ;check if receive buffer is empty jne chkbuf clr r6 stcr r6,8 ;get byte sbz 18 ;reset buffer swpb r6 mov r6,*r1+ ;store byte in array dec r2 jne chkbuf sbo -27 ;inactivate cts Well, that's not all the relevant code, since we can't see how you declared the buffer you are using. The pointer you get will be to where the buffer starts. In an array[0..5] of integer it's to index 0, but in an array[5..10] of integer it's to item 5 in the buffer. Also, if you declare an array[0..80] of char, then each new value is one word away (two addresses, so MOV with autoincrement will track it. It's the same as an array[0..80] of integer. But a more common text buffer is a packed array[0..80] of char, in which case the index is by byte, so a MOVB with autoincrement will make it. Note that STCR will autoincrement by one up to eight bits transferred, then by two. If the buffer is a string[80] the pointer will point to index 0, which is the length byte, and then index by one from there. The whole string is 81 bytes long and will occupy 82 bytes in memory. This is a pseudo-declaration of a string. type byte = 0..255; string = packed record length: byte; packed array[1..size] of char; end; Packing in UCSD Pascal implies that the compiler will stuff things in words as tight as it can. So a packed array of char implies two chars per word, since they are eight bits each. You can also pack bytes per the definition above, since they are also eight bits. But if you define a data type as 0..511 and pack that, nothing happens, since each item is nine bits and thus two will not fit in a word. But one item of nine bits and two more, three bits each, will pack in a word with one unused bit left over. Booleans pack well, of course, since you get 16 in a word instead of only one if they aren't packed. Edited March 15 by apersson850 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 15 Share Posted March 15 9 hours ago, TheBF said: You can STCR directly into the buffer using indirect auto-inc. addressing and save instructions. Indeed, but I still need to SWPB prior to returning 3 hours ago, apersson850 said: Well, that's not all the relevant code, since we can't see how you declared the buffer you are using. These are the relevant lines on the host side TYPE INTARRAY = ARRAY[0..131] OF INTEGER; VAR BLOCK : INTARRAY; PROCEDURE GETPACKET(PACKET : INTARRAY); EXTERNAL; BEGIN ... GETPACKET(BLOCK); ... END. According to what you said then, this should work fine. In that case it must be a transmission issue somewhere. I'll do some more digging. Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted March 15 Share Posted March 15 I recently found my two original P-Code cards for my TI99 systems and the full binders for them with the manuals. But sadly the original floppies are gone. I guess there archives of them on WHT, but I was wondering if there was any updated setups by fellow 99ers that add like 80 column support or new features. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 15 Share Posted March 15 3 minutes ago, Gary from OPA said: I recently found my two original P-Code cards for my TI99 systems and the full binders for them with the manuals. But sadly the original floppies are gone. I guess there archives of them on WHT, but I was wondering if there was any updated setups by fellow 99ers that add like 80 column support or new features. The p-system is natively 80 columns, implemented on the TI with scrolling windows. It's effective enough once you get used to it. That said, support for the F18A would have been awesome though. It's not trivial to expand the system because the code is spread out between the ROMs and 2 different code pools (VDP and RAM) and minor changes can easily break it. Case in point being the Editor which practically uses nearly every last byte of the VDP. @apersson850 did expand his system with a 4th floppy drive and a couple of RAM disks as well as a hardware RTC, but it required some high level wizardry. One gets the feeling that the p-system was forcefully squeezed into the limited TI resources using every possible trick in the book at the expense of expansion flexibility. Still quite an achievement and by far the best development environment available at the time on the TI when emulation and cross-development were not available. 3 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted March 15 Author Share Posted March 15 42 minutes ago, Vorticon said: Indeed, but I still need to SWPB prior to returning These are the relevant lines on the host side TYPE INTARRAY = ARRAY[0..131] OF INTEGER; VAR BLOCK : INTARRAY; PROCEDURE GETPACKET(PACKET : INTARRAY); EXTERNAL; BEGIN ... GETPACKET(BLOCK); ... END. According to what you said then, this should work fine. In that case it must be a transmission issue somewhere. I'll do some more digging. SWPB? That kind of depends. Your own code is storing 132 received bytes into 132 words, not using half of the space available. You clear every second byte in the buffer. @TheBF stores 132 received bytes into 132 bytes, leaving the remaining 132 bytes empty. Storing bytes in every byte is the normal procedure. The buffer is then ususally declared as a packed array[0..131] of char. I've not checked the details of your RSUTIL thing yet, but I presume you do math with the received characters? But a buffer declaration like this one will allow you do to math with every character and still store them as bytes. type byte = 0..255; buffer = packed array[0..131] of byte; 1 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted March 15 Share Posted March 15 (edited) 54 minutes ago, Vorticon said: The p-system is natively 80 columns, implemented on the TI with scrolling windows. It's effective enough once you get used to it. That said, support for the F18A would have been awesome though. It's not trivial to expand the system because the code is spread out between the ROMs and 2 different code pools (VDP and RAM) and minor changes can easily break it. Case in point being the Editor which practically uses nearly every last byte of the VDP. @apersson850 did expand his system with a 4th floppy drive and a couple of RAM disks as well as a hardware RTC, but it required some high level wizardry. One gets the feeling that the p-system was forcefully squeezed into the limited TI resources using every possible trick in the book at the expense of expansion flexibility. Still quite an achievement and by far the best development environment available at the time on the TI when emulation and cross-development were not available. Ok, thanks for the update. I guess something to look into redoing for f18a or v9938 support. That going to take some rewriting. Add it to my growing list of coding projects. Any available on what @apersson850did to at least add Ramdisk and the clock? Edited March 15 by Gary from OPA Quote Link to comment Share on other sites More sharing options...
Rhodanaj Posted March 15 Share Posted March 15 On 3/14/2024 at 2:37 PM, Vorticon said: @Rhodanaj is looking into the possibility of allowing Pcode Tool to insert transferred files into existing disk images. 😊 and I have the first test programma ready ☺️ I do not have a real TI anymore, so I could only test it with some files i got from @Vorticon. I have to do some more tests with Data files, but text and code files should go without problems. When you try this version 'V6.0 - Test' and you have any problems, please let me know. When you copy a PCode file from a virtual TI disk to Windows, with p-code-tool, the program will add 24 bytes with the file info at the end. When you transfer a file by @Vorticon's program to Windows, there is no file info with it. So when you want to get this file into a virtual TI disk, you have to tell what kind of file it is (TEXT, CODE or DATA). p-code-tool V6.0 - Test.exe 1 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 16 Share Posted March 16 Works great with xmodem transferred code and text files. Thank you! Edit: transferred data files can be added to existing disk images with the Get Binary File option of Pcode Tool. As a background, the whole purpose of creating the Xmodem utility was to allow for file transfers to the PC for backup or sharing purposes and the other way around, particularly when when it's only 1 or 2 files. Prior to Xmodem, the only way to transfer files to/from the pcode system was by using Fred Kaal's HDX system and the DSK2PC utility which transfers whole disks, a rather slow process requiring modifications to the RS232 card. The problem encountered with Xmodem transfers however was that the files were not recognized by Pcode Tool properly and so could not be imported into a disk image. This issue has now been solved Pcode Tool is an invaluable utility for any pcode system user, so big thanks to @Rhodanaj for all his efforts. On a side note, I can definitely relate to his space-themed avatar icon 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 16 Share Posted March 16 23 hours ago, Gary from OPA said: Any available on what @apersson850did to at least add Ramdisk and the clock? I'm sure he'll chime in on this and give you all the gory details Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 16 Share Posted March 16 10 hours ago, Vorticon said: Prior to Xmodem, the only way to transfer files to/from the pcode system was by using Fred Kaal's HDX system and the DSK2PC utility which transfers whole disks, a rather slow process requiring modifications to the RS232 card. The problem encountered with Xmodem transfers however was that the files were not recognized by Pcode Tool properly and so could not be imported into a disk image. I have been a X BASIC program that has Assembly language support to do XMODEM called "Magic File Manipulator for 6 years or so. It works well and transfers at 19.2Kbps but it means leaving your current environment and going to BASIC. Yours is available directly from Pascal which is ideal. I need a version for the same reason so that I can remain in Forth and transfer binary files. You are an inspiration. 1 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 16 Share Posted March 16 23 hours ago, apersson850 said: SWPB? That kind of depends. Your own code is storing 132 received bytes into 132 words, not using half of the space available. You clear every second byte in the buffer. @TheBF stores 132 received bytes into 132 bytes, leaving the remaining 132 bytes empty. Storing bytes in every byte is the normal procedure. The buffer is then ususally declared as a packed array[0..131] of char. I've not checked the details of your RSUTIL thing yet, but I presume you do math with the received characters? But a buffer declaration like this one will allow you do to math with every character and still store them as bytes. type byte = 0..255; buffer = packed array[0..131] of byte; Since the return subroutine stack returns words, not bytes, that is the reason for declaring an array of integers. I suppose I could pack 2 bytes into a register in the assembly receive routine before returning, but that adds more instructions and delays. Then I can declare a packed array of bytes. Not sure there is value in doing that since it complicates things. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 16 Share Posted March 16 2 minutes ago, TheBF said: You are an inspiration. Seems to me it's the other way around! But hey I'm always up for a little confidence building 😄 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 16 Share Posted March 16 Just now, Vorticon said: Since the return subroutine stack returns words, not bytes, that is the reason for declaring an array of integers. I suppose I could pack 2 bytes into a register in the assembly receive routine before returning, but that adds more instructions and delays. Then I can declare a packed array of bytes. Not sure there is value in doing that since it complicates things. That's why you would STCR each byte directly into memory with *Rx+. Even it was a separate buffer you should be able to transfer that Assembly buffer to a Pascal packed array no? 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted March 16 Author Share Posted March 16 3 minutes ago, Vorticon said: Since the return subroutine stack returns words, not bytes, that is the reason for declaring an array of integers. I was thinking about if you make an assembly routine that fills a buffer, whatever the size, then it would make more sense filling it bytewise, not wordwise. I was thinking to abandon the single word return thing in this case. Go from characters to "lines". 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted March 16 Author Share Posted March 16 (edited) On 3/15/2024 at 2:46 PM, Gary from OPA said: Any available on what @apersson850did to at least add Ramdisk and the clock? Sure there is, but it's not very relevant for an 80 column adaption. As said, the p-system is already 80 columns - it can just only show 40 at the same time. The immediate issue I see with doing this on a real machine is that the screen related surbroutines (like display one half of the 80 column screen on the physical 40 column screen or print a character on the simulated 80 column screen) are in ROM on the p-code card. So they are a bit tricky to change. Edited March 17 by apersson850 Quote Link to comment Share on other sites More sharing options...
Rhodanaj Posted March 16 Share Posted March 16 (edited) 12 hours ago, Vorticon said: On a side note, I can definitely relate to his space-themed avatar icon I have been reading the Perry Rhodan magazine ( https://en.wikipedia.org/wiki/Perry_Rhodan ) since 1970. In order to download the classic Doctor Who episodes from a site (Sharez org) around 2005, I needed a username to register and the first thing I thought of was the name Rhodan. With AJ behind it from my own name 'Antoon Jansen', I had a unique username for that site.... (the icon is of course an image of Perry Rhodan himself) Edited March 16 by Rhodanaj 4 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 16 Share Posted March 16 1 hour ago, TheBF said: That's why you would STCR each byte directly into memory with *Rx+. Even it was a separate buffer you should be able to transfer that Assembly buffer to a Pascal packed array no? 1 hour ago, apersson850 said: I was thinking about if you make an assembly routine that fills a buffer, whatever the size, then it would make more sense filling it bytewise, not wordwise. I was thinking to abandon the single word return thing in this case. Go from characters to "lines". Ah I think I understand where you guys are going with this. STCR directly to *R1+, and since it's a byte move, the autoincrement will increase the target memory by one byte so that I end up having a byte oriented buffer. No need for using another register (R6) at all and no byte manipulation. Then in the host program declare a packed byte array that would receive that buffer. Saves a few instructions in the receive routine which is always good. I'll make the changes and do some testing later today. 4 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 16 Share Posted March 16 I switched the Xmodem routines from byte to packet based send and receive and there is a definite increase in baud rate, but not nearly as much at @TheBF is reporting. For send I can go as high as 9600 bps, but for receive only 2400 bps remains reliable although I have managed a couple of 4800 bps transfers. I am not setting any character or line delays in Teraterm. Below are the assembly routines, and they are as tight as I can make them, so it's unclear to me what else I can do. ;set of routines for packet reception for xmodem ;by walid maalouli ;March 2024 .proc xsetrs232,1 ; set up the rs232 card cru base ; 1 = CRU 1300H, 2 = CRU 1500H ; usage: setrs232(n) .def cruadr,pmeret,procret,pcodeon,pcodoff,uartdis .def rs232on,rs232of mov r12,@pmeret ;save the pme pointer mov *r10+,r1 ;get desired RS232 card number ci r1,1 jne rs2322 li r12,1300h li r3,40h ;uart base address displacement jmp savecru rs2322 li r12,1500h li r3,80h ;uart base address displacement savecru mov r12,@cruadr ;save base CRU address mov r3,@uartdis ;save uart base address displacement mov @pmeret,r12 ;restore the pme pointer b *r11 cruadr .word pmeret .word procret .word uartdis .word pcodeon li r12,1f00h ;activate the pcode card sbo 0 mov @pmeret,r12 ;retrieve the pme pointer b *r11 pcodoff mov r12,@pmeret ;save the pme pointer li r12,1f00h ;deactivate the pcode card sbz 0 b *r11 rs232on mov @cruadr,r12 ;load rs232 cru base sbo 0 ;turn card on sbo 7 ;turn card led on b *r11 rs232of mov @cruadr,r12 ;load rs232 cru base sbz 7 ;turn card led off sbz 0 ;turn card off b *r11 .proc getpacket,1 ;get an xmodem packet ;usage: getpacket(bytearray) .ref pcodeon,pcodoff,rs232on,rs232of,uartdis,procret mov r11,@procret bl @pcodoff bl @rs232on mov *r10+,r1 ;get array pointer a @uartdis,r12 ;uart base cru address li r2,131 ;number of bytes to get sbz -27 ;activate cts line bufchk tb 21 ;check if receive buffer is empty jne bufchk stcr *r1+,8 ;store byte into array sbz 18 ;reset buffer cru bit 21 dec r2 jne bufchk ;132 bytes transferred? sbo -27 ;inactivate cts line bl @rs232of bl @pcodeon mov @procret,r11 b *r11 .proc sendpacket,1 ;send an xmodem packet ;usage: sendpacket(bytearray) .ref pcodeon,pcodoff,rs232on,rs232of,uartdis,procret mov r11,@procret bl pcodoff bl rs232on mov *r10+,r1 ;get array pointer a @uartdis,r12 ;set uart base address li r2,132 ;number of bytes to send notconn tb 27 ;test dsr pin. is receiver connected? jne notconn sbo 16 ;activate rts line waitcts tb 28 ;wait for receiver to activate cts line jne waitcts chkbuf tb 22 ;is emission buffer empty? jne chkbuf ldcr *r1+,8 ;send byte from array dec r2 ;are all bytes sent? jne waitcts sbz 16 ;inactivate rts line bl @rs232of bl @pcodeon mov @procret,r11 b *r11 .end and here's the new XMODEM program Spoiler {$i-} (* xmodem file transfer utility *) (* xmodem checksum only. xmodem crc not supported *) (* by walid maalouli *) (* march 2024 *) program xmodem; label 1; type byte = 0..255; bytearray = packed array[0..131] of byte; byteword = record case boolean of true : (value : integer); false : (bytes : packed array[0..1] of byte); end; longint = record case boolean of true : (value : integer[4]); false : (intval : packed array[0..1] of integer); end; var key, d : integer; send, timeout : boolean; fname : string; tfile : file; function getkey : integer; external; procedure setrs232(base : integer); external; procedure getbyte(var n, flag : integer); external; procedure sendbyte(n : integer); external; procedure xsetrs232(xbase : integer); external; procedure getpacket(var packet : bytearray); external; procedure sendpacket(var packet : bytearray); external; procedure sendfile; label 1; var i, j, flag, blocksin, buffloc, packet, tdata, comcode : integer; stime, itime : longint; block : bytearray; buffer : array[0..255] of byteword; begin (* sendfile *) packet := 1; buffloc := 0; while (not(eof(tfile))) or ((eof(tfile)) and (buffloc < 255) and (buffer[buffloc].bytes[0] <> 26)) do begin if buffloc = 0 then begin fillchar(buffer, 512, chr(26)); {fill buffer with padding character} blocksin := blockread(tfile, buffer, 1); buffloc := 0; end; (* set up transmission packet *) tdata := 0; block[0] := 1; {soh} block[1] := packet; {transmitted packet number} block[2] := 255 - packet; j := 3; while j < 131 do begin block[j] := buffer[buffloc].bytes[0]; tdata := tdata + block[j]; block[j + 1] := buffer[buffloc].bytes[1]; tdata := tdata + block[j + 1]; j := j + 2; buffloc := succ(buffloc); if buffloc > 255 then if not(eof(tfile)) then buffloc := 0 else buffloc := 255; end; block[j] := tdata mod 256; {checksum} (* send transmission packet *) 1: sendpacket(block); time(stime.intval[0], stime.intval[1]); {start time} repeat getbyte(comcode, flag); {wait for remote ack or nak code} time(itime.intval[0], itime.intval[1]); {interval time} if (itime.value - stime.value) > 35 then {20 second timeout} begin timeout := true; exit(sendfile); end; until comcode in[6, 21]; if comcode = 21 then {resend block if nak received} goto 1; gotoxy(15, 23); write(packet); packet := succ(packet); end; sendbyte(4); {send eot code} time(stime.intval[0], stime.intval[1]); {start time} repeat getbyte(comcode, flag); {wait for ack code} time(itime.intval[0], itime.intval[1]); {interval time} if (itime.value - stime.value) > 35 then {20 second timeout} begin timeout := true; exit(sendfile); end; until comcode = 6; end; (* sendfile *) procedure recvfile; label 1; var i, flag, packet, tdata, buffloc, blocksin, errcount, comcode : integer; recerr, eotcode : boolean; block : bytearray; buffer : array[0..255] of byteword; begin (* recvfile *) (* receive packet *) recerr := false; eotcode := false; buffloc := 0; errcount := 0; 1: sendbyte(21); {send nak code} getbyte(comcode, flag); {check if soh code received} if comcode <> 1 then recerr := true; getpacket(block); {get 131 byte packet} repeat if buffloc = 0 then fillchar(buffer, 512, chr(26)); {fill buffer with padding character} tdata := 0; packet := block[0]; {packet number} {check if inverse packet number matches} if (255 - packet) <> block[1] then recerr := true; for i := 2 to 129 do tdata := tdata + block[i]; {check if checksum correct} if (tdata mod 256) <> block[130] then recerr := true; if recerr then begin errcount := succ(errcount); if errcount > 10 then begin timeout := true; exit(recvfile); end else begin recerr := false; goto 1; end; end; (* process packet *) i := 2; while i < 130 do begin buffer[buffloc].bytes[0] := block[i]; buffer[buffloc].bytes[1] := block[i + 1]; i := i + 2; buffloc := succ(buffloc); end; if buffloc > 255 then begin buffloc := 0; blocksin := blockwrite(tfile, buffer, 1); end; gotoxy(18, 23); write(packet); errcount := 0; sendbyte(6); {send ack code} getbyte(comcode, flag); {check if soh or eot received} if comcode = 4 then eotcode := true else if comcode <> 1 then begin timeout := true; exit(recvfile); end else getpacket(block); until eotcode; sendbyte(6); {send ack code} end; (* recvfile *) begin (* xmodem *) 1: page(output); writeln('(R)eceive file'); writeln('(S)end file'); writeln('(Q)uit program', chr(7)); repeat key := getkey; until key in[81, 82, 83]; case key of 81 : exit(program); 82 : begin writeln('receive mode'); send := false; end; 83 : begin writeln('send mode'); send := true; end; end; repeat gotoxy(0, 5); writeln('enter filename:', chr(7)); readln(fname); if send then reset(tfile, fname) else rewrite(tfile, fname); until ioresult = 0; writeln(chr(10), chr(7), '1: rs232/1 2: rs232/2'); repeat key := getkey; until key in[49, 50]; if key = 49 then begin setrs232(1); xsetrs232(1); writeln('using rs232/1'); end else begin setrs232(2); xsetrs232(2); writeln('using rs232/2'); end; writeln(chr(10), chr(7), 'press any key to start transfer...'); repeat until getkey <> 255; timeout := false; if send then begin gotoxy(0, 23); write('packets sent: '); sendfile; end else begin gotoxy(0, 23); write('packets received: '); recvfile; end; if timeout then begin gotoxy(0, 21); writeln(chr(7), 'transfer error!'); for d := 1 to 2000 do begin end; timeout := false; close(tfile); goto 1; end; gotoxy(0, 13); writeln('transfer complete!', chr(7)); writeln('press any key'); if send then close(tfile) else close(tfile, lock); repeat until getkey <> 255; goto 1; end. (* xmodem *) Still, I'm overall pretty happy with the results and it's fast enough for most transfers and much faster than whole disk transfers. Updated disk image attached. RSUTIL.dsk 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 17 Share Posted March 17 Nice work. Looking at your Assembly language code the only difference I see is that you put TB 21 in an infinite loop. I used a timed loop that jumped out only when the characters stopped coming. Not sure that makes a difference. ?? Anyway I gotta get something going here now that you have set the bar. 3 Quote Link to comment Share on other sites More sharing options...
