Reaperman Posted February 11, 2012 Share Posted February 11, 2012 I've replaced my LCD with one feeding from the composite port, and installed a 50/60hz switch. Does the nomad properly output PAL colors through composite? My screen recognizes the PAL timing and the game plays at the correct speed, but it's displayed in b/w. Is there a mod out there that fixes the issue? Or is it not an issue for most since the stock screen probably uses RGB which does either? Quote Link to comment Share on other sites More sharing options...
Reaperman Posted February 11, 2012 Author Share Posted February 11, 2012 (edited) Well, after some research, it seems like I'm going to need a second clock for pal color. If anybody happens across this with the same problem, this seems like a decent tutorial. Edited February 11, 2012 by Reaperman Quote Link to comment Share on other sites More sharing options...
