walter_J64bit Posted January 17, 2003 Share Posted January 17, 2003 Im need some help I want to make some VCD's the files Ive have are in AVI but thay need to transformed to MPEG Any good program I can use? Quote Link to comment Share on other sites More sharing options...
Lemmi Posted January 17, 2003 Share Posted January 17, 2003 humm am i the only one who makes VCD's out of AVI files? i use NERO i cant figure out how to make mpeg files into VCD's there must be something im just missing, when i try to make mpegs/mpg into vcd's i get a might not burn properly box popup, but avi files burn like a charm Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted January 17, 2003 Share Posted January 17, 2003 Are you following this method? http://users.chariot.net.au/~menzy/divxtovcd.html Quote Link to comment Share on other sites More sharing options...
liquid_sky Posted January 17, 2003 Share Posted January 17, 2003 Walter, Are you trying to make movies viewable on any home dvd player, or a jagcd? I dont know enough about the jagcd to help you, other than that it uses cinipak compression Quote Link to comment Share on other sites More sharing options...
benjam138 Posted January 17, 2003 Share Posted January 17, 2003 Im need some help I want to make some VCD's the files Ive have are in AVI but thay need to transformed to MPEG Any good program I can use? I have done this before. I use a freeware program called TMPGE, or something like that. You can get very easy to follow instructions at www.vcdhelp.com. If you have any questions, feel free to pm me. -Ben Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted January 17, 2003 Author Share Posted January 17, 2003 Lemmi wrote: humm am i the only one who makes VCD's out of AVI files? i use NERO i cant figure out how to make mpeg files into VCD's there must be something im just missing, when i try to make mpegs/mpg into vcd's i get a might not burn properly box popup, but avi files burn like a charm Thats funny I have NERO ver. 5.5.5.1 If I use mpeg I can make VCD's but if I use AVI I get the box popup Quote Link to comment Share on other sites More sharing options...
Lemmi Posted January 17, 2003 Share Posted January 17, 2003 Ive got Nero 5.5.8.3 i dont know if the minor difference would be a factor, or if i changed something in my mulling around in the options area and i think Icecold had the same problem i do with the mpeg files, i told him to try an AVI. file , but i havent asked him if that worked i dont make many VCD's and im not very experienced with using a burner and programs yet Quote Link to comment Share on other sites More sharing options...
MattyXB Posted January 17, 2003 Share Posted January 17, 2003 I use TMPGEnc to convert the avi files to mpg files. There you can make VCD-MPG files and it will work great. Just Load the Config File for VCD NTSC or VCD PAL (what I use). But you will need maybe the NTSC version, which is a bit different. The programm can be found here: TMPGEnc Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted January 17, 2003 Author Share Posted January 17, 2003 Thanks for the info! This is hard task and long one but its all good! Making vcd for the jag would good Subject but its just for my dvd player! Quote Link to comment Share on other sites More sharing options...
liquid_sky Posted January 18, 2003 Share Posted January 18, 2003 http://www.vcdeasy.org/modules.php?name=_D...wnloads#VCDEasy This is what I use to burn VCDS (sorry i didnt reply sooner) Screenshots here http://www.vcdeasy.org/modules.php?name=_ScreenShots small teaser to show how easy of a program it is.. Again, sorry for taking so long to get back to ya Quote Link to comment Share on other sites More sharing options...
EricBall Posted January 19, 2003 Share Posted January 19, 2003 The other place to go for VCD info is www.doom9.net. Quote Link to comment Share on other sites More sharing options...
IceCold Posted January 19, 2003 Share Posted January 19, 2003 Icecold had the same problem i do with the mpeg files, i told him to try an AVI. file , but i havent asked him if that worked I tried AVI's, still doesn't work. I think it's just that my CD-i player can't read vcd's well, becuase I tried the ones I made using .mpeg and they run fine on my brother's dvd player. And I can get them to play EVENTUALLY on the CD-i after many, many, many tries. Quote Link to comment Share on other sites More sharing options...
