ti99iuc Posted February 26, 2012 Share Posted February 26, 2012 Hi Friends, becouse i am doing conversion of 1500 floppy disks (by HxC or TI99-PC or Kryoflux), it's not first time that i would want have help from you for understand what a program is or do or if is not a program or other informatsion that i do not know... so i would want use this thread every time i need help from you about program i will found in my disk ... ..... community at work ... so... for starting i purpose a file images. i have about 70 disks all with the same progam format of the file in attachment, maybe they could be all pictures, but i do not know how to open that kind of files may be you know ? Strange files program.zip Thank you Ciro. Quote Link to comment Share on other sites More sharing options...
GratedTopping Posted February 26, 2012 Share Posted February 26, 2012 (edited) That's a disk file and should have TIdisk at the end for use with "Win994a" emulator. Every file in it is DIS/VAR format and each file has "_I" at the end. The disk's name is BK. I imagine they are picture files, perhaps viewable with TI ARTIST? However, I can't test it as my TI ARTIST disk file doesn't seem to work with the emulator. The program "TI99dir" doesn't allow me to view the files as pictures, so I'm not fully sure what they are. I hope you would share your games or other TI files when you can. You probably have a lot of good software. (-: Edited February 26, 2012 by GratedTopping Quote Link to comment Share on other sites More sharing options...
GratedTopping Posted February 26, 2012 Share Posted February 26, 2012 Hi. I found this information: There are 3 files extensions for TI Artists's files: 1) _C and _P: standard picture files; 2) _F: fonts files (load them from "enhanced" menu, then "Fonts"); 3) _I: instances (cliparts). Load the instance (from "enhanced" menu). It shows a bounding box which can be moved around with the joystick. Pressing the fire button drops the instance on the screen. So, the files are 'instances' (clipart) and can be used with TI ARTIST. 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 26, 2012 Author Share Posted February 26, 2012 Hi. I found this information: There are 3 files extensions for TI Artists's files: 1) _C and _P: standard picture files; 2) _F: fonts files (load them from "enhanced" menu, then "Fonts"); 3) _I: instances (cliparts). Load the instance (from "enhanced" menu). It shows a bounding box which can be moved around with the joystick. Pressing the fire button drops the instance on the screen. So, the files are 'instances' (clipart) and can be used with TI ARTIST. WOW ! Thankyou for Helping me ! ... so i have about 70 disks SSDD of Clipart for TI Artist !? ... :-) perfect... i will catalog too... thankyou again ! Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 26, 2012 Author Share Posted February 26, 2012 Ok, now more difficult... there is a shoes box with these kind of disks ??? C1AZ.zip Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 26, 2012 Author Share Posted February 26, 2012 (edited) Ok, now more difficult... there is a shoes box with these kind of disks ??? C1AZ.zip i found this documet on line, someone understand what program need to open these files ? ***** Shareware Notice ***** The images in these files are the property of Cooper Graphics, 5846 Highway 111 South, New Albany, In. 47150. They are issued as shareware for TI-99/4A and Myarc 9640 users. If you enjoy using these images you should register by sending $5.00 to the authors listed above. Please specify your system (TI-99/4A or Myarc 9640) when registering. Additional comments: (1) The $5.00 covers the following files of images or icons from Cooper Graphics, representing a total of 600 instances of empty frames, icons for U.S. states, signs (text only and text-with-picture), faces, and miscellaneous picture icons: C1AZTXT, C1AZXXX, C2AZTXT, C2AZXXX, C3AZTXT, C3AZXXX, C4AZTXT, C4AZXXX, C5AZTXT, C5AZXXX, C6AZTXT, and C6AZXXX. (It does not cover other shareware packages that may be issued from Cooper Graphics.) Edited February 26, 2012 by ti99userclub Quote Link to comment Share on other sites More sharing options...
