Rev Posted February 29, 2012 Share Posted February 29, 2012 (edited) I want to directly record my gameplay videos from my TV to my computer. How some of you guys do it. I heard about a device called the Dazzle. Edited February 29, 2012 by revolutionika Quote Link to comment Share on other sites More sharing options...
+evg2000 Posted February 29, 2012 Share Posted February 29, 2012 (edited) I use a TV card in my mac that has s-video, composite, and RF inputs. Cost about $100. If you have a pc you could probably use something like this: http://www.dealextre...ner-card-112132 or here are a bunch on amazon: http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Delectronics&field-keywords=tv+tuner+pci#/ref=sr_nr_p_36_0?rh=n%3A172282%2Ck%3Atv+tuner+pci%2Cp_36%3A1253503011&bbn=172282&keywords=tv+tuner+pci&ie=UTF8&qid=1330486455&rnid=386442011 Edited February 29, 2012 by evg2000 Quote Link to comment Share on other sites More sharing options...
Rev Posted February 29, 2012 Author Share Posted February 29, 2012 I use a TV card in my mac that has s-video, composite, and RF inputs. Cost about $100. If you have a pc you could probably use something like this: http://www.dealextre...ner-card-112132 Check out the Dazzle, I seen it on youtube the other day. you ever hear about that? It is an external method versus something you have to install in your PC. Quote Link to comment Share on other sites More sharing options...
Austin Posted February 29, 2012 Share Posted February 29, 2012 I use a TV card in my mac that has s-video, composite, and RF inputs. Cost about $100. If you have a pc you could probably use something like this: http://www.dealextre...ner-card-112132 Check out the Dazzle, I seen it on youtube the other day. you ever hear about that? It is an external method versus something you have to install in your PC. There are a lot of devices like the Dazzle. You are going to want something with a RF input though unless you have your consoles A/V modded. Or, you can buy a cheap device along the lines of a Dazzle (they can run $30+), hook your system to a VCR and let that convert the signal to composite, then plug your VCR into the capture card/device. Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted February 29, 2012 Share Posted February 29, 2012 Personally I use a cheap low end standalone DVD -Recorder. Got tired of audio sync issues, after several USB devices from Dazzle to 3 others I record direct to DVD now, has a tv tuner built in and composite or even RF (coaxial) input just like a VCR. This way, gameplay is recorded and ready to import into my editing program and the original footage is already archived to DVD. I had to many issues trying to record to my PC, when I switched to windows 7 I had driver issues that were never resolved and incompatibility with software and the OS, screw that, took the PC out of the recording equation and have never looked back! $80 low end DVD recorder form FutureShop. Quote Link to comment Share on other sites More sharing options...
+evg2000 Posted February 29, 2012 Share Posted February 29, 2012 In my original post I also added a bunch more from amazon that are under $50. It depends on what you want, cheapest way is with an internal card, most of them handle video, composite, and rf, so most everything you would want. I had tried usb devices in the past, never happy with them. Also, the nice thing about the internal ones with the three different inputs is most of them will also work with PAL, so you can use your PAL systems to play games or record videos. Quote Link to comment Share on other sites More sharing options...
