Keatah Posted May 19, 2012 Share Posted May 19, 2012 (edited) It seems safe to say that anything p4-class at 1100MHz and up will work fine. A PIII at 1 GHz is about as fast as a PIV at 1.4 GHz. So if the PIII is struggeling at 1.4 GHz, you need at least a 2 - 2.5 GHz PIV. If the CPU is the bottleneck. I understand the shorter pipeline in the P3 is a good thing. I also know that my 1st test system, the P4 mobile Dothan core, has a much better IPC than Netburst on a regular P4 and the P3. I would guess perhaps the P3 I tested is lagging due to missing instructions or perhaps it's even the ISA soundcard or the slow-ass 100MHz bus. Edited May 19, 2012 by Keatah Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 20, 2012 Share Posted May 20, 2012 Stephen I wouldn't worry about the slowdown between 3.6.1 and 3.7, It's not significant enough and can be "tuned out" by dropping the resolution or not using gl fs stretch. Quote Link to comment Share on other sites More sharing options...
+stephena Posted May 22, 2012 Author Share Posted May 22, 2012 Just another quick update. First the bad news. I've pushed the release date until June 1. But barring any major issues that pop up at work, I won't be going past that date. Now the good news. I think I've fixed the speed regression from 3.6 to 3.7. It was necessary to fix this, since we've moved from 16-bit to 32-bit colour, and the new phosphor effect will use blending, which stresses the video card a little. So I wanted to reduce the CPU usage as much as possible, since it'll increase with new features. So here's another test release. Note that this one still doesn't have phosphor effect enabled for TV modes, but it does use 32-bit framebuffer. So it's just like the last release, except it should be faster. Testing on my systems show that it's just as fast in 32-bit colour mode as 3.6 was in 16-bit colour mode. Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 22, 2012 Share Posted May 22, 2012 Ehh shit.. I'm not going to have time to test this! Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 22, 2012 Share Posted May 22, 2012 Wait. I can get in a quick side by side comparison! Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 22, 2012 Share Posted May 22, 2012 Working.. Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 22, 2012 Share Posted May 22, 2012 (edited) Nicely done! I see a significant decrease in cpu usage. About 25-30%. I had the filtering effects enabled. This graph shows the prior version on the left and the new beta on the right. Edited May 22, 2012 by Keatah Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 22, 2012 Share Posted May 22, 2012 I also see ZERO speed decrease when switching between BLIT and FLIP modes in my graphics card driver option menu. In the previous beta 3.7.2 there would be a slowdown in BLIT mode. Also I believe the 3.6.1 > 3.7.x slowdown has been stomped on. I don't have time to do an in-depth test. But it looks promising. I will run a quick test that I believe will tell the truth entirely once and for all.. Wait... Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 22, 2012 Share Posted May 22, 2012 Absolutely thrilling! I eco-clocked my CPU down to 600MHz and cut the integrated on-board Intel EXTREME Graphics II core to 133MHz. Half speed on the GPU basically. We were getting full head of steam and had clock cycles to spare. I think I could run this as low as 475MHz before we see a slowdown. Righteous! Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 22, 2012 Share Posted May 22, 2012 I took the afternoon off to play with this shit and finish up my commentary on the Paddle emulation issues (which you probably don't want to hear about). I regressed this crap back to 3.6.1 and did another side-by-side comparison, again with the CPU clocked down low to see some granularity. 3.6.1 and 3.7.3 are indeed now the same - within 2-3% as far as I can see in the graphs. Quote Link to comment Share on other sites More sharing options...
+stephena Posted May 22, 2012 Author Share Posted May 22, 2012 OK, good that the issue is fixed. Now I can continue working on this, adding features that take some of that performance back Quote Link to comment Share on other sites More sharing options...
israelg Posted May 22, 2012 Share Posted May 22, 2012 Well, still working great for me... After Keatah tests I can't really contribute on this subject... Waiting to see to phosphor effects... The visual aspects of this version are more close to my heart... Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 22, 2012 Share Posted May 22, 2012 (edited) hey guys how do I get these command line arguments working? It would appear that -video <soft|gl> is working fine. Good.. But -ntsc_filter <1|0> and -gl_filter <nearest|linear> seem busted. There's no effect. I have not played with other command line options, so maybe there are more that are broke? Edited May 22, 2012 by Keatah Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 22, 2012 Share Posted May 22, 2012 Ahh shit.. Miniature Golf (Atari 1979) has miniature glitches in the playfields. They are really really miniaturized. And they a-wasn't present in 3.6.1. In each screenshot I positioned the club below the affected area. Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 23, 2012 Share Posted May 23, 2012 (edited) It also shows up in some other games like MazeCraze and Adventure, so it's not game specific. Seems to happen when I have gl_fs_stretch on and 1024x768 resolution, which happens to be the same as my desktop. If I select 640x480 or 800x600 or turn of fs_stretch then it goes away, but then the image size isn't quite full screen - border to border. I also got the old beater PIII going at full speed with room to spare. And I dropped my other system's clock speed to 468MHz, with filtering before it started slowing down. Edited May 23, 2012 by Keatah Quote Link to comment Share on other sites More sharing options...
+stephena Posted May 23, 2012 Author Share Posted May 23, 2012 The 'artifacts' are from performing what is called a non-integral stretch. Basically, this is stretching an image by a non integer amount (so instead of 1x, 2x, etc, it's probably something like 2.66 or 3.4). As such, there's no guarantee that the image will come out looking precisely the same as its non-stretched representation. This is also dependent on video cards and drivers; some do it better than others. One other thing that occurred to me is that I haven't tested much on 4:3 displays, since all I have access to here is 16:9 and 16:10 widescreens. This issue will have to be pushed post-3.7, since I'm not even sure I can fix it. As for the dead commandline arguments, I'm assuming you're looking at the 3.6.1 documentation, because these items aren't actually present in 3.7. Have a look in the 'docs' directory of beta3, which contains more up-to-date documentation. Keep in mind that you're downloading WIP releases, which of course also includes the documentation. Quote Link to comment Share on other sites More sharing options...
+stephena Posted May 23, 2012 Author Share Posted May 23, 2012 OK, I'm making good progress on the phosphor effect. One initial issue is that I was trying to make it look like software mode, where there is absolutely no flicker at all. However, I realized that this was just an idealized approximation; the colours there are precomputed to completely remove flicker, and the phosphor 'blend' simply lightens or darkens the output. But when you think about it, this isn't how a real TV works; there is always some flicker, but it's not as noticeable as on an LCD. The real issue is that in Stella, flickering is happening because you're first drawing a completely black area, then coloured, then completely black again, and so on. So what needs to happen is that coloured areas 'persist', and black doesn't. But you can't just completely through away the black, since then the image is all colour, which (while probably nice looking) doesn't emulate what a real TV look like. Anyway, long story short, the phosphor blend for OpenGL modes (including TV effects) will now act as a real blend %. That is, phosphor blend of 100% will show complete colour and throw away black completely. Phosphor blend of 0% will alternate between black and colour every frame (IOW, just like turning it off). And anything in between will give you varying levels of persistence, which results in varying levels of flicker. With the default of 77%, you can just see some slight flicker; it isn't completely hideous, but isn't completely gone either. Which is how a real TV looks. Quote Link to comment Share on other sites More sharing options...
+Trebor Posted May 23, 2012 Share Posted May 23, 2012 Excellent update and thanks again, stephena. Your efforts to get the phosphor effect working on a modern day display so that it simulates the look of a tradtional CRT is very much appreciated. Quote Link to comment Share on other sites More sharing options...
+stephena Posted May 23, 2012 Author Share Posted May 23, 2012 And some snapshots to illustrate what I mean. These are with TV effects turned off; I haven't integrated Blarrg filtering and phosphor mode yet: Software rendering (colours are precomputed, no flicker at all, 77% 'blend' level): OpenGL rendering (actually uses OpenGL blending, 80% blend level): Note how in the second snapshot you can actually see parts of the previously drawn image. That's what I mean by 'persistence', sometimes also known as motion blur. Quote Link to comment Share on other sites More sharing options...
israelg Posted May 23, 2012 Share Posted May 23, 2012 Will we have control over the fading factor of the Phosphor ? or it will be hard-coded ? I.G Quote Link to comment Share on other sites More sharing options...
+stephena Posted May 23, 2012 Author Share Posted May 23, 2012 The fading factor is the blend level, and that is currently already configurable (and defaults to 77%). Although that brings up another issue. The current phosphor settings (whether it's enabled/disabled and the blend level) are stored in per-ROM settings. This was required in the past, since enabling phosphor for ROMs that didn't need it gave too much blur, and disabling for those that did need it resulted in too much flicker. The real problem is that the old phosphor effect is too coarse, so it needed to be specific to the ROM. The new phosphor effect really shouldn't be like that, since when you think about it, phosphor blending is a function of the TV, not the ROM! Put another way, if I enable phosphor effect at (say) level 80%, it should look fine in all types of ROMs. For those that don't have 30Hz flicker, there will be some slight smearing. And for those that do, it will greatly reduce flicker. In either case, it is exactly what a TV would output. So now I need to figure out how to deal with the settings. I would like to just kill the per-ROM settings entirely, but there's still software rendering mode (arrrgh!@#) which complicates things and necessitates keeping them around. Quote Link to comment Share on other sites More sharing options...
israelg Posted May 23, 2012 Share Posted May 23, 2012 if you want to follow mame behavior you will have a global settings for ALL games and the ability to override this setting in specific games with different values... But, global settings for all games should be fine since they all running in Atari hardware, and this is like the settings in Mess for each system, In mess you can set the values differently for each system but not for each game in this system... Don't be hard with yourself... I.G Quote Link to comment Share on other sites More sharing options...
+stephena Posted May 23, 2012 Author Share Posted May 23, 2012 I'll think a little bit more about how the settings should work. At this point I'm more concerned about the getting the effect to work correctly, and I must say that it's looking good so far. Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 23, 2012 Share Posted May 23, 2012 I have both 16:10 and 4.3 displays. 16:10 is good for technical work, data recovery ops, and watching movies only. 4:3 is for everything else including classic gaming, especially classic gaming! Regarding 16:9?? That's some kind of Hollywood thing that just happens to be the most efficient proportions when cutting the glass plates at factory where LCD's are made. I'm personally a fan of 16:10 and 4:3. With a little bit of y-positioning and y-stretching I "tuned out" the "miniature golf glitch". And in the process got it to be 100 perfect size on 4:3 LCD. It's probably my cheap-o intel graphics making the glitch in the first place.. My GeForce 4 does not show the problem. So don't make a big stink about it because I don't know what enthusiast these days is using 10 year old shit intel graphics, except for the hundreds of millions of business-class laptops and desktops. I'll have to try this out on the i7 with integrated graphics and the older 945g graphics as well. Anyhow when it comes to screen formatting it's always been a sack full of tediousness for the programmer and the end-user; both of whom have to work at it to ensure the right proportions are achieved. As far as the beta 3.7.x goes, it's so good its easy to think it's a finished product. I reviewed the documentation, btw. Briefly, back to my Miniature Golf issue and how I fixed it. A short list of settings 4:3 monitor (best CRT equivalent!) OpenGL Zoom3x Resolution Auto (or any 4:3 ratio) GL_FS_Stretch ON This gives me a perfect edge to edge image with no glitches and fills the entire screen top to bottom, left to right; provided I use the Game Properties / Display / Ystart & Yheight tweak. Demon Attack is just fine the way it is and needs no tweaks. I'm sure we could spend hours and hours tweaking each individual game to perfection, but my point is that we need the GAME PROPERTIES <<-- you need to keep them. Keep them until the PC display hardware can be made to behave exactly like a VCS + CRT combo. Quote Link to comment Share on other sites More sharing options...
