tjb Posted March 25, 2012 Share Posted March 25, 2012 Would it be possible for an Atari Jaguar controller to be modified so that it could work with an Intellivision II? I apologize ahead of time if this has been covered previously. tjb Quote Link to comment Share on other sites More sharing options...
catsfolly Posted March 25, 2012 Share Posted March 25, 2012 tjb I guess anything is "possible". It depends on how hard you want to work, and if the result is worth it to you. Here are 3 approaches: 1. Gut the controller Rip out all the electronics in the Jaguar controller and replace them with your own electronics that duplicate the Intellivisions button matrix. The result would be an intellivision controller that only supported 8 directions. If the buttons are built in to the Jaguar circuit board, you would have to either cut the circuit traces or provide new buttons. In that case the Jaguar only contributes a plastic button holder to the project. 2. Internal circuit board Some guy made a micro controller add in board that made the Jaguar controller work with usb. http://raphnet.net/e...sb/index_en.php The problem with this sort of solution is that the micro controllers need power, and no power is supplied to the Intellivision controller. 3. External adapter An external Jaguar controller to Intellivision 2 adapter could be built, but this would also require a power source. This approach would require the least amount of physical hacking, and the controller could easily be replaced if it wore out. Does this help? catsfolly Quote Link to comment Share on other sites More sharing options...
