itaych Posted May 17, 2012 Author Share Posted May 17, 2012 Fox-1: In MyDOS, the aux1 value determines whether it'll just load or also init and/or run the binary code. In Sparta it seems that the only accepted value for aux1 is 4 (both init and run) and other values just cause an error. If you could find a way to load without running it might solve the problem - I'd JSR to the init address from within my code and hope that Sparta will resume loading Ice-T afterwards. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted May 17, 2012 Share Posted May 17, 2012 XIO 40,#1,4,0,"D1:RS232.COM" should be the way to do it. 40 = Binary File Load #1 = IOCB (any except "0" should do) 4 = Open for read 0 = RUN/INIT flag. If <128 then RUN/INIT vectors will be used Is this the way you do it right now? Quote Link to comment Share on other sites More sharing options...
itaych Posted May 17, 2012 Author Share Posted May 17, 2012 This is what I do, and as you can see it works - the only problem being that DOS forgets that it was in the middle of loading Ice-T. One thing I will try is setting 128 in aux2, doing the JSR to the R: handler myself, and hoping that doesn't break the Ice-T load process. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted May 17, 2012 Share Posted May 17, 2012 It's surely worth a try. I just tried to load the things from a batch file and that works. If I load "RVERTER.HND" (original file name, no RS232.COM file in directory) and then IceT from a batch file it starts up the right way. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 17, 2012 Share Posted May 17, 2012 Calling CIO binary load from inside a DOS binary load??? I'd suggest a (fairly simple) custom loader which simply reads the handler file segments, calls the init, etc, and then returns control to DOS. Certainly it would be more conventional to install the RS232 handler from DOS. Quote Link to comment Share on other sites More sharing options...
itaych Posted May 17, 2012 Author Share Posted May 17, 2012 Ahh, but conventionality belongs to yesterday... at least on MyDOS, where this trick works. No luck with Sparta though, setting icaux2 to 128 indeed causes the R: handler code not to run, but does not prevent the original file load from being lost. That is, even if I JSR to the RS232 init routine then RTS, it drops back to DOS and doesn't resume loading Ice-T. I am simply going to disable this feature in Sparta and recommend the batch file solution unless there's anything I missed. And no I am not going to implement a binary file loader, it's reinventing the wheel and not worth the effort. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 17, 2012 Share Posted May 17, 2012 Ahh, but conventionality belongs to yesterday... at least on MyDOS, where this trick works. No luck with Sparta though, setting icaux2 to 128 indeed causes the R: handler code not to run, but does not prevent the original file load from being lost. That is, even if I JSR to the RS232 init routine then RTS, it drops back to DOS and doesn't resume loading Ice-T. Yeah - I think that's more by accident than design with MyDOS. The behaviour you want sort of requires the binary loader to be re-entrant, regardless of the IOCB in use. Sparta drops back to DOS because the most "recent" binary load did exactly that (it ended with an RTS). I am simply going to disable this feature in Sparta and recommend the batch file solution unless there's anything I missed. And no I am not going to implement a binary file loader, it's reinventing the wheel and not worth the effort. Sounds sensible. It's reasonable to me to expect drivers to be loaded before the application starts up, unless said drivers are proprietary ones specific to the application - regardless of the DOS in use. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted May 17, 2012 Share Posted May 17, 2012 I am simply going to disable this feature in Sparta and recommend the batch file solution Sound like a good idea and completely in line with the Sparta-Dos guidelines. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 17, 2012 Share Posted May 17, 2012 I am simply going to disable this feature in Sparta and recommend the batch file solution Sound like a good idea and completely in line with the Sparta-Dos guidelines. Exactly. Since I run SDX on a permanently installed hard drive, I have a subdirectory in my path with a bunch of batch files. When I want to run Ice-T, I just type "-ICET" from any drive and it turns off TDLINE, loads the R: handler, then launches Ice-T. Same for many of my other apps. Quote Link to comment Share on other sites More sharing options...
Jacques Posted May 18, 2012 Share Posted May 18, 2012 @itaych Would you consider VBXE version of this great terminal? 1 Quote Link to comment Share on other sites More sharing options...
itaych Posted May 18, 2012 Author Share Posted May 18, 2012 Ok. Here is one more beta. With this version the RS232.COM will only be loaded (and suggested, if missing) under MyDOS. I think it's ready for release; if anyone thinks otherwise please let me know. icet2.74BETA3.xex Quote Link to comment Share on other sites More sharing options...
itaych Posted May 23, 2012 Author Share Posted May 23, 2012 (edited) Here's another beta. EDIT: The speed improvement is not as dramatic as I thought. Let this be a lesson to us all: never release software versions at 3 AM. Hope you enjoy regardless... Speed improvement in text rendering thanks to an idea from The Last Word. Thanks to Jon Halliday (flashjazzcat) for this one. Minor improvement to clock accuracy (NTSC only at the moment, PAL soon). Mini-DOS: Path will now accept any single-letter (or letter and number) device type, so you can use files on things like H:. Also '\' is now allowed as a directory separator. File Viewer: Fixed EOL parser, should work with Unix/Windows/ATASCII files. VT100 emulator: Minor tweaks to font. Underline now ignored for mode 3 (top half of double height row) text. Fixed a bug involving scrolling portions of the screen in boldface mode. With these fixes the VT100 'torture test' now passes. icet2.74BETA4.xex Edited May 23, 2012 by itaych 2 Quote Link to comment Share on other sites More sharing options...
w1k Posted May 23, 2012 Share Posted May 23, 2012 i trying open towel.blinkenlights.nl if its faster then beta3.. and i trying see disk directory and i was watching settings and text on BAUD RATE was unreadable.. try that url and listen disk directory.. Quote Link to comment Share on other sites More sharing options...
itaych Posted May 23, 2012 Author Share Posted May 23, 2012 w1k, please turn your computer off and leave it off for about 10 seconds between running two different beta versions. Let me know if that fixes the problem you've seen, Quote Link to comment Share on other sites More sharing options...
w1k Posted May 23, 2012 Share Posted May 23, 2012 always i using ice-t on real HW.. Quote Link to comment Share on other sites More sharing options...
Mot Posted May 23, 2012 Share Posted May 23, 2012 Sorry, I know this is not related but I could not resist Quote Link to comment Share on other sites More sharing options...
w1k Posted June 1, 2012 Share Posted June 1, 2012 idea: can you add to ice-t "save screenshot to disk" ? Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted June 1, 2012 Share Posted June 1, 2012 use the "capture" option Quote Link to comment Share on other sites More sharing options...
+Stephen Posted June 2, 2012 Share Posted June 2, 2012 idea: can you add to ice-t "save screenshot to disk" ? shift+ctrl+p is print screen. How about shift+ctrl+d for "print" to disk? Quote Link to comment Share on other sites More sharing options...
Jacques Posted September 9, 2012 Share Posted September 9, 2012 (edited) I have a problem with 2.73, real ATARI and telnetting specifically to irc.atarichat.net via APE for Windows and SIO2PC. Text on screen is broken, every letter typed in causes echo of "7" and other digits occur between what I type in (mess after every typed in letter)... Something which didn't occur when testing on ALTIRRA. Any advice? Edited September 9, 2012 by Jacques Quote Link to comment Share on other sites More sharing options...
itaych Posted September 9, 2012 Author Share Posted September 9, 2012 (edited) Jacques, this is an issue with APE's telnet client - it presents itself incorrectly as a VT-52 terminal when connecting, and there's nothing Ice-T can do to fix this. I've spoken to Steve Tucker, author of APE, and he has added an "identify as" option in the R: configuration - VT100 or ANSI should work well. The fix appears in version 3.0.8 which is available to registered users. Good luck Edited September 9, 2012 by itaych Quote Link to comment Share on other sites More sharing options...
w1k Posted September 9, 2012 Share Posted September 9, 2012 you mean something like this? latest version fixes this problem Quote Link to comment Share on other sites More sharing options...
w1k Posted September 22, 2012 Share Posted September 22, 2012 idea: can author ice-t add tool "make screenshot" ? Quote Link to comment Share on other sites More sharing options...
npturton Posted September 22, 2012 Share Posted September 22, 2012 what is this ICE t? program Quote Link to comment Share on other sites More sharing options...
itaych Posted September 22, 2012 Author Share Posted September 22, 2012 (edited) It's a rap music generator with autotune Edited September 22, 2012 by itaych 2 Quote Link to comment Share on other sites More sharing options...
