Tyleski Posted May 16, 2012 Share Posted May 16, 2012 Hello, as this is my first post, just thought I'd say I've been lurking for a while and finally realized I should make an account since I'm spending too much time here. Anyway, I picked up a couple Sega Master Systems recently and want to sell them. (I know, I know, this isn't the marketplace) I have one console that powers on, but doesn't produce a picture with the AV jack or the RF jack. Any ideas? And the other one I have has a Phaser and 3D glasses. The phaser I can't get to work with my flatscreen, but I've heard this is just a technological problem. The 3D glasses work fine, but it seems I have to stealth slide the connection into the slot as I'm getting the fun error sounds whenever I'm starting the games (Missle Defense, Space Harrier) with the glasses inside. Is this common or did I pick up a damaged system at this flea market? (Hey, either way I might just keep one to have on the shelf "for looks".) Thanks in advance. Quote Link to comment Share on other sites More sharing options...
the.golden.ax Posted May 16, 2012 Share Posted May 16, 2012 Does the system have | / || as the channel selection or 3 / 4? It may be pal. Quote Link to comment Share on other sites More sharing options...
Tyleski Posted May 16, 2012 Author Share Posted May 16, 2012 Both have 3/4. Both model 3010. Quote Link to comment Share on other sites More sharing options...
jferio Posted May 16, 2012 Share Posted May 16, 2012 Check the cables. A Model 1 Genesis (volume control model) uses the same AV and RF cables, it can be used as a troubleshooting test to see if the cables are still good. You might also try another power supply on both units. The Model 1 Genesis power supply should be usable on the Master System. Quote Link to comment Share on other sites More sharing options...
Tyleski Posted May 17, 2012 Author Share Posted May 17, 2012 I have tested both cables. They power on my second unit, and it plays. The faulty unit powers on, but doesn't put a picture on the screen. Quote Link to comment Share on other sites More sharing options...
+thegoldenband Posted May 18, 2012 Share Posted May 18, 2012 Does the faulty unit play the "Sega" chime? I assume so, but just checking. Nice find on picking up a SMS set with the glasses, those are great! Quote Link to comment Share on other sites More sharing options...
