boxpressed Posted May 22, 2012 Share Posted May 22, 2012 I just came to the conclusion that 5200 Berzerk is worth owning this system for. It is really tough -- sometimes I can't break 2,000! The speech really makes this version special -- I do freak out a little bit knowing that Otto could be coming from any direction. The pause just makes it more suspenseful. If you've got Berzerk, break it out along with a digital joystick if you have one. 1 Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted May 22, 2012 Share Posted May 22, 2012 Yeah? I might give it a try. I know Game Over always has a copy sitting in a case. Quote Link to comment Share on other sites More sharing options...
boxpressed Posted May 22, 2012 Author Share Posted May 22, 2012 (edited) I played a little of 2600 Berzerk -- just the default game with "B" difficulty -- and it felt as though I could play for an hour if I wanted to (I know I probably couldn't). I'm not kidding you -- I'm a pretty decent twitch player, and some games of 5200 Berzerk last only a couple of minutes. I've only played a few dozen times, but still. It's still very fair and very risk-rewardy. Edited May 22, 2012 by boxpressed 1 Quote Link to comment Share on other sites More sharing options...
fernando marrin Posted May 22, 2012 Share Posted May 22, 2012 I played a little of 2600 Berzerk -- just the default game with "B" difficulty -- and it felt as though I could play for an hour if I wanted to (I know I probably couldn't). I'm not kidding you -- I'm a pretty decent twitch player, and some games of 5200 Berzerk last only a couple of minutes. I've only played a few dozen times, but still. It's still very fair and very risk-rewardy. yep, one of the 5200 gems Quote Link to comment Share on other sites More sharing options...
+FujiSkunk Posted May 22, 2012 Share Posted May 22, 2012 I played a little of 2600 Berzerk -- just the default game with "B" difficulty -- and it felt as though I could play for an hour if I wanted to (I know I probably couldn't). I'm not kidding you -- I'm a pretty decent twitch player, and some games of 5200 Berzerk last only a couple of minutes. I've only played a few dozen times, but still. It's still very fair and very risk-rewardy. The default 2600 game doesn't have Evil Otto. That together with the robots never firing diagonally and never occupying the same space horizontally makes the 2600 version relatively easy to master. Still fun, but quite not the melee that the arcade and 5200 versions can be. Quote Link to comment Share on other sites More sharing options...
NE146 Posted May 22, 2012 Share Posted May 22, 2012 I played a little of 2600 Berzerk -- just the default game with "B" difficulty -- and it felt as though I could play for an hour if I wanted to (I know I probably couldn't). I'm not kidding you -- I'm a pretty decent twitch player, and some games of 5200 Berzerk last only a couple of minutes. I've only played a few dozen times, but still. It's still very fair and very risk-rewardy. That's the problem.. you played the default. The ONLY way to play 2600 Berzerk is game variation 3, 6, or 9. But as said, 2600 Berzerk the robots cannot shoot diagonally.. so it's easy to use to your advantage. Also, Evil Otto is slow running upwards so you can just keep running to the up exit and it makes it a lot easier. Still a great translation though.. I played it a ton as a kid. But yes it does not hold a candle to the true-to-life arcade difficulty of the 5200 version. Quote Link to comment Share on other sites More sharing options...
boxpressed Posted May 22, 2012 Author Share Posted May 22, 2012 Why the 2600 version seemed so easy makes sense now! My high score on 5200 Berzerk is still only 4380. It's pretty nerve wracking materializing at the start of a level. You have about a half second to react to the placement of the robots before one fires at you -- often at close range. There's a lot more running and less shooting in 5200 Berzerk. I figured out that the good mazes give you access to the middle of the screen. If you're in the middle, you can outrun Otto. If you're close to the edge without an exit, you're in big trouble. Quote Link to comment Share on other sites More sharing options...
NE146 Posted May 22, 2012 Share Posted May 22, 2012 Why the 2600 version seemed so easy makes sense now Yes.. no Evil Otto makes for a dull Berzerk. On that note, I don't believe the difficulty switches (A/B) do anything for the game. But my memory may be bad. Quote Link to comment Share on other sites More sharing options...
Crazy Climber Posted May 22, 2012 Share Posted May 22, 2012 videogamecritic likes it http://videogamecritic.net/5200ae.htm#Berzerk I should get a 5200 one of these days... Quote Link to comment Share on other sites More sharing options...
boxpressed Posted May 22, 2012 Author Share Posted May 22, 2012 videogamecritic likes it http://videogamecrit...0ae.htm#Berzerk I should get a 5200 one of these days... I'm glad I'm not the only one who thinks it's difficult. It got a B+ from VGC, who said control suffered with the analog controller. I wonder what it would get with a digital controller. A+ game in my book. Quote Link to comment Share on other sites More sharing options...
BillyHW Posted May 23, 2012 Share Posted May 23, 2012 I recently experienced 5200 Berzerk because of the high score club. I agree that it's a well done game, and the voices are great, the pause does not detract from the game at all. But I was playing on an Xbox controller. Not sure how it would work with the stock controllers. If you guys like Berzerk on 5200 you should really check out Frenzy on ColecoVision. There aren't any voices, but these are replaced with an excellent soundtrack. There is also the Frantic homebrew (unfinished) which takes the game concept to the next level. They are both very worth sequels. Quote Link to comment Share on other sites More sharing options...
fernando marrin Posted May 23, 2012 Share Posted May 23, 2012 I recently experienced 5200 Berzerk because of the high score club. I agree that it's a well done game, and the voices are great, the pause does not detract from the game at all. But I was playing on an Xbox controller. Not sure how it would work with the stock controllers. If you guys like Berzerk on 5200 you should really check out Frenzy on ColecoVision. There aren't any voices, but these are replaced with an excellent soundtrack. There is also the Frantic homebrew (unfinished) which takes the game concept to the next level. They are both very worth sequels. Frantic is amazing, can't believe it's the 2600 Quote Link to comment Share on other sites More sharing options...
Crazy Climber Posted May 23, 2012 Share Posted May 23, 2012 videogamecritic likes it http://videogamecrit...0ae.htm#Berzerk I should get a 5200 one of these days... I'm glad I'm not the only one who thinks it's difficult. It got a B+ from VGC, who said control suffered with the analog controller. I wonder what it would get with a digital controller. A+ game in my book. He is pretty tough on hard games so B+ coming from him is pretty damn good Quote Link to comment Share on other sites More sharing options...
BillyHW Posted May 23, 2012 Share Posted May 23, 2012 I recently experienced 5200 Berzerk because of the high score club. I agree that it's a well done game, and the voices are great, the pause does not detract from the game at all. But I was playing on an Xbox controller. Not sure how it would work with the stock controllers. If you guys like Berzerk on 5200 you should really check out Frenzy on ColecoVision. There aren't any voices, but these are replaced with an excellent soundtrack. There is also the Frantic homebrew (unfinished) which takes the game concept to the next level. They are both very worth sequels. Frantic is amazing, can't believe it's the 2600 Haven't played it on the 2600. I was talking about the ColecoVision homebrew. Quote Link to comment Share on other sites More sharing options...
fernando marrin Posted May 23, 2012 Share Posted May 23, 2012 I recently experienced 5200 Berzerk because of the high score club. I agree that it's a well done game, and the voices are great, the pause does not detract from the game at all. But I was playing on an Xbox controller. Not sure how it would work with the stock controllers. If you guys like Berzerk on 5200 you should really check out Frenzy on ColecoVision. There aren't any voices, but these are replaced with an excellent soundtrack. There is also the Frantic homebrew (unfinished) which takes the game concept to the next level. They are both very worth sequels. Frantic is amazing, can't believe it's the 2600 Haven't played it on the 2600. I was talking about the ColecoVision homebrew. http://www.youtube.com/watch?v=wRxdl2T8nlQ Quote Link to comment Share on other sites More sharing options...
BillyHW Posted May 23, 2012 Share Posted May 23, 2012 I recently experienced 5200 Berzerk because of the high score club. I agree that it's a well done game, and the voices are great, the pause does not detract from the game at all. But I was playing on an Xbox controller. Not sure how it would work with the stock controllers. If you guys like Berzerk on 5200 you should really check out Frenzy on ColecoVision. There aren't any voices, but these are replaced with an excellent soundtrack. There is also the Frantic homebrew (unfinished) which takes the game concept to the next level. They are both very worth sequels. Frantic is amazing, can't believe it's the 2600 Haven't played it on the 2600. I was talking about the ColecoVision homebrew. http://www.youtube.com/watch?v=wRxdl2T8nlQ Yeah, looks good. Here is the ColecoVision homebrew I was talking about: http://www.atariage.com/forums/topic/123932-for-the-colecovision-frantic/ You can download the rom on that thread. You can also find the ColecoVision Frenzy rom just about anywhere since it was a commercial release. Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted May 23, 2012 Share Posted May 23, 2012 (edited) Berzerk's one of my favs on the 5200! Love the gameplay and voice! One of the main reasons I got back into the 5200. And back when it came out I remember being totally amazed at the voice, perfect for the game. Edited May 23, 2012 by thegamezmaster Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted May 23, 2012 Share Posted May 23, 2012 5200 Berzerk is fantastic. One of the top games for the system IMO. I however like to turn to voice off. Its cool to hear now and then but I think it makes going from level to level take too long. 2 Quote Link to comment Share on other sites More sharing options...
NE146 Posted May 23, 2012 Share Posted May 23, 2012 And just for the record (although I'm sure most here know) there is the 2600 version with voice as well. Pretty amazing. Quote Link to comment Share on other sites More sharing options...
captcapcom Posted May 24, 2012 Share Posted May 24, 2012 Ordered a Copy on Amazon last night ... Can't wait until it gets here! Quote Link to comment Share on other sites More sharing options...
R.O.T.S Posted June 4, 2012 Share Posted June 4, 2012 I agree Berzerk is a real good conversion,not just on the 5200 but also the 2600 and Atari 8-bit computers ,it gets pretty tough later and you find yourself running more than fighting lol Quote Link to comment Share on other sites More sharing options...
Chris-in-NJ Posted June 12, 2012 Share Posted June 12, 2012 Connected my 5200 last night and played a few games of Berzerk. I'm lucky enough to have a Redemption, and scored 7990 on my second game in over a year. My 9-year-old niece started out by heaping scorn on the cheap-looking graphics, but a few minutes of watching me play won her over and she wanted to try it herself. Her mom came by and she had to leave, however. Before this I'd played one game of Millipede, and got nearly 330,000. Now I know why the 7800 sticks are called "pain lines". Quote Link to comment Share on other sites More sharing options...
BrutallyHonestGamer Posted July 7, 2012 Share Posted July 7, 2012 With as good as the voices sounded I'm surprised that this game and Real Sports Baseball are the only 2 games that have voice in them. Shame. But yes I also agree 5200 Berzerk is awesome. Quote Link to comment Share on other sites More sharing options...
metzger130 Posted July 22, 2012 Share Posted July 22, 2012 5200 Berzerk is fun to play, but so much harder then the 2600 version. I get about 2000 on the 5200 version and am out of lives. 2600 I get a lot higher then that. I know everyone says evil otto is part of the game, but I wish there was a way to turn him off in the 5200 like the 2600 so I could play and get used to the difficulty and then add that smiley ball off death coming at me. Quote Link to comment Share on other sites More sharing options...
