awjg86 Posted June 2, 2012 Share Posted June 2, 2012 apologies if this has already been posted, just got my fb3 and quite eager to give it a blast, hooked it up to my tv, switched it on(at least I hope i did, not much sign of life) and no picture or sound.......advice? Quote Link to comment Share on other sites More sharing options...
toiletunes Posted June 3, 2012 Share Posted June 3, 2012 1: verify everything is hooked up, plugged in, and turned on. Make sure you're set to the right tv setting, make sure you don't have the audio cable plugged into the video slot. 2: Isolate the problem- try hooking up to a different tv, or hooking something else up to the tv inputs. 3: return / exchange the fb3 to the nearest walmart. Quote Link to comment Share on other sites More sharing options...
Csonicgo Posted June 3, 2012 Share Posted June 3, 2012 If you're not getting the color bar startup, then, I can say your FB3 is DOA. Quote Link to comment Share on other sites More sharing options...
awjg86 Posted June 4, 2012 Author Share Posted June 4, 2012 I got it from ebay tbh, but nothing on the listing suggested it was faulty, I have messaged the seller so we'll see. failing that I may as well buy an ACTUAL atari hadn't I Quote Link to comment Share on other sites More sharing options...
MIKE5200 Posted September 26, 2012 Share Posted September 26, 2012 I'm taken mine back because of the reset button the afew games won't start at all. I did notice that it says 480i SD when you start it. Quote Link to comment Share on other sites More sharing options...
