SeaGtGruff Posted July 8, 2012 Share Posted July 8, 2012 There is another approach you might try. rand MOD 6 is a fairly good distribution. I wrote some code to find this using divison by 6 to get the whole number, then multiplication by 6 followed by subtraction to get the remainder. I then increased it by 1 to get a number of 1 to 6. It is slower than using a look up table of course, but it saves bytes and is faster than the worse time case of looped division. So it is a medium length time/bytes approach to try and get the most bang for the buck. Try it out. Thanks for the code. Division by N-- or a mod N function-- is the solution I generally prefer, whether by actual division, repeated subtraction, or (in a higher language) an actual MOD function call. If I remember correctly, bB's division routine does save the remainder in one of the temp variables (I forget which one), so you can also use that as a sort of built-in mod function. The reason I decided to try a lookup table was for speed, and then I thought of using two different tables so the three extra values from each table could make use of the extra values and still get an even distribution. It does require a bit more ROM, but I think ROM is cheaper to come by than cycles-- unless you're writing a 2K or 4K game. It would be nice to do an analysis of different methods to document the average cycles used (as well as min and max cycles used), plus the distribution for each value. If I remember correctly, this has been discussed before in other threads, but I don't know if anyone ever collected it all into an actual document for reference purposes. I need to go back and look at the rand16 option again, because I forget the details of which values it produces (0 to 255, or just 1 to 255 as rand does), plus how many calls it takes for the "random" sequence to start repeating itself. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted July 8, 2012 Share Posted July 8, 2012 I noticed when I used AND with rand instead of dividing, the distribution was very uneven. When I switched to dividing or a mix of AND and dividing, the distribution became more even. For example, instead of using something like a = (rand&3) + (rand&1) + (rand&1), I had to use something like a = (rand/64) + (rand&1) + (rand/128). I would have thought that AND gives pretty good results, at least if you're using it by itself (i.e., not combining it with addition). But yes, if you add multiple AND values together then it would throw off the distribution. I wonder if the distribution might be better if you use just one call to rand-- something like this? a=rand b=(a&3)+(a&4)/4+(a&8)/8 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted July 8, 2012 Share Posted July 8, 2012 (edited) I need to go back and look at the rand16 option again, because I forget the details of which values it produces (0 to 255, or just 1 to 255 as rand does), plus how many calls it takes for the "random" sequence to start repeating itself. If it is a LFSR then it should never use zero, as it would get stuck at zero. I did a second attempt, and it's much better. I remembered the old fast divide by 3 code from an apple magazine. It was easy to make it divide by six, and I also simplified the multiplication. In short there are no branches now, so it always takes 65 cycles and 41 bytes. You could probably lose more cycles by merging it with the rand routine. Here it is: a = rand ASM ;this routine takes any number 1 to 255, do MOD 6, add 1 ;produces a value 1 to 6 ;requires 65 cycles, 41 bytes lda a ; holds rand value, 1 to 255 ;unsigned division by six sta tempOne lsr lsr adc tempOne ror lsr adc tempOne ror lsr adc tempOne ror lsr adc tempOne ror and #$FC ; clears carry on the LSR lsr ;at this point we have the whole number from division by six << 1 ;now do multiplication by six sta tempOne adc tempOne adc tempOne sbc #0 ; decrease value by 1, so remainder range will be 1 to 6 sta tempOne ;finally, find the remainder... lda a ; holds 1 to 255 sec sbc tempOne sta a ; now holds 1 to 6 END Edit: shortened the code, at 65 cycles and 41 bytes now! Edited July 8, 2012 by Omegamatrix Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted July 8, 2012 Share Posted July 8, 2012 (edited) Instead of assembly voodoo (because I don't know how) I usually mix in other game variables. Sometimes I call the rand function once per game, stuff it into a variable named gameseed and just shift around bits using existing variables. Check out how I change the color of a dungeon level in Destiny: change_dungeon_color tempvar{1} = dungeonlvl{1} tempvar{2} = 1 rem Setting bits 2 and 3 to 1 keeps things bright tempvar{3} = 1 tempvar{4} = gameseed{5} tempvar{5} = dungeonlvl{0} tempvar{6} = gameseed{1} tempvar{7} = dungeonlvl{1} tempvar ends up with a nice playfield color due to a bit of bitshifting instead of constantly calling a rand function. Real randomness usually means complicated code. The trick is to make things seem random enough to the player without committing to complicated code. Mixing in game variables and bitshifting is one answer. Another technique is to mix in a timer/counter variable. At the top of the main game loop I have something like: counter = counter + 1 You can insert various bits from that counter variable to make your bit-shifting based randomizer seem more random. Edited July 8, 2012 by theloon Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted July 8, 2012 Share Posted July 8, 2012 If it is a LFSR then it should never use zero, as it would get stuck at zero. I modified my program to use rand16 again, and to stop rolling the dice as soon as either one is 96 (the opcode for RTS, which is the 0 byte value for table0). I also removed the update to the counter so it rolls the dice on every frame to speed up the process. Sometimes it hits 96 right away, and sometimes it runs for a bit before hitting 96, but it does hit 96 eventually, which means the rand function returned a value of 0: rem * generate a random number from 1 to 6 with equal chances dim die1 = a dim die2 = b dim roll1 = c dim roll2 = d dim counter = e dim rand16 = f rem * roll1 and roll2 are used to track whether to use table0 or rem * table1 when looking up the mod 6 value for die1 and die2 scorecolor=$14 loop if counter = 0 then gosub rolldice loop2 drawscreen if die1=96 then goto loop2 if die2=96 then goto loop2 rem counter=counter+1:counter=counter&63 goto loop rolldice rem * roll the first die temp1=rand roll1=roll1^1 if roll1=0 then die1=table0[temp1] else die1=table1[temp1] rem * roll the second die temp1=rand roll2=roll2^1 if roll2=0 then die2=table0[temp1] else die2=table1[temp1] score=0 for temp1=1 to die1:score=score+1000:next for temp1=1 to die2:score=score+1:next scorecolor=scorecolor+128 asm table0 rts byte 1,2 table1 byte 3,4,5,6,1,2,3,4,5,6,1,2,3,4,5,6 byte 1,2,3,4,5,6,1,2,3,4,5,6,1,2,3,4 byte 5,6,1,2,3,4,5,6,1,2,3,4,5,6,1,2 byte 3,4,5,6,1,2,3,4,5,6,1,2,3,4,5,6 byte 1,2,3,4,5,6,1,2,3,4,5,6,1,2,3,4 byte 5,6,1,2,3,4,5,6,1,2,3,4,5,6,1,2 byte 3,4,5,6,1,2,3,4,5,6,1,2,3,4,5,6 byte 1,2,3,4,5,6,1,2,3,4,5,6,1,2,3,4 byte 5,6,1,2,3,4,5,6,1,2,3,4,5,6,1,2 byte 3,4,5,6,1,2,3,4,5,6,1,2,3,4,5,6 byte 1,2,3,4,5,6,1,2,3,4,5,6,1,2,3,4 byte 5,6,1,2,3,4,5,6,1,2,3,4,5,6,1,2 byte 3,4,5,6,1,2,3,4,5,6,1,2,3,4,5,6 byte 1,2,3,4,5,6,1,2,3,4,5,6,1,2,3,4 byte 5,6,1,2,3,4,5,6,1,2,3,4,5,6,1,2 byte 3,4,5,6,1,2,3,4,5,6,1,2,3,4,5,6 end Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted July 8, 2012 Share Posted July 8, 2012 If it is a LFSR then it should never use zero, as it would get stuck at zero. I modified my program to use rand16 again, and to stop rolling the dice as soon as either one is 96 (the opcode for RTS, which is the 0 byte value for table0). I also removed the update to the counter so it rolls the dice on every frame to speed up the process. Sometimes it hits 96 right away, and sometimes it runs for a bit before hitting 96, but it does hit 96 eventually, which means the rand function returned a value of 0: Was the seed for the LFSR 0? This is what I mean Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted July 8, 2012 Share Posted July 8, 2012 Here's a simpler test. If you take out the dim the screen will always be green. If you include the dim the screen will eventually turn red. If you include the dim but take out the second if then screen will flash red every so often and then go back to green. This indicates that using rand16 does return a value of 0 every now and then. rem * rand 0? dim rand16 = b loop a=rand if a=0 then COLUBK=$44 else COLUBK=$C4 loop2 drawscreen if a=0 then loop2 goto loop Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted July 8, 2012 Share Posted July 8, 2012 (edited) How about leaving rand out of it altogether? set smartbranching on set romsize 16k set kernel_options no_blank_lines dim counter = a dim randval = b scorecolor = $0E main if joy0fire then gosub rscore drawscreen goto main rscore randval = randval + counter + randval score = 0 : score = score + randval return vblank counter = counter + 1 return Edited July 8, 2012 by theloon Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted July 8, 2012 Share Posted July 8, 2012 I took a look and found the rand routine in std_routines.asm randomize lda rand lsr ifconst rand16 rol rand16 endif bcc noeor eor #$B4 noeor sta rand ifconst rand16 eor rand16 endif RETURN So rand16 seems to be using 2 zero page ram locations. I am assuming rand16 is a variable simply because it begins in lowercase, and hoping that it is following convention. But I looked in 2600basic.h and only found rand set to address $A2. I can't find where rand16 is yet. Anyhow maybe the modified code for using rand16 was to allow for a zero to be produced from time to time? It makes sense that way. Quote Link to comment Share on other sites More sharing options...
RevEng Posted July 8, 2012 Share Posted July 8, 2012 On rand16...Its the user's choice to define the memory location in their bB code. If they don't, bB uses an 8-bit LFSR. If they do, bB uses a 16-bit LFSR. The rand command returns the lower byte of the LFSR, if its 16-bit. That's why its often zero.(The higher byte won't be zero at the same time) Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted July 8, 2012 Share Posted July 8, 2012 I took a look at rand (but not rand16), and ran through all the combinations in excel. If rand is seeded with zero, it will be permanently stuck at zero. This is as I expected. Any other number (1 to 255) will produce a different number. All numbers (1 to 255) eventually get produced by rand. seed ==> output from rand 0 ==> 0 1 ==> 180 2 ==> 1 3 ==> 181 4 ==> 2 5 ==> 182 6 ==> 3 7 ==> 183 8 ==> 4 9 ==> 176 10 ==> 5 11 ==> 177 12 ==> 6 13 ==> 178 14 ==> 7 15 ==> 179 16 ==> 8 17 ==> 188 18 ==> 9 19 ==> 189 20 ==> 10 21 ==> 190 22 ==> 11 23 ==> 191 24 ==> 12 25 ==> 184 26 ==> 13 27 ==> 185 28 ==> 14 29 ==> 186 30 ==> 15 31 ==> 187 32 ==> 16 33 ==> 164 34 ==> 17 35 ==> 165 36 ==> 18 37 ==> 166 38 ==> 19 39 ==> 167 40 ==> 20 41 ==> 160 42 ==> 21 43 ==> 161 44 ==> 22 45 ==> 162 46 ==> 23 47 ==> 163 48 ==> 24 49 ==> 172 50 ==> 25 51 ==> 173 52 ==> 26 53 ==> 174 54 ==> 27 55 ==> 175 56 ==> 28 57 ==> 168 58 ==> 29 59 ==> 169 60 ==> 30 61 ==> 170 62 ==> 31 63 ==> 171 64 ==> 32 65 ==> 148 66 ==> 33 67 ==> 149 68 ==> 34 69 ==> 150 70 ==> 35 71 ==> 151 72 ==> 36 73 ==> 144 74 ==> 37 75 ==> 145 76 ==> 38 77 ==> 146 78 ==> 39 79 ==> 147 80 ==> 40 81 ==> 156 82 ==> 41 83 ==> 157 84 ==> 42 85 ==> 158 86 ==> 43 87 ==> 159 88 ==> 44 89 ==> 152 90 ==> 45 91 ==> 153 92 ==> 46 93 ==> 154 94 ==> 47 95 ==> 155 96 ==> 48 97 ==> 132 98 ==> 49 99 ==> 133 100 ==> 50 101 ==> 134 102 ==> 51 103 ==> 135 104 ==> 52 105 ==> 128 106 ==> 53 107 ==> 129 108 ==> 54 109 ==> 130 110 ==> 55 111 ==> 131 112 ==> 56 113 ==> 140 114 ==> 57 115 ==> 141 116 ==> 58 117 ==> 142 118 ==> 59 119 ==> 143 120 ==> 60 121 ==> 136 122 ==> 61 123 ==> 137 124 ==> 62 125 ==> 138 126 ==> 63 127 ==> 139 128 ==> 64 129 ==> 244 130 ==> 65 131 ==> 245 132 ==> 66 133 ==> 246 134 ==> 67 135 ==> 247 136 ==> 68 137 ==> 240 138 ==> 69 139 ==> 241 140 ==> 70 141 ==> 242 142 ==> 71 143 ==> 243 144 ==> 72 145 ==> 252 146 ==> 73 147 ==> 253 148 ==> 74 149 ==> 254 150 ==> 75 151 ==> 255 152 ==> 76 153 ==> 248 154 ==> 77 155 ==> 249 156 ==> 78 157 ==> 250 158 ==> 79 159 ==> 251 160 ==> 80 161 ==> 228 162 ==> 81 163 ==> 229 164 ==> 82 165 ==> 230 166 ==> 83 167 ==> 231 168 ==> 84 169 ==> 224 170 ==> 85 171 ==> 225 172 ==> 86 173 ==> 226 174 ==> 87 175 ==> 227 176 ==> 88 177 ==> 236 178 ==> 89 179 ==> 237 180 ==> 90 181 ==> 238 182 ==> 91 183 ==> 239 184 ==> 92 185 ==> 232 186 ==> 93 187 ==> 233 188 ==> 94 189 ==> 234 190 ==> 95 191 ==> 235 192 ==> 96 193 ==> 212 194 ==> 97 195 ==> 213 196 ==> 98 197 ==> 214 198 ==> 99 199 ==> 215 200 ==> 100 201 ==> 208 202 ==> 101 203 ==> 209 204 ==> 102 205 ==> 210 206 ==> 103 207 ==> 211 208 ==> 104 209 ==> 220 210 ==> 105 211 ==> 221 212 ==> 106 213 ==> 222 214 ==> 107 215 ==> 223 216 ==> 108 217 ==> 216 218 ==> 109 219 ==> 217 220 ==> 110 221 ==> 218 222 ==> 111 223 ==> 219 224 ==> 112 225 ==> 196 226 ==> 113 227 ==> 197 228 ==> 114 229 ==> 198 230 ==> 115 231 ==> 199 232 ==> 116 233 ==> 192 234 ==> 117 235 ==> 193 236 ==> 118 237 ==> 194 238 ==> 119 239 ==> 195 240 ==> 120 241 ==> 204 242 ==> 121 243 ==> 205 244 ==> 122 245 ==> 206 246 ==> 123 247 ==> 207 248 ==> 124 249 ==> 200 250 ==> 125 251 ==> 201 252 ==> 126 253 ==> 202 254 ==> 127 255 ==> 203 Quote Link to comment Share on other sites More sharing options...
bogax Posted July 8, 2012 Share Posted July 8, 2012 (edited) a=rand/2 a=(a/2 + a)/4/4/2+1 produces .L00 ; a = rand / 2 jsr randomize lsr STA a .L01 ; a = ( a / 2 + a ) / 4 / 4 / 2 + 1 ; complex statement detected LDA a lsr CLC ADC a lsr lsr lsr lsr lsr CLC ADC #1 STA a . ; or in assembly a=rand asm lda a lsr adc a and #$C0 rol rol rol adc #$01 sta a end Edited July 8, 2012 by bogax Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted July 8, 2012 Share Posted July 8, 2012 Okay, third try. I've gone after MOD 6 plus 1 directly, and had great success. It takes a lot less cycles now, and I have combined the rand call in it too. So... I've attempted to make a stand alone library called doDiceRoll, which returns a value 1 to 6. I'm not sure if I got the integration syntax right for BB, but lets see! In theory you should be able to add the library and just do a simple call like: a = doDiceRoll The code itself looks like this: doDiceRoll ;perform rand lda $A2 ; load rand lsr bcc .noeor eor #$B4 .noeor: sta $A2 ; rand is updated ;find MOD 6 plus 1 and #$30 lsr lsr sta temp1 lda $A2 and #$0F adc temp1 tay lda remainderTable,Y RETURN remainderTable: .byte 1,2,3,4,5,6 .byte 1,2,3,4,5,6 .byte 1,2,3,4,5,6 .byte 1,2,3,4,5,6 .byte 1,2,3,4 I've using temp1, and I'm also using the Y register, so I don't know if that will mess with anything. Another thought is It would be simple to also do a different table of values 0 to 5, and have a constant to switch in-between. Or maybe you could just do: a = doDiceRoll - 1 Anyhow, and testers out there? diceRoll.asm Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted July 8, 2012 Share Posted July 8, 2012 Also for distribution, the possible seed values are 1 to 255, which gives: dice number 6 | 5 | 4 | 3 | 2 | 1 | ------------------------------------------- occurrence 42 | 42 | 43 | 43 | 43 | 42 | Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted July 8, 2012 Share Posted July 8, 2012 a=rand/2 a=(a/2 + a)/4/4/2+1 Thanks, bogax! If I figured it correctly in Excel, the distribution for bB's standard 8-bit rand function is as follows: 1 = 43 (rand = 1 through 43) 2 = 42 (rand = 44 through 85) 3 = 42 (rand = 86 through 127) 4 = 44 (rand = 128 through 171) 5 = 42 (rand = 172 through 213) 6 = 42 (rand = 214 through 255) Quote Link to comment Share on other sites More sharing options...
RevEng Posted July 8, 2012 Share Posted July 8, 2012 It works well, Omega. Here's a minimal bB program that shows how to use the function. It updates the last score digit with the results of the function once a frame... dim sc2=score+2 scorecolor=$0f mainloop sc2=doDiceRoll() drawscreen goto mainloop include diceRoll.asm Also, its better to reference the "rand" label in your function rather than directly using $A2. In the multisprite kernel, rand is $D6 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted July 8, 2012 Share Posted July 8, 2012 (edited) a=rand/2 a=(a/2 + a)/4/4/2+1 produces .L00 ; a = rand / 2 jsr randomize lsr STA a .L01 ; a = ( a / 2 + a ) / 4 / 4 / 2 + 1 ; complex statement detected LDA a lsr CLC ADC a lsr lsr lsr lsr lsr CLC ADC #1 STA a . ; or in assembly a=rand asm lda a lsr adc a and #$C0 rol rol rol adc #$01 sta a end I just tried it in excel and I got a nice distribution: 6 => 43 5 => 42 4 => 43 3 => 43 2 => 42 1 => 42 Works great and a lot less bytes too. But that is for: a=rand a=(a/2 + a)/4/4/2+1 When you have rand/2 like so: a=rand/2 a=(a/2 + a)/4/4/2+1 you get: 6 => 0 5 => 0 4 => 0 3 => 86 2 => 84 1 => 85 So the good code is: a=rand asm lda a lsr adc a and #$C0 rol rol rol adc #$01 sta a end Edited July 8, 2012 by Omegamatrix Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted July 8, 2012 Share Posted July 8, 2012 Here are the values produced for each routine side by side. The number on the left is what rand produces. Then the numbers that follow are the outcomes. ---- Bogax - Omega ------------------ 255 ---- 6 ---- 4 254 ---- 6 ---- 3 253 ---- 6 ---- 2 252 ---- 6 ---- 1 251 ---- 6 ---- 6 250 ---- 6 ---- 5 249 ---- 6 ---- 4 248 ---- 6 ---- 3 247 ---- 6 ---- 2 246 ---- 6 ---- 1 245 ---- 6 ---- 6 244 ---- 6 ---- 5 243 ---- 6 ---- 4 242 ---- 6 ---- 3 241 ---- 6 ---- 2 240 ---- 6 ---- 1 239 ---- 6 ---- 6 238 ---- 6 ---- 5 237 ---- 6 ---- 4 236 ---- 6 ---- 3 235 ---- 6 ---- 2 234 ---- 6 ---- 1 233 ---- 6 ---- 6 232 ---- 6 ---- 5 231 ---- 6 ---- 4 230 ---- 6 ---- 3 229 ---- 6 ---- 2 228 ---- 6 ---- 1 227 ---- 6 ---- 6 226 ---- 6 ---- 5 225 ---- 6 ---- 4 224 ---- 6 ---- 3 223 ---- 6 ---- 2 222 ---- 6 ---- 1 221 ---- 6 ---- 6 220 ---- 6 ---- 5 219 ---- 6 ---- 4 218 ---- 6 ---- 3 217 ---- 6 ---- 2 216 ---- 6 ---- 1 215 ---- 6 ---- 6 214 ---- 6 ---- 5 213 ---- 6 ---- 4 212 ---- 5 ---- 3 211 ---- 5 ---- 2 210 ---- 5 ---- 1 209 ---- 5 ---- 6 208 ---- 5 ---- 5 207 ---- 5 ---- 4 206 ---- 5 ---- 3 205 ---- 5 ---- 2 204 ---- 5 ---- 1 203 ---- 5 ---- 6 202 ---- 5 ---- 5 201 ---- 5 ---- 4 200 ---- 5 ---- 3 199 ---- 5 ---- 2 198 ---- 5 ---- 1 197 ---- 5 ---- 6 196 ---- 5 ---- 5 195 ---- 5 ---- 4 194 ---- 5 ---- 3 193 ---- 5 ---- 2 192 ---- 5 ---- 1 191 ---- 5 ---- 6 190 ---- 5 ---- 5 189 ---- 5 ---- 4 188 ---- 5 ---- 3 187 ---- 5 ---- 2 186 ---- 5 ---- 1 185 ---- 5 ---- 6 184 ---- 5 ---- 5 183 ---- 5 ---- 4 182 ---- 5 ---- 3 181 ---- 5 ---- 2 180 ---- 5 ---- 1 179 ---- 5 ---- 6 178 ---- 5 ---- 5 177 ---- 5 ---- 4 176 ---- 5 ---- 3 175 ---- 5 ---- 2 174 ---- 5 ---- 1 173 ---- 5 ---- 6 172 ---- 5 ---- 5 171 ---- 5 ---- 4 170 ---- 4 ---- 3 169 ---- 4 ---- 2 168 ---- 4 ---- 1 167 ---- 4 ---- 6 166 ---- 4 ---- 5 165 ---- 4 ---- 4 164 ---- 4 ---- 3 163 ---- 4 ---- 2 162 ---- 4 ---- 1 161 ---- 4 ---- 6 160 ---- 4 ---- 5 159 ---- 4 ---- 4 158 ---- 4 ---- 3 157 ---- 4 ---- 2 156 ---- 4 ---- 1 155 ---- 4 ---- 6 154 ---- 4 ---- 5 153 ---- 4 ---- 4 152 ---- 4 ---- 3 151 ---- 4 ---- 2 150 ---- 4 ---- 1 149 ---- 4 ---- 6 148 ---- 4 ---- 5 147 ---- 4 ---- 4 146 ---- 4 ---- 3 145 ---- 4 ---- 2 144 ---- 4 ---- 1 143 ---- 4 ---- 6 142 ---- 4 ---- 5 141 ---- 4 ---- 4 140 ---- 4 ---- 3 139 ---- 4 ---- 2 138 ---- 4 ---- 1 137 ---- 4 ---- 6 136 ---- 4 ---- 5 135 ---- 4 ---- 4 134 ---- 4 ---- 3 133 ---- 4 ---- 2 132 ---- 4 ---- 1 131 ---- 4 ---- 6 130 ---- 4 ---- 5 129 ---- 4 ---- 4 128 ---- 4 ---- 3 127 ---- 3 ---- 2 126 ---- 3 ---- 1 125 ---- 3 ---- 6 124 ---- 3 ---- 5 123 ---- 3 ---- 4 122 ---- 3 ---- 3 121 ---- 3 ---- 2 120 ---- 3 ---- 1 119 ---- 3 ---- 6 118 ---- 3 ---- 5 117 ---- 3 ---- 4 116 ---- 3 ---- 3 115 ---- 3 ---- 2 114 ---- 3 ---- 1 113 ---- 3 ---- 6 112 ---- 3 ---- 5 111 ---- 3 ---- 4 110 ---- 3 ---- 3 109 ---- 3 ---- 2 108 ---- 3 ---- 1 107 ---- 3 ---- 6 106 ---- 3 ---- 5 105 ---- 3 ---- 4 104 ---- 3 ---- 3 103 ---- 3 ---- 2 102 ---- 3 ---- 1 101 ---- 3 ---- 6 100 ---- 3 ---- 5 -99 ---- 3 ---- 4 -98 ---- 3 ---- 3 -97 ---- 3 ---- 2 -96 ---- 3 ---- 1 -95 ---- 3 ---- 6 -94 ---- 3 ---- 5 -93 ---- 3 ---- 4 -92 ---- 3 ---- 3 -91 ---- 3 ---- 2 -90 ---- 3 ---- 1 -89 ---- 3 ---- 6 -88 ---- 3 ---- 5 -87 ---- 3 ---- 4 -86 ---- 3 ---- 3 -85 ---- 3 ---- 2 -84 ---- 2 ---- 1 -83 ---- 2 ---- 6 -82 ---- 2 ---- 5 -81 ---- 2 ---- 4 -80 ---- 2 ---- 3 -79 ---- 2 ---- 2 -78 ---- 2 ---- 1 -77 ---- 2 ---- 6 -76 ---- 2 ---- 5 -75 ---- 2 ---- 4 -74 ---- 2 ---- 3 -73 ---- 2 ---- 2 -72 ---- 2 ---- 1 -71 ---- 2 ---- 6 -70 ---- 2 ---- 5 -69 ---- 2 ---- 4 -68 ---- 2 ---- 3 -67 ---- 2 ---- 2 -66 ---- 2 ---- 1 -65 ---- 2 ---- 6 -64 ---- 2 ---- 5 -63 ---- 2 ---- 4 -62 ---- 2 ---- 3 -61 ---- 2 ---- 2 -60 ---- 2 ---- 1 -59 ---- 2 ---- 6 -58 ---- 2 ---- 5 -57 ---- 2 ---- 4 -56 ---- 2 ---- 3 -55 ---- 2 ---- 2 -54 ---- 2 ---- 1 -53 ---- 2 ---- 6 -52 ---- 2 ---- 5 -51 ---- 2 ---- 4 -50 ---- 2 ---- 3 -49 ---- 2 ---- 2 -48 ---- 2 ---- 1 -47 ---- 2 ---- 6 -46 ---- 2 ---- 5 -45 ---- 2 ---- 4 -44 ---- 2 ---- 3 -43 ---- 2 ---- 2 -42 ---- 1 ---- 1 -41 ---- 1 ---- 6 -40 ---- 1 ---- 5 -39 ---- 1 ---- 4 -38 ---- 1 ---- 3 -37 ---- 1 ---- 2 -36 ---- 1 ---- 1 -35 ---- 1 ---- 6 -34 ---- 1 ---- 5 -33 ---- 1 ---- 4 -32 ---- 1 ---- 3 -31 ---- 1 ---- 2 -30 ---- 1 ---- 1 -29 ---- 1 ---- 6 -28 ---- 1 ---- 5 -27 ---- 1 ---- 4 -26 ---- 1 ---- 3 -25 ---- 1 ---- 2 -24 ---- 1 ---- 1 -23 ---- 1 ---- 6 -22 ---- 1 ---- 5 -21 ---- 1 ---- 4 -20 ---- 1 ---- 3 -19 ---- 1 ---- 2 -18 ---- 1 ---- 1 -17 ---- 1 ---- 6 -16 ---- 1 ---- 5 -15 ---- 1 ---- 4 -14 ---- 1 ---- 3 -13 ---- 1 ---- 2 -12 ---- 1 ---- 1 -11 ---- 1 ---- 6 -10 ---- 1 ---- 5 --9 ---- 1 ---- 4 --8 ---- 1 ---- 3 --7 ---- 1 ---- 2 --6 ---- 1 ---- 1 --5 ---- 1 ---- 6 --4 ---- 1 ---- 5 --3 ---- 1 ---- 4 --2 ---- 1 ---- 3 --1 ---- 1 ---- 2 Quote Link to comment Share on other sites More sharing options...
bogax Posted July 9, 2012 Share Posted July 9, 2012 (edited) When you have rand/2 like so: a=rand/2 a=(a/2 + a)/4/4/2+1 you get: 6 => 0 5 => 0 4 => 0 3 => 86 2 => 84 1 => 85 That's odd Are you sure you didn't divide by 64? ie /4/4/4 instead of /4/4/2 ? I reckon it thusly suppose rand returns 255 then: rand/2 = 127 a/2 = 63 + a = 190 /4 = 47 /4 = 11 /2 = 5 +1 = 6 Edited July 9, 2012 by bogax Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted July 9, 2012 Share Posted July 9, 2012 That's odd Are you sure you didn't divide by 64? ie /4/4/4 instead of /4/4/2 ? You're right I missed a number somewhere. I might try to explore my own code more to see if I can come up with some more MOD routines. I think my own routine can still be more optimized. Quote Link to comment Share on other sites More sharing options...
bogax Posted July 9, 2012 Share Posted July 9, 2012 I think my own routine can still be more optimized. You could probably get by with fewer partial products in the reciprocal multiplication. Quote Link to comment Share on other sites More sharing options...
abaudrand Posted July 11, 2012 Author Share Posted July 11, 2012 ouch, so many replies... I didn't tough my little post will raise so many help thanks everyone ! Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted July 11, 2012 Share Posted July 11, 2012 We're not really helping. I'm just confusing matters and Omegamatrix is reinventing what pseudo random and modulus means by rewiring the fundamentals of mathematics. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted July 11, 2012 Share Posted July 11, 2012 Yeah, we hijacked your thread about on...gosub, and turned it into a discussion about rand and rand16. Quote Link to comment Share on other sites More sharing options...
abaudrand Posted July 12, 2012 Author Share Posted July 12, 2012 no problem, the discussion is very interesting. I ve finally understand why my dragon behavior seldom use some path. I will return to this game part once I'm done with this on gosub issue. Quote Link to comment Share on other sites More sharing options...
