+atari2600land Posted July 18, 2012 Share Posted July 18, 2012 Somehow I managed to cobble up two games, but I'm having some troubles on this one, mainly due to the fact that I can't figure out how to display just one part of a sprite. Suppose I have some code that looks like this: enemy db 01111100b db 11010110b db 11111110b db 10000010b db 11111110b db 01000100b db 01000100b db 11000110b db 01111000b db 11111110b db 11111110b db 01111100b db 00000000b db 00011110b db 00111111b db 00011110b setshape ; r0=spritepointer, r1=pointer to image in rom mov r7,#8 ; 8 bytes copyspriteloop: mov a,r1 movp a,@a ; get byte movx @r0,a inc r0 inc r1 djnz r7,copyspriteloop ret At the beginning, I called the certain shape to appear using this: mov r0,#vdc_spr2_shape mov r1,#enemy & 0ffh call setshape My question is, how would I get the next 8 lines of the sprite to appear instead of the first 8? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 18, 2012 Share Posted July 18, 2012 I don't know the Z80 equalivant to (indirect),y addressing...or much else pertaining to Z80 for that matter...but couldn't you just alter the value of r1 before entering the loop? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted August 2, 2012 Share Posted August 2, 2012 (edited) No. YOU'RE hard atari2600land. You've got the stones to persevere until it makes sense. Keep on going! Edited August 2, 2012 by theloon Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 2, 2012 Share Posted August 2, 2012 I don't know the Z80 equalivant to (indirect),y addressing...or much else pertaining to Z80 for that matter...but couldn't you just alter the value of r1 before entering the loop? Its not Z80. Its 8048 which is the CPU in the Philips G7000. My question is, how would I get the next 8 lines of the sprite to appear instead of the first 8? Try :- mov r0,#vdc_spr2_shape mov r1,#enemy+8 & 0ffh call setshape Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 5, 2012 Author Share Posted August 5, 2012 (edited) Thanks, groovybee, but I've given up on that game. It was just too hard for me to contemplate how to do other stuff. OK, well, next question. I'm working on a Freeway type game, and I was just wondering how to make a non-appearing timer like in Freeway? I struggled with this for days on end and what I've tried doesn't make any sense whatsoever. traff4.txt Edited August 5, 2012 by atari2600land Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 5, 2012 Share Posted August 5, 2012 I can't find your software timer code in that source. You aren't keeping track of either the seconds or the number of vblanks passing by. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 5, 2012 Author Share Posted August 5, 2012 There is no software timer in the code. How would I keep track of the number of vblanks? Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 5, 2012 Share Posted August 5, 2012 There is a vsyncirq in the vector table but no source code to handle it in your example. Put an increment of a RAM variable in there. When it gets to 50 or 60 (depending on TV region) then reset it back to 0 and subtract 1 from your seconds counter. When the seconds counter reaches 0 then your time has run out. With a single byte containing the seconds you can have a maximum time out of 255 seconds. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 5, 2012 Author Share Posted August 5, 2012 Why does this not work? ;timer part mov r0,#thissucks movx a,@r0 add a,#1 movx @r0,a mov r0,#thissucks movx a,@r0 xrl a,#60 jz loop_000 jmp loop_00 loop_000 call add_score mov r0,#thissucks mov @r0,#000h mov r0,#seconds movx a,@r0 add a,#0ffh movx @r0,a mov r0,#seconds movx a,@r0 xrl a,#000h jz gameover_4 jmp loop_00 gameover_4 jmp gameover loop_00 -rest of program- Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 5, 2012 Share Posted August 5, 2012 In G7000.h there are ram locations called iram_clock, eram_minutes and eram_seconds. What happens in those locations? Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 5, 2012 Author Share Posted August 5, 2012 In my code? Nothing. I didn't know they existed. How would I go about using those variables? Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 5, 2012 Share Posted August 5, 2012 You could convert them to digits and put them on screen to see if the BIOS does anything with them. Or look at them in the emulator. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 5, 2012 Author Share Posted August 5, 2012 I got it working! By the way, what's the difference between PAL and NTSC in terms of seconds? Would PAL be 50 and NTSC be 60, or PAL is 60 and NTSC is 50? traff4.txt Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 5, 2012 Share Posted August 5, 2012 PAL has 50 vblanks per second and NTSC 60. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 6, 2012 Author Share Posted August 6, 2012 Since the clock is different on different machines, can someone do a quick look at my code to see whether this would help detect whether the game is running on a PAL Videopac or an NTSC Odyssey2? traff5.txt Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 6, 2012 Author Share Posted August 6, 2012 Never mind. As someone pointed out in the other thread, and I didn't know this, the whole game would run slower, so there's no need to make the clock run slower. Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 6, 2012 Share Posted August 6, 2012 Never mind. As someone pointed out in the other thread, and I didn't know this, the whole game would run slower, so there's no need to make the clock run slower. Not true! You need to account for the difference in the number of vblanks per second. If you are counting to 60 on NTSC the clock will roll over every second as expected. If you are counting to 60 on PAL the clock will roll over every 1.2 seconds. For a 60 second time limit you get (60*60)/60 seconds running on NTSC. If you run on PAL without changing the code you'd get (60*60)/50 seconds. So PAL people would get 72 seconds to complete the same course. That wouldn't be good if the game was ever used in an international high score contest. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 7, 2012 Author Share Posted August 7, 2012 Well, then, look through this amended code and see if this would work. traff7.txt Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 10, 2012 Author Share Posted August 10, 2012 OK, I'm stumped. How do you get a number to equal another number? Say for instance, that I want sprite0x to equal char1x. How would I do this? Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 10, 2012 Share Posted August 10, 2012 You need to do the following steps: - Load a data register with the source address (the variable you want to read). - Move the contents of the address pointed to by the register into the accumulator. - Load a data register with the destination address (the variable you want to write). - Move the accumulator into the address pointed at by that register. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 10, 2012 Author Share Posted August 10, 2012 Cool, thanks, I ended up with this: mov r0,#011h movx a,@r0 mov r1,#001h movx @r1,a (In Odyssey2 assembly, #11h is char0x and #001h is sprite0x. I am still wondering what exactly @ does, though. Keep in mind I learned/ am learning how to do different things by tweaking different examples) Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 10, 2012 Share Posted August 10, 2012 I am still wondering what exactly @ does, though. It roughly means "the contents of the address". Its a bit like saying "let fred=1" in BASIC except that in the Videopac's case "1" would have moved into the accumulator first and the address of "fred" would be moved into a data register. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 10, 2012 Author Share Posted August 10, 2012 last question for a while. How would I do "if a>80 && a<88" in assembly? Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 10, 2012 Share Posted August 10, 2012 We discussed "if statements" back in February. I'm not an 8048 programmer but the code would be something like :- ; Check if val>=88 add a, #168 jc OutOfRange ; Val is in the range 0 to 87 at this point. ; You need to restore A here it was just trashed with the add. ... ; Check if val>=81 add a, #175 jnc OutOfRange ; Get here if val>80 and val<88 InRange: ; Do something because its in range... ; Jump to somewhere. ; Get here if val<=80 or val >=88 OutOfRange: ; Do something because its out of range... Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 22, 2012 Author Share Posted August 22, 2012 So then would "if a<3" would be: add a, #253 jc OutOfRange Quote Link to comment Share on other sites More sharing options...
