yell0w_lantern Posted September 1, 2012 Share Posted September 1, 2012 I was looking at using the HXC to load up Workbench on an Amiga 1200. In addition to the original disks that I could rip, I have a bunch of ADF images for workbench. There are a lot of them though and I can't tell if need them all or just certain ones. Just as an example, here are all the ADF images for disk 1 alone. Do the !, a, a2, a3 and so on just indicate different dumps so that I only need to pick one set of dumps to use or are they something else and I need them all? Workbench v3.1 rev 40.42 (1994)(Commodore)(M10)(Disk 1 of 6)(Install)[!] Workbench v3.1 rev 40.42 (1994)(Commodore)(M10)(Disk 1 of 6)(Install)[a] Workbench v3.1 rev 40.42 (1994)(Commodore)(M10)(Disk 1 of 6)(Install)[a2] Workbench v3.1 rev 40.42 (1994)(Commodore)(M10)(Disk 1 of 6)(Install)[a3] Workbench v3.1 rev 40.42 (1994)(Commodore)(M10)(Disk 1 of 6)(Install)[m drive definitions] Workbench v3.1 rev 40.42 (1994)(Commodore)(M10)(Disk 1 of 6)(Install)[m drive definitions][a] Workbench v3.1 rev 40.42 (1994)(Commodore)(M10)(Disk 1 of 6)(Install)[m] Quote Link to comment Share on other sites More sharing options...
amiman99 Posted September 2, 2012 Share Posted September 2, 2012 Check this link for details http://www.tosecdev.org/index.php/tosec-naming-convention But in a nut shell, get the [!] first then [a], not or [m] (well [m] sometimes) ! is verified good dump a is alternative dump b is bad dump m is modified dump As far as Workbench disks, you need 6 of them for HD installation. Quote Link to comment Share on other sites More sharing options...
yell0w_lantern Posted September 2, 2012 Author Share Posted September 2, 2012 (edited) Check this link for details http://www.tosecdev....ming-convention But in a nut shell, get the [!] first then [a], not or [m] (well [m] sometimes) ! is verified good dump a is alternative dump b is bad dump m is modified dump As far as Workbench disks, you need 6 of them for HD installation. Check this link for details http://www.tosecdev....ming-convention But in a nut shell, get the [!] first then [a], not or [m] (well [m] sometimes) ! is verified good dump a is alternative dump b is bad dump m is modified dump As far as Workbench disks, you need 6 of them for HD installation. Ah! Thank you very much, sir. Edited September 2, 2012 by yell0w_lantern Quote Link to comment Share on other sites More sharing options...
