tep392 Posted October 1, 2012 Share Posted October 1, 2012 Hi all, I'm looking for some help on assembly directive's for bank switched code. I'm currently using MADS. The game will be built on a 144k cart that has a 16k rom fixed at $4000 and a 128k banked rom were banks 0-6 are switched at $8000 and bank 7 is fixed at $c000. I have code in each bank and need to make subroutine calls between the fixed and switched banks. The code would look something like this. org $4000 fixed code and data in 16k rom org $8000 bank0 code and data org $8000 bank 1 code and data org $8000 remaining banks filled with $ff org $c000 fixed bank 7 code and data If I try to assemble this, I'll get "can't fill from higher memory" errors when bank 1 is assembled. Can this be done with MADS or do I need to use a different assembler? Perry Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 1, 2012 Share Posted October 1, 2012 I'm not familiar with MADS, nor am I familiar with Atari 7800 programming, but in general you can't have code that uses the same physical addresses, such as org $8000 org $8000 org $8000 When writing bank-switched games for the Atari 2600 with the DASM assembler, the normal procedure is to code the ORG addresses so they define a continuous and contiguous set of ROM banks. Note that for this purpose you can start with an ORG of $0000 if you want because the ORG addresses will define the memory within the finished ROM image file, but for the 2600 it's common to start with ORG $1000. So if you wanted to assemble a 16K ROM for the 2600, made up of four 4K banks, you could use ORG addresses like this: ORG $0000 ORG $1000 ORG $2000 ORG $3000 When it's compiled, the ROM file will be a 16K file with no "gaps" between the banks. But then you need to use RORG to relocate the code in each bank so the addresses fall within the proper area of the address space, like this: ORG $0000 RORG $9000 ORG $1000 RORG $B000 ORG $2000 RORG $D000 ORG $3000 RORG $F000 Those aren't the only RORG addresses that would work for the 2600-- you could also use RORG $1000, RORG $3000, RORG $5000, and RORG $7000, for example. For the addresses you listed, I would suggest something like this, or some equivalent with a different starting address: ORG $0000 RORG $4000 ; fixed code and data in 16k rom ORG $4000 RORG $8000 ; bank0 code and data ORG $8000 RORG $8000 ; bank 1 code and data ORG $C000 RORG $8000 ; remaining banks filled with $ff ORG $10000 RORG $8000 ; remaining banks filled with $ff ORG $14000 RORG $8000 ; remaining banks filled with $ff ORG $18000 RORG $8000 ; remaining banks filled with $ff ORG $1C000 RORG $8000 ; remaining banks filled with $ff ORG $20000 RORG $C000 ; fixed bank 7 code and data The ORG addresses would give you a 144K ROM image file, but the RORG addresses would control what addresses are used inside each bank. Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 2, 2012 Share Posted October 2, 2012 If I remember correctly, in MADS you can use ORG A,B Where A is the address it assembles to and B is the address it is assumed to be running from (I think it's that way around). I've not used Mads to recursively create banks as in your case but have used it to have code that loads in one location but is intended to run at another. It'd be a bit of a kludgy workaround but you could use the ORG A,B method to generate a banked cart image. Also note that Mads will usually generate an executable for the 8-bit computer which you don't want for carts - ideally you want a raw binary (optionally prefixed with the headers needed for some emulation filetypes) Alternatively you could use AtAsm - it has the .bank directive which allows easy creation of banked binaries - but of course it's usually easier to stick with what you started out with. Quote Link to comment Share on other sites More sharing options...
tep392 Posted October 2, 2012 Author Share Posted October 2, 2012 I figured it out. Thanks for the help! ORG A,B almost worked, but gave me an error when I exceeded 0xFFFF. I was able to make it work by turning the FILL option off and on between each bank. This stopped the "can't fill from higher memory" error. ;Start of Bank1 org $8000 opt h-f+ ;turn on fill ;End of Bank1 org $bffe .byte $01 ;this causes assembler to fill to end of bank opt h-f- ;turns off fill ;Start of Bank2 org $8000 opt h-f+ Quote Link to comment Share on other sites More sharing options...
