19rsn007 Posted October 19, 2012 Share Posted October 19, 2012 hey people Lately I've not had any luck with atari computers. I've just picked up a power supply for my recently given AtariST 520. It came with a composite cable, but somehow all it gives my is a jumpy image (like it's out of sync) So tonight I took it to a friend of mine who had an AtariST monitor which is working fine on his 1040ST. We hooked it up to get it going, but the picture is way out of sync! Same goes when I try to hook it up via RF......no good signal. What could be going on with this ST?? I'd love to get it working, cause I never had an ST and I want to see what an ST can do. Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 20, 2012 Share Posted October 20, 2012 Pal machine running in NTSC country or the other way around will often give a rolling picture. You could try to find a game menu disk with system selector - some pirated menu systems and games let you switch Pal/NSTC. It won't really help the problem but could identify if your machine is starting in the wrong mode. The Pal/NTSC mode on startup is controlled by what Rom is installed, e.g. English/German will start in Pal, US Rom will start in NTSC. Quote Link to comment Share on other sites More sharing options...
19rsn007 Posted October 20, 2012 Author Share Posted October 20, 2012 ok, but should it be like that when it was connected to an official atari st monitor (the high res monochrome one) Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 21, 2012 Share Posted October 21, 2012 Hires should be the same no matter where - it's ~ 70 Hz refresh. Sounds like the computer itself has some sort of fault. The old "2 inch drop" might fix it, but it has it's risk factor, ie might make it worse. 2 inch drop: Hold the computer level, 2 inches above the desk, then drop it. Quote Link to comment Share on other sites More sharing options...
fedepede04 Posted October 21, 2012 Share Posted October 21, 2012 i would advise you to ask over at atari-forum.com, there are some very talent Atari-st hardware guys, there have help other fix there Atari's Quote Link to comment Share on other sites More sharing options...
19rsn007 Posted October 21, 2012 Author Share Posted October 21, 2012 the 2 inch drop didn't make ik any better. Not worse either. Think I'm just gonna take out the TOS chips and ask my friend (that had stacks of ST's for parts) if I can pick one at his place and test it with my TOS chips to see if it works Quote Link to comment Share on other sites More sharing options...
tjlazer Posted October 29, 2012 Share Posted October 29, 2012 Press all socketed chips in firmly and see if that helps. Quote Link to comment Share on other sites More sharing options...
