LX.NET Posted November 16, 2012 Share Posted November 16, 2012 I need a bit of help on this one. I am working on the collision detection for Pitfall and have got most of it set up. The lynx-160-102-16.tgi driver sets up the collision detection buffer at $A058 and the collision depository offset at $FFFE (minus 2 I believe) automatically. Collision detection is started by myself by using: asm("lda #$04"); asm("sta $fc92"); The collisions are detected, but I notice some weird, unexpected behavior. Imagine Harry walking in the underground from left to right. He turns around before he encounters the scorpion and runs to the left again. As the scorpion approaches Harry, but before it reaches him collisions start occurring with the scorpion (coll number 4) hitting Harry (coll number 15) at places where Harry has been. Not every frame, but every other frame. It seems to me that the collision buffer is not cleared. I do a call to tgi_clear() whenever I redraw the screen. My questions: Am I correct in the assumptions that the buffer is not cleared? How do you clear the collision buffer officially if not via tgi_clear() ? What are possible reasons that the scorpion sprite has a changing collision depository value every other frame? Is there a neat trick to visualize the collision buffer? I tried a quick and dirty hack with the collision base address and also with the collision build buffer: if (kbhit()) { switch (cgetc()) { case 'P': // Swap around collision build buffer with video build buffer asm("lda $FC0E"); asm("sta $FC0C"); asm("lda $FC0F"); asm("sta $FC0D"); while (true); But that did not seem to work. Is there a timing restriction on when you can read the collision depositories from the sprites? Specific moments? Why is the collision depository at -2, not -1. There is only a 4 bit value written to it, so why use an int value? Thanks in advance for any advice or hints. Source code available on demand. Alex Quote Link to comment Share on other sites More sharing options...
matashen Posted November 16, 2012 Share Posted November 16, 2012 You have to clean the collision buffer every time you redraw the screen. When you draw something the same would be added to the collisionbuffer. in the old c it looks like this extern char clsSCB[]; extern uchar cls_color; #asm ; sprite used to clear the collision buffer dc.w 0 ; collision depository _clsSCB: dc.b $c0,$90,$00 ; collision number is 0! dc.w 0,cls_data dc.w 0,0 ; X,Y dc.w 255*$100,102*$100 ; scaled to 255*102 pixels original 160 cause we use more space scrolled _cls_color: dc.b $00 ; data: 1*1 pixel cls_data dc.b 2,$10,3 #endasm /***********************************************/ /* Clears the screen _and_ the collsion buffer */ /***********************************************/ CLS(nColor) uchar nColor; { cls_color = nColor; // Quick and dirty DrawSprite(clsSCB); } Quote Link to comment Share on other sites More sharing options...
sage Posted November 16, 2012 Share Posted November 16, 2012 Is there a timing restriction on when you can read the collision depositories from the sprites? Specific moments? Yes., after the last sprite has been finished dfrawing and before you start to draw it again. Why is the collision depository at -2, not -1. There is only a 4 bit value written to it, so why use an int value? because the SCB can have different sizes. thus is easier to have negative offsets or you would have to use the maximum size for each SCB and waste a lot of memory. Quote Link to comment Share on other sites More sharing options...
LX.NET Posted November 17, 2012 Author Share Posted November 17, 2012 because the SCB can have different sizes. thus is easier to have negative offsets or you would have to use the maximum size for each SCB and waste a lot of memory. Hi Sage, Yes, I understand why it is negative. What I do not understand is why the default is -2. Since the collision number is just a 4 bit number set in the SPRCOLL of the SCB, is there a reason to reserve 2 bytes for the depository? I would think that you could use a single byte. Do you know why (not)? Quote Link to comment Share on other sites More sharing options...
+karri Posted November 17, 2012 Share Posted November 17, 2012 There is actually an ioctl command for starting the collision detection. tgi_ioctl(5, 0/1); Or use the more convenient form tgi_setcollisiondetection(active); where active=0 or 1. -- Karri Quote Link to comment Share on other sites More sharing options...
sage Posted November 17, 2012 Share Posted November 17, 2012 Hi Sage, Yes, I understand why it is negative. What I do not understand is why the default is -2. Since the collision number is just a 4 bit number set in the SPRCOLL of the SCB, is there a reason to reserve 2 bytes for the depository? I would think that you could use a single byte. Do you know why (not)? I do nott know why you think -2 is a "default" value here? Quote Link to comment Share on other sites More sharing options...
LX.NET Posted November 17, 2012 Author Share Posted November 17, 2012 It's not a hardware default, but a chosen one in CC65. In the libsrc for lynx-160-102-16.s you can find: INIT: ; Enable interrupts for VBL lda #$80 tsb VTIMCTLA ; Set up collision buffer to $A058 lda #$58 sta COLLBASL lda #$A0 sta COLLBASH ; Put collision index before sprite data lda #$FE sta COLLOFFL lda #$FF sta COLLOFFH which makes a "default" of FFFE for the COLLOFF collision depository offset. You must create a struct like this: typedef struct { int collision; sprite_sizable sprite; } sprite_entity_collidable; to work with the correct value. At least, that is what I think. Correct? So, I still wonder: why an int and -2 as default? Any particular reason for that? Quote Link to comment Share on other sites More sharing options...
LX.NET Posted November 17, 2012 Author Share Posted November 17, 2012 There is actually an ioctl command for starting the collision detection. tgi_ioctl(5, 0/1); Or use the more convenient form tgi_setcollisiondetection(active); where active=0 or 1. -- Karri Thanks Karri, I forgot about that one. I will add it to my code and the upcoming tutorial. Quote Link to comment Share on other sites More sharing options...
sage Posted November 17, 2012 Share Posted November 17, 2012 It's not a hardware default, but a chosen one in CC65. In the libsrc for lynx-160-102-16.s you can find: as it seems, only there, neither newcc65 nor bll have this strange init values. So, I still wonder: why an int and -2 as default? Any particular reason for that? Nah, just looks waste of memory. Quote Link to comment Share on other sites More sharing options...
LX.NET Posted November 17, 2012 Author Share Posted November 17, 2012 You have to clean the collision buffer every time you redraw the screen. When you draw something the same would be added to the collisionbuffer. in the old c it looks like this ... Thanks matashen, Tried this in a cc65 way and it works. It does seem though that this slows down rendering considerably (at least in Handy emulation) up to the point where I start missing frames. I will look at that. As it turns out the implementation of tgi_clear draws non-collidable sprites to clear only the visible screen. Makes sense, as you would only want to clear the collision buffer when you are using it. It does beg for an implementation of tgi_clearcollisionbuffer() or an overload method tgi_clear(true) where the Boolean indicates whether to clear the collision buffer as well. Karri? Quote Link to comment Share on other sites More sharing options...
LX.NET Posted November 17, 2012 Author Share Posted November 17, 2012 as it seems, only there, neither newcc65 nor bll have this strange init values. Nah, just looks waste of memory. Karri, maybe something to test and fix in cc65? Quote Link to comment Share on other sites More sharing options...
+karri Posted November 18, 2012 Share Posted November 18, 2012 (edited) It's not a hardware default, but a chosen one in CC65. In the libsrc for lynx-160-102-16.s you can find: INIT: ; Enable interrupts for VBL lda #$80 tsb VTIMCTLA ; Set up collision buffer to $A058 lda #$58 sta COLLBASL lda #$A0 sta COLLBASH ; Put collision index before sprite data lda #$FE sta COLLOFFL lda #$FF sta COLLOFFH which makes a "default" of FFFE for the COLLOFF collision depository offset. You must create a struct like this: typedef struct { int collision; sprite_sizable sprite; } sprite_entity_collidable; to work with the correct value. At least, that is what I think. Correct? So, I still wonder: why an int and -2 as default? Any particular reason for that? The reason is that the length of the sprite struct is not constant. So it is very difficult to place it after the sprite. Instead I placed it before the sprite so that the tgi-driver does not have to know how large the sprite struct is. But why is it -2 and not -1? Perhaps I thought that it needs on int and not a byte. I can change that. Edited November 18, 2012 by karri Quote Link to comment Share on other sites More sharing options...
+karri Posted November 18, 2012 Share Posted November 18, 2012 As it turns out the implementation of tgi_clear draws non-collidable sprites to clear only the visible screen. Makes sense, as you would only want to clear the collision buffer when you are using it. It does beg for an implementation of tgi_clearcollisionbuffer() or an overload method tgi_clear(true) where the Boolean indicates whether to clear the collision buffer as well. Karri? tgi_clear() is reserved as it is. Do we need a separate command for clearing the collision buffer or is it enough if the active flag from activating the collision detection would change the the tgi_clear() to clear both buffers?. Quote Link to comment Share on other sites More sharing options...
LX.NET Posted November 19, 2012 Author Share Posted November 19, 2012 I would say your suggestion is very good. tgi_clear will also clear the collision buffer when it is enabled. Would a separate method for explicitly clearing the buffer be useful? You wouldn't have to depend on the collision detection to be enabled. Just thinking out loud. Quote Link to comment Share on other sites More sharing options...
obschan Posted November 19, 2012 Share Posted November 19, 2012 I vote for the specialized tgi_clearcollisionbuffer method. I have few reasons connected to my coding habits but most importantly I believe, is trying to keep the API away from being bloated. I know that on our latest computers it does not sound armful, but CPU cycles and memory are very precious on Lynx, if I do not use the hard collision buffer I would prefer not to loose memory to store the unnecessary code and cpu on each frame to test if the collision buffer is activated. Quote Link to comment Share on other sites More sharing options...
+karri Posted November 20, 2012 Share Posted November 20, 2012 (edited) I changed to offset to -1 for the collision index of a sprite. I also changed the behaviour of tgi_clear. Normal tgi_clear works without collision buffer erasing. If you activate collision detection through the tgi_setcollisiondetection(1) then the sprite type of tgi_clear() is changed so that it will also erase the collision detection screen. Changing the collision away will reurn the standard tgi_clear() operation back again. There is no extra code run in tgi_clear() due to this change. Unfortynately I have not had the time to test this code yet. But I hope it works. -- Karri Edited November 20, 2012 by karri Quote Link to comment Share on other sites More sharing options...
LX.NET Posted November 20, 2012 Author Share Posted November 20, 2012 Sounds good. I am pressed for time until after December, 3rd. After that I will take a look at it. For now I will work with Matashen's approach (which works brilliantly, thanks Matashen!). Quote Link to comment Share on other sites More sharing options...
+karri Posted November 21, 2012 Share Posted November 21, 2012 I actually checked my own work already. First all sprites are grey. Then I move the circle to touch the cross and it turns red. The sources and a compiled lnx image are included. collision.zip The code needed for this to work is now in the svn of the cc65. Quote Link to comment Share on other sites More sharing options...
+karri Posted November 23, 2012 Share Posted November 23, 2012 I started to play around with the collision stuff. Unfortunately I found some strange symptoms that may be stack corruption. It is only there when collision detection is active. It may take a while for me to find the reason for it. Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted November 24, 2012 Share Posted November 24, 2012 Compiled with the latest snapshot? Using your collision.zip source above or only the pong clone you mentioned? Quote Link to comment Share on other sites More sharing options...
LX.NET Posted November 25, 2012 Author Share Posted November 25, 2012 Perhaps GadgetUK has encountered a bug in this as well. See tgi_outtextxy topic. Quote Link to comment Share on other sites More sharing options...
+karri Posted November 26, 2012 Share Posted November 26, 2012 Compiled with the latest snapshot? Using your collision.zip source above or only the pong clone you mentioned? The pong clone. The collision demo may be ok. Quote Link to comment Share on other sites More sharing options...
+karri Posted November 27, 2012 Share Posted November 27, 2012 The collision detection demo has the same stack bug as my pong game. The C-stack and the collision buffer are now sharing he same memory are. So the stack is filled with zeroes on every round. To fix this you need to add "-C lynx-coll.cfg" to the linker command line. Here is the fixes sources. collision.zip Quote Link to comment Share on other sites More sharing options...
LX.NET Posted November 29, 2012 Author Share Posted November 29, 2012 Is the clearing of the collision buffer (for a full screen) a particular long operation? I thought it would be as cycle-consuming as a full screen paint times two (at most). I notice that when I do a draw of the full-screen sprite that I start getting frame-drops. This also begs the question: what if you want to do a partial collision buffer clearing? A tgi_clearcollisionbuffer(0, 0, 160, 51) would be great for that. Right now, the tgi_clear always does a full screen clear, right? Quote Link to comment Share on other sites More sharing options...
sage Posted November 29, 2012 Share Posted November 29, 2012 Is the clearing of the collision buffer (for a full screen) a particular long operation? I thought it would be as cycle-consuming as a full screen paint times two (at most). I notice that when I do a draw of the full-screen sprite that I start getting frame-drops. This also begs the question: what if you want to do a partial collision buffer clearing? A tgi_clearcollisionbuffer(0, 0, 160, 51) would be great for that. Right now, the tgi_clear always does a full screen clear, right? As clearing the buffer is done on drawing a sprite (like 1*1 pixel scaled to screen size), it will take roughly two times the time for drawing the sprite without collision. the time is consumed by the memory writes, not the sprite decoding in this case. Quote Link to comment Share on other sites More sharing options...
