ParanoidLittleMan Posted December 10, 2012 Share Posted December 10, 2012 I'm working on hi-color video playback together with Cyg and Douglas Little - so it includes hi-color picture displaying on ST, STE machines too. There is one issue what results in small errors in displayings in some cases, caused by different timings in video circuits on diverse machines and emulators. Furthermore, it may change by warming of machine. Errors look like: SW for testing: http://atari.8bitchip.info/TIMINGC.ZIP Mostly testing on STE, Mega STE is interesting. Please, run TTP executable, and enter 1A and look carefully what is on screen errors are not big - bad color dots, mostly at same hor. pos, so like stripped vertical bars. Exit with space, then check other s -1B, 2A, 2B . If can, do check with cold machine, and later with warmed up - but turn off for short between tests - it is important, because timing scheme sets only by power-up. Then write here which ones looked good, which bad - and when. My STE, when is cold shows well A or B in 50%-50% cases. When is warmed shows always A correct. Emulators whow B correct (Steem and Hatari). My Mega STE shows correct A or B even when warmed up. I don't expect situation that none will be shown correct, but who knows - then would like to see screenshot of it - but it may be problem if no capture card. Warmed up - it means here after working couple minutes - intern warm of chips is relevant, not that computer gets hot :-) As presence for people contributing: you will be able to playback something like this on your machine: http://atari.8bitchip.info/DebrisUS12fps.avi It was made with Mega STE and UltraSatan. STE is good too, of course - must run on 8MHz CPU clock. I need to fix some things yet in playback SW, mostly related to diverse filesystems and drivers possible. As already said earlier: this will work only if disk and adapter are enough fast, so min transfer rate is 1100KB/sec. And you need to defragment partition on which large AV file will be copied. SW and example AV file in couple days ... Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted December 10, 2012 Share Posted December 10, 2012 Still amazed by what's being done lately with video on the STe line. Wonderful stuff - Big pat on the back for all involved. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted December 12, 2012 Author Share Posted December 12, 2012 (edited) Here is video, good for UltraSatan playback, something interesting for Atari fans, from 25 years ago: http://atari.8bitchip.info/HCPL158.ZIP 22MB. Player SW and instructions included. Works on ST too, without sound. In case of problems test speed with: http://atari.8bitchip.info/ahpt.html Video of playback: http://atari.8bitchip.info/AscUS.avi When SD card is slow: http://atari.8bitchip.info/Slowc.avi With classic hard disk: http://atari.8bitchip.info/ClHard.avi Same video with overscan (not for US) : http://atari.8bitchip.info/Asc.avi If someone with IDE adapter and CF card want video playback, please let me know - write couple words about your specs. Edited December 12, 2012 by ParanoidLittleMan Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted December 14, 2012 Author Share Posted December 14, 2012 Updated player and some technical infos added: http://atari.8bitchip.info/movpst.php Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted December 14, 2012 Share Posted December 14, 2012 Always interesting reading, thanks! I remember VCD. Usually took 2 CDs to make a whole movie. When I first got into Mandrake Linux about 1999 or so, the video player I used would only support VCD. I've still got a stack of them lying around somewhere. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted February 8, 2013 Author Share Posted February 8, 2013 Not much help received here, but why to surprise me Anyway: Here is regular Steem 3.2 with only changed to TimingA: http://atari.8bitchip.info/SteemTimingA.zip Just copy it to your Steem DIR and use to see difference. If compare hi-color screens of hard disk adaptations, latest ones, you will see that errors are same as on YouTube videos of games. By me, it should be default Steem timing, since most of STE machines are in TimingA in most of cases. Quote Link to comment Share on other sites More sharing options...
