Atari Lynx programming tutorial
LX.NET
I tried to collect the tools into one place at bitbucket.org/atarilynx.
There is a repository
lynx/tools/bll = the BLL repository. You need to add an environment variable BLL_ROOT to point to the right place.
lynx/tools/cc65 = the C compiler/linker
lynx/tools/lynxer = the tool for creating carts when using BLL or newcc65
lynx/tools/lyxass = the old assembler used with the BLL kit
lynx/tools/newcc65 = the very old C-compiler that wastes space and has bugs
If you want to set up everything for Ubuntu or Raspbian there is a simple way to do it.
cd lynx/tools
sudo make -f Makefile.deb
It will compile all tools and install them into proper places.
Actually this script generates installation packages that could be exported and later be installed by the standard installers. But the creation of the packages happen to leave the stuff installed. So as a side effect running the package creation script will also install everything.
What we still need to do is to make a simple installation script for other popular OS like Windows.
In addition to that there is user contributions in
lynx/contrib
lynx/contrib/multicart = contains code for using the SD multicart by SainT
lynx/contrib/ottelo = an Othello clone written in BLL that fits into 1024 bytes ;)
there is also a version that is a few bytes larger that plays an old Finnish kantele tune in the background.
My daughter was practicing on this tune when I wrote Ottelo for a 1k competition years ago.
The tune is written using abcmusic.
I also hope to add lynx-snd.s there. It contains the Chipper run-time code.
Edited by karri
Does anyone currently have an Atari Lynx programming environment set up on a Windows 7 64 bit computer?
I managed to set up my setup but on Windows 7 32 bit. Used files from first post of this topic. Also sprpck.exe 1.98 will be needed there.
I already tried to paint some graphics with custom color palette and attach that to game. Works fine and first sample screen of my text adventure game was made.
http://www.atariage.com/forums/gallery_ips/gallery/album_1819/gallery_49654_1819_1359.png
Now need to read next stages of tutorial, and try to figure out how joystick + selecting dialogue options will work.
Edited by hikachi
I love the style. You could take a look at some of my denser fonts like Arial if you go for a text adventure.
https://bitbucket.org/karri/arial
Or the classic Atari font
https://bitbucket.org/karri/atari
Thanks for help, will consider those fonts. Would it be memory heavy? Because i'm no sure yet how many graphics (and text lines) like on screenshot i can include to project.
Was there text adventure / graphics novel game released on lynx before?
Sorry for little off-topic, I will create a topic about my project when it will be on proper stage. Working on joystick functions -> trying to figure out how to include a lot of text and choices with the minimum of coding.
Sort of. One of my favourite writers.
http://atariage.com/forums/topic/206681-a-novel-program-for-the-lynx/?p=2662167
And Dracula the Undead was cut down to fit 256k. But today making a 512 k cart is no problem.
Edited by karri
Personally, I like this kind of interface with a cursor and submenu
Somethings like this :
Yea that was my idea there too. I already made working choice menu and just added square pointer
http://www.atariage.com/forums/gallery_ips/gallery/album_1819/gallery_49654_1819_6007.png
"Simon the Sorcerer" - i don't know this one but it looks good. I like the pixel art there. I liked "Teenagent" (it's free on gog nowadays https://www.gog.com/game/teenagent) My game will be text based i think.
Edited by hikachi
  • 2 months later...
I downloaded the "Tutorials26082016.zip" file
"Encryption" you can check the folder. the "tutorial.c" file is wrong.
Not match the file "Tutorial-encryption.lnx"
Let me have a look. Could be that the encryption had some "non-public" things that i removed.
The Lynx encryption is not relevant as the private key is revealed. The cc65 builds a minimal encrypted loader before the directory automatically so unless you are interested in encryption as part of the Lynx history there is no need to dig into encryption anymore.
  • 2 months later...
  • 6 months later...
A sprite can have a sprite depth of 1, 2, 3 or 4 bits. This corresponds to 2, 4, 8 or 16 colors. Color 0 can be used as transparent if you choose the sprite type to NORMAL.
All these tricks to get more colors than 16 on the screen at the same time has to be done by modifying the mapping from the 4 pits per pixel in the frame buffer to the 4096 colors the LCD can display. I don't know how the flicker-free high res images were created. But they look really nice.
  • 3 months later...
Have you tried other options or different option for the .bmp format (i.e. encoding)?
I've been using sprpck 1.98, and that worked well enough with BMP files. I just wanted to try making transparent (shaped) sprites, a feature of sp65. I'm still looking for a way to export a PCX with a 4-bit index before that can happen.
Edited by rmzalbar
