trub Posted January 2, 2013 Share Posted January 2, 2013 Hello, SpartaDOS X 4.46 with Toolkit is now officially available for download on: http://sdx.atari8.info (or http://spartados.com and http://spartadosx.com). List of changes is available here: http://sdx.atari8.in...46/whatsnew.txt Since the manual will be updated to 4.46 a little bit later, please review the whatsnew.txt file carefully. You may also like to visit SDX upgrade project on Facebook: http://www.facebook.com/SpartadosX Although still in the early stage, the page contains highlights of the new release and other announcements. DLT team 4 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted January 2, 2013 Share Posted January 2, 2013 Great set of updates! I can't wait to try out the CP/M stuff. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted January 3, 2013 Share Posted January 3, 2013 On my 800xl that has an Ultmate upgrade. COMEXE.SYS and X.COM don't seem to like MYIDE II hardware. screen corruption needing RESET key to clear or reboot. Atari's without this upgrade seem to work ok.. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted January 3, 2013 Share Posted January 3, 2013 Well, I am successfully reading CP/M disks! My Indus is connected to a different system, so I cannot try Trub's terminal using the RC_GR8 driver yet. So far the only issue I have noticed with this latest version, is that EDDY will lock up if using CON 80. The CON.SYS driver can be loaded, but I have to issue a CON 40 first. Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted January 4, 2013 Share Posted January 4, 2013 (edited) How are FAT12A.SYS, FAT12B.SYS, and FAT16.SYS used? Are there any parameters required? What type(s) of media are supported? Which interfaces/disk drives? Can I still use flashjazzcat's MYIDE.SYS and APT with this release of SDX? I tried the beta driver that's at least a year old. It seems to work but I was wondering if drivers and utilities have been updated for SDX 4.46. BTW, I have an 8-mbit Atarimax flashcart with SDX 4.46 (image customized w/ SDXImageUser), an NTSC 800XL, 320K (compyshop) w/ battery, MyIDE kit (OS ver 4.2i), ATR8000 w/ two 360KB drives and two 1.2MB drives. Regards and thanks for this update. -SteveS p.s. ED does not seem to get along with CON64.SYS. (This is the first time I've tried this driver). The window is tiny and there seems to be bitmapped graphics instead of text. Edited January 4, 2013 by a8isa1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted January 4, 2013 Share Posted January 4, 2013 p.s. ED does not seem to get along with CON64.SYS. (This is the first time I've tried this driver). The window is tiny and there seems to be bitmapped graphics instead of text. This is a known limitation - ED only works with the standard 40 col screen currently. Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted January 4, 2013 Share Posted January 4, 2013 This is a known limitation - ED only works with the standard 40 col screen currently. ok. sorry. Guess I never looked at CON64.SYS with SDX 4.44 and 4.45. I do like that video mode though. Quote Link to comment Share on other sites More sharing options...
drac030 Posted January 4, 2013 Share Posted January 4, 2013 So far the only issue I have noticed with this latest version, is that EDDY will lock up if using CON 80. The CON.SYS driver can be loaded, but I have to issue a CON 40 first. That's odd, I can't reproduce such a problem here. Quote Link to comment Share on other sites More sharing options...
drac030 Posted January 4, 2013 Share Posted January 4, 2013 How are FAT12A.SYS, FAT12B.SYS, and FAT16.SYS used? Are there any parameters required? No parameters. What type(s) of media are supported? Anything which is able to read/write 512-byte sectors. Which interfaces/disk drives? E.g. such serial drives as TOMS 720, or such parallel drives as Karin Maxi, or hard disk interfaces such as IDEa or IDE+. Can I still use flashjazzcat's MYIDE.SYS and APT with this release of SDX? I guess so:) Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted January 5, 2013 Share Posted January 5, 2013 No parameters. Anything which is able to read/write 512-byte sectors. Thanks. Apparently the ATR8000 can't I was able to view a disk image by taking the 16 byte header from an ATR (2880 sectors, 512 bps) created with AspeQt and concatenating it with a floppy disk image (1.44MB) made with dd. I thought I had been doing something wrong until I tried this but it works great! -SteveS Quote Link to comment Share on other sites More sharing options...
w1k Posted January 5, 2013 Share Posted January 5, 2013 succesful flashed into u1mb Quote Link to comment Share on other sites More sharing options...
drac030 Posted January 5, 2013 Share Posted January 5, 2013 Apparently the ATR8000 can't The key feature necessary are PERCOM commands implemented. SDX needs the "READ PERCOM" command to fetch the sector size value before a disk access is made. When PERCOM is not supported, SDX assumes the drive can only do 128-byte sectors. This may be the case here. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted January 5, 2013 Share Posted January 5, 2013 succesful flashed into u1mb Victor, I like your nature photos.... Quote Link to comment Share on other sites More sharing options...
w1k Posted January 5, 2013 Share Posted January 5, 2013 i dont go away.. only my atari personal site will be deleted in 6/2013 and i stopped releasing my diskmag. but thanks Quote Link to comment Share on other sites More sharing options...
+Stephen Posted January 5, 2013 Share Posted January 5, 2013 Will this new 4.46 work on the Incognito boards or is a special build required? Quote Link to comment Share on other sites More sharing options...
drac030 Posted January 5, 2013 Share Posted January 5, 2013 U1MB build will do. Quote Link to comment Share on other sites More sharing options...
+tf_hh Posted January 6, 2013 Share Posted January 6, 2013 Hi, I try to copy some utilities from the CAR: device to a standard SDX partition. Reason is to keep the FDISK.COM from FJC´s SDX 4.45 package and update my SIDE to 4.46, which doesn´t contains FDISK.COM. But I get an error "161 - too many files open" when I try this. In SDX 4.45 and 4.46. Is it generelly not possible to copy COM-files or so from the CAR: device to a floppy oder harddrive partition? Thanks, Jurgen Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 6, 2013 Share Posted January 6, 2013 There's only one I/O channel on the CAR: handler, so you can't open files for copying. Instead, use output redirection, e.g.: TYPE CAR:FDISK.COM >>C:FDISK.COM 2 Quote Link to comment Share on other sites More sharing options...
+tf_hh Posted January 6, 2013 Share Posted January 6, 2013 Cool. Works fine. Thanks! Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 6, 2013 Share Posted January 6, 2013 Thanks tf_hh for pointing out that the HDD driver in the SIDE build of 4.46 is somewhat outdated. I'll send the latest one to the SDX team as soon as I get a chance. 3 Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted January 6, 2013 Share Posted January 6, 2013 I am having a small problem with THE LAST WORD not printing with Aspeqt print function with SDX446. Also something with the COMEXE.SYS and X.COM features causing a crash after viewing RasterView files, and then loading Turbobasic or the last word 3.1b. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted January 6, 2013 Share Posted January 6, 2013 (edited) Did it work with SDX 4.45?....I'll upgrade to 4.46 and see.. Edited January 6, 2013 by atari8warez Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted January 6, 2013 Share Posted January 6, 2013 (edited) Drac030 KMK While updating My IDE+20 to SDX446 I checked your site and noticed a new BIOS 1.2 BUT the down load link is directed to BIOS 1.1. This is a great upgrade for hard disk users it is my main for daily use.. Edited January 6, 2013 by rdea6 Quote Link to comment Share on other sites More sharing options...
drac030 Posted January 6, 2013 Share Posted January 6, 2013 Thanks for pointing this out, link fixed. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted January 6, 2013 Share Posted January 6, 2013 I am having a small problem with THE LAST WORD not printing with Aspeqt print function with SDX446. Also something with the COMEXE.SYS and X.COM features causing a crash after viewing RasterView files, and then loading Turbobasic or the last word 3.1b. Works just fine here..... although to find that out i had to flash my U1MB to SDX 4.46. After the flash few things started to go nuts and I was a bit worried. Turns out, I had to leave the 130XE OFF for a few minutes after the flash. Whew!!!..... Atari means excitement all the time.... Quote Link to comment Share on other sites More sharing options...
