Roydea6 Posted January 6, 2013 Share Posted January 6, 2013 Works just fine here..... although to find that out i had to flash my U1MB to SDX 4.46. After the flash few things started to go nuts and I was a bit worried. Turns out, I had to leave the 130XE OFF for a few minutes after the flash. Whew!!!..... Atari means excitement all the time.... OK thanks for checking My print driver must not be the correct one...I'll work on it to see if I can get it working better.. Quote Link to comment Share on other sites More sharing options...
AtariMagic! Posted January 7, 2013 Share Posted January 7, 2013 using the rom generator, upgraded the ultimate 1mb with the sdx 4.46 rom now selecting spartados x brings the blue screen but no text since i can not load spartados, can't reflash the ultimate again either.... Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted January 7, 2013 Share Posted January 7, 2013 using the rom generator, upgraded the ultimate 1mb with the sdx 4.46 rom now selecting spartados x brings the blue screen but no text since i can not load spartados, can't reflash the ultimate again either.... Maybe you used the Ultimate V1 ROM instead of V2 or vice versa ? I just upgraded my 800xl with U1MB using The ROM Generator to add the SDX4.46 ROM and flashed it without a problem... Jay Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted January 7, 2013 Share Posted January 7, 2013 On another note, if you use the correct Ultimate ROM and add the SDX 4.46 to it, you can still fix it. You just need SDX Enabled in Ultimate's Bios Menu and boot the image created by The ROM Generator... Quote Link to comment Share on other sites More sharing options...
greblus Posted January 7, 2013 Share Posted January 7, 2013 I also noticed a strange issue with U1mb Rom generator. If I use rom file from SDX 4.46 and if i load it in the Rom generator, the flasher will do its job correctly without any errors, but after a restart I still have SDX in version 4.45a. However, the atr image with flasher for Ultimate from the SDX 4.46 release works fine. Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted January 7, 2013 Share Posted January 7, 2013 (edited) I also noticed a strange issue with U1mb Rom generator. If I use rom file from SDX 4.46 and if i load it in the Rom generator, the flasher will do its job correctly without any errors, but after a restart I still have SDX in version 4.45a. However, the atr image with flasher for Ultimate from the SDX 4.46 release works fine. Looks like DLT and Jad have a new flasher in the Ultimate Atr. I'll check and see if this will flash a 512k image... Edit: I've updated The ROM Generator with the latest Ultimate Flasher and flashed my 130xe without any problems, (just like the 800xl)... Edited January 7, 2013 by AtariGeezer Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted January 7, 2013 Share Posted January 7, 2013 From the SDX446 release the toolkit.atr the SCRDRV sc083.arc has an older RC_GR8.SYS file in it . I have changed mine ... BUT... Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 8, 2013 Share Posted January 8, 2013 Still haven't had time to flash SDX 4.46 yet, but it strikes me that we should be able to have "external" FAT12 / FAT16 partitions referenced inside the APT segment of a hard disk. This would allow CF cards, etc, with - say - FAT16 + APT to have the FAT partitions mounted and accessed via the PBI as regular volumes using the new SDX FAT driver. All that's required is a little tweak to FDISK... at least, that's the plan. 3 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 12, 2013 Share Posted January 12, 2013 It works. Here's a zipped image for a 1GB CF card, for use with any APT device (SIDE, U1MB/SIDE, Incognito, IDE Plus with APT, etc): http://atari8.co.uk/downloads/CF_APT_With_FAT16.zip There's a FAT16 partition and an APT segment, containing two Atari partitions. Partition 1 (C:) is SDX formatted. Partition 2 (D:) is an external partition entry (hacked using a hex editor for now) which points back to the MS-DOS FAT16 partition. If you install the FATFS.SYS driver and type DIR D: at the prompt, you should (eventually) get a list of the contents of the latest IDE Plus 2.0 BIOS archive in the FAT16 partition. Best to make a custom CONFIG.SYS on C: with DEVICE FATFS and place the driver there too. (Note the driver's on the SDX support disk). Unfortunately I did neither of these things before imaging the card. The first DIR on the FAT partition is VERY slow, even at PBI transfer rates. I've read the readme describing some of the performance issues, but I'm not sure what the driver's doing while it's thrashing around. Subsequent access is pretty instantaneous, so presumably something's being cached in extended RAM for some reason. Quote Link to comment Share on other sites More sharing options...
Firedawg Posted January 12, 2013 Share Posted January 12, 2013 Thanks Fjc! Quote Link to comment Share on other sites More sharing options...
drac030 Posted January 12, 2013 Share Posted January 12, 2013 The first DIR on the FAT partition is VERY slow, even at PBI transfer rates. I've read the readme describing some of the performance issues, but I'm not sure what the driver's doing while it's thrashing around. It is scanning the FAT to obtain the initial number of free clusters. Quote Link to comment Share on other sites More sharing options...
candle Posted January 12, 2013 Share Posted January 12, 2013 what for? isn't this writen elsewhere just waiting for you to read it? Quote Link to comment Share on other sites More sharing options...
drac030 Posted January 12, 2013 Share Posted January 12, 2013 It is not. Quote Link to comment Share on other sites More sharing options...
candle Posted January 12, 2013 Share Posted January 12, 2013 so i've learned ;( Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 13, 2013 Share Posted January 13, 2013 Yikes... Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted January 13, 2013 Share Posted January 13, 2013 So if this partition was a normal floppy size (like a diskette) it would be faster because not as many cluster to check as free.. Quote Link to comment Share on other sites More sharing options...
candle Posted January 13, 2013 Share Posted January 13, 2013 not quite, floppy fat12 is slow to process, since data are packet to sqeeze most of the media capacity lots of nibble operations have to be preformed to get that data Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 13, 2013 Share Posted January 13, 2013 (Probably flawed) mental arithmetic suggests the FAT for a 32MB (FAT16) partition will consume 256 quad density sectors, or 128KB. Presumably cluster size is currently limited to one sector (hence the 32MB limit), so at least the FAT scanning won't ever take longer to process, even if the clusters get bigger. Bigger clusters would mean a smaller FAT for the same sized partition, however, which would introduce other trade-offs in performance. In short, it's rather unfortunate the free sector count isn't recorded in the boot sector of FAT disks. The FAT on a 360/720KB disk will obviously be many magnitudes smaller than that on a 32MB HDD partition (about 3 sectors for FAT12 on a 360KB quad density disk?), so yes - it would be considerably faster to process, despite the bit-packing overhead. Of course, unless our floppy disk is PBI, some of the speed advantage is lost. Quote Link to comment Share on other sites More sharing options...
drac030 Posted January 13, 2013 Share Posted January 13, 2013 The 32 MB limit is due to the SPARTA.SYS internal limit of 16 bits per physical sector number. The clusters themselves are not limited to 1 physical sector, so yes, one actually can split a 32 MB disk into 2k or 4k clusters, and have the FAT smaller. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 13, 2013 Share Posted January 13, 2013 Yeah - that's what I was trying to say: that it's the 1:1 cluster size limiting the partition size (since the 16-bit sector numbers are a hard-limit at the moment). Presumably larger clusters aren't supported in the driver yet (I wouldn't expect it at this stage)? Anyway - the drivers are really excellent, and open up many interesting storage and data transfer possibilities. Thanks for this. Quote Link to comment Share on other sites More sharing options...
drac030 Posted January 13, 2013 Share Posted January 13, 2013 Presumably larger clusters aren't supported in the driver yet (I wouldn't expect it at this stage)? They are, up to at least 16k per cluster should work without any problem. 32k may also work, I don't remember at the moment. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 13, 2013 Share Posted January 13, 2013 Brilliant - I'll test later on. Quote Link to comment Share on other sites More sharing options...
drac030 Posted January 15, 2013 Share Posted January 15, 2013 The "alpha version" of the SDX I/O library documentation, as dscussed in the other topic. This is a half of the Polish original, the translated version ends abruptly inside the chapter 9. sdx-programming-en-pub.pdf 3 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 19, 2013 Share Posted January 19, 2013 I'll start a separate thread for APT driver updates and utilities, but in the meantime here's a video of an ATR disk image on the same CF card I imaged in post #34 being mounted and run with U1MB / SIDE. The ATR files are all in the "external" FAT16 partition, the directory of which is seen here being listed via the SDX FAT16 driver (sequence shortened for brevity), before the NUMEN.ATR is mounted and booted via the MATR utility. Forthcoming versions of all the APT drivers / PBI BIOSes which previously supported FAT32 now support FAT16 as well (as do the attendant APT tools such as MATR) in order to provide maximum functionality when used in conjunction with the SDX FAT16 driver. Quote Link to comment Share on other sites More sharing options...
Defender II Posted January 23, 2013 Share Posted January 23, 2013 It works. Here's a zipped image for a 1GB CF card, for use with any APT device (SIDE, U1MB/SIDE, Incognito, IDE Plus with APT, etc): http://atari8.co.uk/..._With_FAT16.zip There's a FAT16 partition and an APT segment, containing two Atari partitions. Partition 1 (C:) is SDX formatted. Partition 2 (D:) is an external partition entry (hacked using a hex editor for now) which points back to the MS-DOS FAT16 partition. Best to make a custom CONFIG.SYS on C: with DEVICE FATFS and place the driver there too. (Note the driver's on the SDX support disk). Unfortunately I did neither of these things before imaging the card. Did you redo your zip file yet so it has the "custom CONFIG.SYS on C: with DEVICE FATFS and place the driver there too"?Thanks. Quote Link to comment Share on other sites More sharing options...
