flashjazzcat Posted January 23, 2013 Share Posted January 23, 2013 Did you redo your zip file yet so it has the "custom CONFIG.SYS on C: with DEVICE FATFS and place the driver there too"? Oops... no I didn't. I'll try and do that today... More useful, of course, will be an FDISK which allows the allocation of "external" FAT partitions inside the APT and doesn't go haywire when reading partition tables containing same. Really the whole partition editor needs a rewrite, which is a rather daunting prospect. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted January 31, 2013 Share Posted January 31, 2013 I'm loading SDX446 from the Fat32 partition on a CF card in a MyIDE-II with the latest MyBIOS and loader. The only "Atari-Side" partition I am aware of on the CF card is a MyDOS partition. When SDX loads MYIDE2.SYS, it complains of an "Invalid Partition Table". Is this because it is finding the MyDOS partition, but can't read it? SCX446 has no FDISK. Does this exist any where in a form I can use it? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 31, 2013 Share Posted January 31, 2013 Try this: fdisk.zip I have absolutely no idea how this will play with existing MYBIOS space on the disk (anything non-APT is outside my interest), so use at your own risk. Quote Link to comment Share on other sites More sharing options...
Frankie Posted January 31, 2013 Share Posted January 31, 2013 I'm loading SDX446 from the Fat32 partition on a CF card in a MyIDE-II with the latest MyBIOS and loader. The only "Atari-Side" partition I am aware of on the CF card is a MyDOS partition. When SDX loads MYIDE2.SYS, it complains of an "Invalid Partition Table". Is this because it is finding the MyDOS partition, but can't read it? SCX446 has no FDISK. Does this exist any where in a form I can use it? From what I can tell (I'm playing with the same setup) It's like it takes a while for it to read the partitions. If I wait about 30 seconds, suddenly all the drives come online and I can see the myDOS and any SDX partitions created. Quote Link to comment Share on other sites More sharing options...
Frankie Posted January 31, 2013 Share Posted January 31, 2013 Try this: fdisk.zip I have absolutely no idea how this will play with existing MYBIOS space on the disk (anything non-APT is outside my interest), so use at your own risk. I don't know how it does it, but myBIOS uses some other partition table. You can actually have a card setup for both. They won't know about each other so you need to make sure you leave the used space blank on the other partition table. I have a myBIOS partition with two drives, each 65535 in size. Then I load SDX from the FAT32 space, use FDISK and create SDX partitions. I create two inactive ones first (where I hope the myDOS ones are) and then add SDX ones after that. I haven't been able to completely verify if this idea is going to work. Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 31, 2013 Share Posted January 31, 2013 To work with APT and MyBIOS, you need to freshly Init your CF. Select MANUAL, AUTO CHS-detection and on the question APT?, answer yes. The next time you load MYIDE.SYS it will see the APT partition and use it for drives. Still need the toolkit (FDISK for APT/SDX) to create drives/partitions etc. Later, Sijmen. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted January 31, 2013 Share Posted January 31, 2013 Once I've created APT drives and SDX partitions, what is the right device indicator (i.e D1:, D2:, etc.)? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 31, 2013 Share Posted January 31, 2013 Depends what drive numbers you assigned in FDISK. Those ones refer to APT partitions, and rest are free for use by SIO devices and MYBIOS. Just ensure there are no clashes. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted January 31, 2013 Share Posted January 31, 2013 No, my question is dumber than that. I mean, what letter is used? 'D" still? H? My SIO2SD has some "V" devices, I don't have the first CLUE what to do with those! Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 31, 2013 Share Posted January 31, 2013 Me neither. Under SDX, A: = D1:, B: = D2:, and so on, in the command processor. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 1, 2013 Share Posted February 1, 2013 Is there any way to get the SDX446 into the flash area of myide-ii so I don't need to load it from a fat32 partition? Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 1, 2013 Share Posted February 1, 2013 Falling in love with SpartaDos X. But not feeling the fact that everything in the toolkit is arc'ed. "So, then just unarc the stuff", right? I would if I could get "arc x *.arc" to work as it does on every other platform known to man. It doesn't. It unarc's the first arc file that meets the wildcard requirements. *.arc picks up only the first arc'ed file. d*.arc picks up only the first arc'ed file that starts with d. You get the idea. Is this just me not knowing how to do something in SDX or is the wildcard parser in this arc utility broken/badly designed? Quote Link to comment Share on other sites More sharing options...
mr-atari Posted February 1, 2013 Share Posted February 1, 2013 Is there any way to get the SDX446 into the flash area of myide-ii so I don't need to load it from a fat32 partition? SDX446 for MyIDE-][ runs from protected SRAM and need to be copied there then coldstarted. FAT32-loader does this for you and sends the SRAM-bytes down to MyBIOS used to configure D8:SRAMDISK. Beside this, yes it it possible to load SDX446 from flash, but you need a boot-loader that does the above. I have one I can share, but it's for the 128k slim version. Quote Link to comment Share on other sites More sharing options...
spookt Posted February 1, 2013 Share Posted February 1, 2013 Hi folks Which image should I be using to update SDX in Incognito? Is the procedure the same as for U1Mb ? Quote Link to comment Share on other sites More sharing options...
trub Posted February 1, 2013 Author Share Posted February 1, 2013 For Incognito use Ultimate1MB image. They are compatible. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted February 1, 2013 Share Posted February 1, 2013 Beside this, yes it it possible to load SDX446 from flash, but you need a boot-loader that does the above. I have one I can share, but it's for the 128k slim version. This is exactly what I've been looking for since the MYIDE 2 cart landed on my desk. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 1, 2013 Share Posted February 1, 2013 (edited) "I have one I can share, but it's for the 128k slim version." Please, share. Edited February 1, 2013 by pixelmischief Quote Link to comment Share on other sites More sharing options...
Frankie Posted February 1, 2013 Share Posted February 1, 2013 Is there any way to get the SDX446 into the flash area of myide-ii so I don't need to load it from a fat32 partition? There is one for the first MyIDE cart. I haven't seen one for the ][ one. Quote Link to comment Share on other sites More sharing options...
Frankie Posted February 1, 2013 Share Posted February 1, 2013 Falling in love with SpartaDos X. But not feeling the fact that everything in the toolkit is arc'ed. "So, then just unarc the stuff", right? I would if I could get "arc x *.arc" to work as it does on every other platform known to man. It doesn't. It unarc's the first arc file that meets the wildcard requirements. *.arc picks up only the first arc'ed file. d*.arc picks up only the first arc'ed file that starts with d. You get the idea. Is this just me not knowing how to do something in SDX or is the wildcard parser in this arc utility broken/badly designed? http://www.atariage.com/forums/topic/201714-sdx-toolkit-unarced Quote Link to comment Share on other sites More sharing options...
mr-atari Posted February 1, 2013 Share Posted February 1, 2013 This is the version supplied upto MyBIOS 4.8.04 After #4 it was removed and the ATARIMAX Fat32-loader took over. Also the configurable D8:SRAMDSK was implemented. Anyhow, this version does not set the values needed for D8: under the current MyBIOS. Perhaps I can add this feature next Sunday.... If needed..... But it's not user friendly. You have to sign32crc the SDX-file, then add it as packed BIOS to the workbook. (So every time you change the ROM-file with the SDX-manager) The BOOT-SDX.XEX you can simply add. Well, thats about it. Succes, Sijmen. Quote Link to comment Share on other sites More sharing options...
spookt Posted February 1, 2013 Share Posted February 1, 2013 For Incognito use Ultimate1MB image. They are compatible. Hmm, that's what I thought but when I tried earlier it didn't seem to work. I must have done something wrong. I'll try again later when I'm back home. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 1, 2013 Share Posted February 1, 2013 (edited) The challenge using MyIDE-II and getting a CF card to have both FAT32 and APT partitions AND a MYIDE2 device driver acceptable partition table turned out to be, essentially, a tool chain problem. But I finally got it to work, and here is how. 1. Connect a floppy drive (or floppy emulator) to the Atari; 2. Create a floppy (or floppy image) with FJC's FDISK.XEX; 3. Prep a CF card on the PC with a FAT32 partition. Don't worry about the size as you will destroy this partition shortly; 4. Prep an SDX ROM image on the PC, inserting MYIDE2.SYS; 5. Edit CONFIG.SYS on the SDX ROM to include line "DEVICE MYIDE2" right after line "DEVICE SIO". If you are using SIO2SD Turbo as a floppy emulator, you have to load SIO classic, "DEVICE SIO /C"; 6. Copy the SDX ROM image to the FAT32 partition on the CF card. Make sure OSB.ROM is there as well; 7. Put the CF card back into the MyIDE-II and plug the cart into the Atari; 8. Boot the Atari and load the SDX ROM from the FAT32 partition; 9. See the MYIDE2 device load and complain about an "invalid partition table"; 10. Load FDISK.XEX from the floppy; 11. Initialize the disk (yes, I know I am telling you to destroy the FAT32 partition); 12. Answer YES to CREATE A FAT32 PARTITION?; 13. Size your APT partition to a maximim of 32MB * 15 partitions (480MB); 14. Create disk in the APT partition (65535 sectos, drive C: should do); 15. Pull the CF card and put it back on the PC; 16. Put the SDX ROM back on the FAT32 partition; 17. Put the CF card back in the MyIDE-II; 18. Boot the Atari and load the SDX ROM from the FAT32 Partition; 19. See the MYIDE2 device load and recognize the storage and list the disks; 20. Run CAR:FORMAT 21. Set DISK # to whatever you assigned the APT disk to in FDISK 22. Set VOLUME to a name that works for you; 23. "Create Directory" (or something like that); That's it. Exit the tool and navigate to your new APT hard disk. Edited February 1, 2013 by pixelmischief Quote Link to comment Share on other sites More sharing options...
spookt Posted February 1, 2013 Share Posted February 1, 2013 Hmm, that's what I thought but when I tried earlier it didn't seem to work. I must have done something wrong. I'll try again later when I'm back home. OK, here's what I get when I try the Ultimate SDX 4.46 flash ATR: Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted February 1, 2013 Share Posted February 1, 2013 OK, here's what I get when I try the Ultimate SDX 4.46 flash ATR: There is no flasher for the incognito yet... If you have an eprom burner that can flash the PLCC chip then use the Incognito Rombuilder and use that file to burn the PLCC. Or be happy with the existing rom.. and SDX445 version that is there.. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 2, 2013 Share Posted February 2, 2013 (edited) You have to sign32crc the SDX-file, then add it as packed BIOS to the workbook. What does that mean? What exactly do I need to do? Packed BIOS I recognize from the workbook builder, but sign32crc? Edited February 2, 2013 by pixelmischief Quote Link to comment Share on other sites More sharing options...
