B0B 1ob1aw Posted January 16, 2013 Share Posted January 16, 2013 I am sure this has been discussed before: Has anyone made their own, or purchased, some sort of extension cables for the Inty II? I would assume the connectors on the controllers were a proprietary configuration? Building cable assemblies is one thing I can do competently. Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted January 16, 2013 Share Posted January 16, 2013 The Intellivision II uses standard DB9 connectors for the hand controllers, so as long as they're molded cables which fit into the controller ports, you can safely use Atari extension cables with the Intellivision II. I sometimes use them myself, in fact. Quote Link to comment Share on other sites More sharing options...
B0B 1ob1aw Posted January 16, 2013 Author Share Posted January 16, 2013 Cool, thanks. So something like this cable would work? Plug-and-play with no further mods? eBay Auction -- Item Number: 170871800766 Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted January 16, 2013 Share Posted January 16, 2013 A cable like that one should work, yes. The ones I use have molded hoods that are a little slimmer and less square-shaped than those of the cable in the auction, so I don't know if that particular cable will fit into the Intellivision II, which has deeply recessed and narrow controller ports. I do have a few of those exact cables, though, so let me try them tonight to see if they'll fit. Quote Link to comment Share on other sites More sharing options...
B0B 1ob1aw Posted January 16, 2013 Author Share Posted January 16, 2013 If the extension connectors seem need to be shaved down to seat properly, that is something I can do myself too. Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted January 16, 2013 Share Posted January 16, 2013 In that case, those cables should do the job. Quote Link to comment Share on other sites More sharing options...
B0B 1ob1aw Posted January 16, 2013 Author Share Posted January 16, 2013 (edited) OK, sounds good. Extension Cables will be a good thing, I like to recline when I game. Unrelated question: If I have some Inty stuff I want to trade, is it OK manners to post it in this sub-forum? I noticed another forum here where people are posting stuff for sale, but it all seems to be 99% non-Inty. I would assume more Inty fans would see it in this forum. Plus I wouldn't be looking to sell it, just maybe trade/barter with other Inty fans. Edited January 16, 2013 by B0B 1ob1aw Quote Link to comment Share on other sites More sharing options...
nukeshed Posted January 16, 2013 Share Posted January 16, 2013 I don't see why you couldn't post it in both. Quote Link to comment Share on other sites More sharing options...
IntellivisionDude Posted January 16, 2013 Share Posted January 16, 2013 I use Sega Genesis controller extenders for my model 2 controllers. But you will have to shave off a little plastic on the end so it will fit in the controller port. 1 Quote Link to comment Share on other sites More sharing options...
bikeguychicago Posted March 4, 2013 Share Posted March 4, 2013 A cable like that one should work, yes. The ones I use have molded hoods that are a little slimmer and less square-shaped than those of the cable in the auction, so I don't know if that particular cable will fit into the Intellivision II, which has deeply recessed and narrow controller ports. I do have a few of those exact cables, though, so let me try them tonight to see if they'll fit. Jaybird: Were you able to determine whether or not the cables offered on eBay work without modification? I'm thinking about buying one so I can use a Sears controller with the Intv II so I don't have to worry about performing surgery. Thanks! Quote Link to comment Share on other sites More sharing options...
B0B 1ob1aw Posted March 5, 2013 Author Share Posted March 5, 2013 Jaybird: Were you able to determine whether or not the cables offered on eBay work without modification? I'm thinking about buying one so I can use a Sears controller with the Intv II so I don't have to worry about performing surgery. Thanks! They work really well. In fact the male connector housing is identical to the "teardrop" shaped plug on the Sears controllers. The cable plugs in just fine to the INTV II and the controllers. They seem like high quality cables for the price. At this point I am daisy chaining two with no problem. I may need to go with a third to get enough length to put it in my cable run, for phase 2.0 of my Lazy Retro Gamer HT integration. Quote Link to comment Share on other sites More sharing options...
