ResidentevilLeonfan Posted January 21, 2013 Share Posted January 21, 2013 Everything works fine and compiling works like a charm. However, when i run my game and Stella opens up, i get a blank screen as opposed to viewing my sprites. Did i do anything wrong? rem Generated 1/17/2013 9:42:28 PM by Visual bB Version 1.0.0.548 rem ********************************** rem *<filename> * rem *<description> * rem *<author> * rem *<contact info> * rem *<license> * rem ********************************** playfield: XX.............................. XX.............................. X..XXXXXXXXX.................... XXXXXXXXXX.XXXXXXXX............. XXX.X.XX.XXXXXXXXXX............. XX.............................. XXXXXXXXXXXXXXXXXXXXXXXXX....... XXXXXXXXXXXXXXXXXXXXXXXXX....... XXXXXXXXXXXXXXXXXXXXXXXXX....... XXXXXXXXXXXXXXXXXXXXXXXXX....... XXXXXXXXXXXXXXXXXXXXXXXXX....... end COLUBK=$38 COLUPF=212 hero player0x=50:player0y=50 player1x=20:player1y=20 player0: %00000000 %00000000 %00000000 %00000000 %00000000 %00000000 %00000000 %00000000 end villian player0: %00000000 %00000000 %00000000 %00000000 %00000000 %00000000 %00000000 %00000000 end drawscreen_loop drawscreen goto draw_loop Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted January 21, 2013 Share Posted January 21, 2013 Everything works fine and compiling works like a charm. However, when i run my game and Stella opens up, i get a blank screen as opposed to viewing my sprites. Did i do anything wrong? Do you see anything wrong with this: drawscreen_loop drawscreen goto draw_loop Take a second to look at it. I'll wait . . . Do you see the problem? There are actually two problems. Your goto isn't pointing to a label that exists. The second problem is that you don't want to start a label or variable name with a keyword. A great way to avoid that is to use an underscore. I start labels with two underscores and variable aliases with one underscore. Example: __Main_Loop drawscreen goto __Main_Loop Check out this thread to learn more about posting code: http://www.atariage....les-and-images/ Quote Link to comment Share on other sites More sharing options...
ResidentevilLeonfan Posted January 21, 2013 Author Share Posted January 21, 2013 You Do you see anything wrong with this: drawscreen_loop drawscreen goto draw_loop Take a second to look at it. I'll wait . . . Do you see the problem? There are actually two problems. Your goto isn't pointing to a label that exists. The second problem is that you don't want to start a label or variable name with a keyword. A great way to avoid that is to use an underscore. I start labels with two underscores and variable aliases with one underscore. Example: __Main_Loop drawscreen goto __Main_Loop Check out this thread to learn more about posting code: http://www.atariage....les-and-images/ You sir...are a lifesaver! It works perfectly! I don't know how to thank you! Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted January 21, 2013 Share Posted January 21, 2013 I don't know how to thank you! Cash and prizes. Quote Link to comment Share on other sites More sharing options...
