STuck Posted March 3, 2013 Share Posted March 3, 2013 Hi all, I'm trying to upgrade the TOS on my 520STFM from 1.02 to Rainbow TOS (1.06). The chip vendor is understandably a little vague on how to do it, is there HOWTOs available on how to do it? It appears there are 6 chip (28 pin) versions of TOS 1.06, so should it be a case of a straight swap, or do I have to mod it for 2 chip? Many thanks Quote Link to comment Share on other sites More sharing options...
tjlazer Posted March 4, 2013 Share Posted March 4, 2013 Don't bother with 1.06 as that is for the STE. Get 1.04 (the lastest for regular ST's) in 2 or 6 chip form for easy upgrade. Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted March 4, 2013 Share Posted March 4, 2013 6 chip replacement was the cleanest for me. I didn't want chips overhanging the sockets and the wires associated so I avoided to 2 EPROM mod and went for the 6 chip. I created the 6 TOS images using Hatari on the PC - for 1.04 rainbow (you cant use anything greater on STFM to my knowledge). I then programmed 6 EPROMs with the images, plugged them into the 6 sockets, making sure each one goes into the correct space, and finally there are some solder points to swap on the PCB. They are next to the TOS sockets - marked 1M or 256 I think. It will be set to 1M chips if you've got 2 in there, for 6 it needs swapping to the 256 pad. Quote Link to comment Share on other sites More sharing options...
STuck Posted March 6, 2013 Author Share Posted March 6, 2013 Many thanks for the replies, I went for a bank of six TOS 1.04s in the end, and upgraded my STe to 4Mb instead. I can't wait to get cuBase running on it Quote Link to comment Share on other sites More sharing options...
tjlazer Posted March 6, 2013 Share Posted March 6, 2013 (edited) If you have a STe you should Get 1.62 or 2.06!! Edited March 6, 2013 by tjlazer Quote Link to comment Share on other sites More sharing options...
STuck Posted March 6, 2013 Author Share Posted March 6, 2013 (edited) I'm using tos 2.06 on my 4mb STe, using SELTOS for the time being. I just wanted to upgrade my STFM for old time's sake Edited March 6, 2013 by STuck Quote Link to comment Share on other sites More sharing options...
tjlazer Posted March 7, 2013 Share Posted March 7, 2013 I have TOS 2.06 ROMs if you want it. Quote Link to comment Share on other sites More sharing options...
