Shift838 Posted March 9, 2013 Share Posted March 9, 2013 Who has their TI or Geneve hooked up to the internet? Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 9, 2013 Share Posted March 9, 2013 UDS-10 device for internet access Practical Peripherals 9600 modem for dialing out Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted March 9, 2013 Share Posted March 9, 2013 (edited) Same as you Tim; UDS-10 for TCP/IP connection, and GVC 14.4k external for calling The Hidden Reef. Edited March 9, 2013 by Mad Hatter Quote Link to comment Share on other sites More sharing options...
Gazoo Posted March 9, 2013 Share Posted March 9, 2013 No, I don't see the need. If there's something I want to up/download, I do it on the PC. Then it's easily transferred to my TI/Geneve 'hard drive' CF cards with TIimagetool. Gazoo Quote Link to comment Share on other sites More sharing options...
Stuart Posted March 13, 2013 Share Posted March 13, 2013 Not my 99/4A, but I've hooked my TM990 system up to the Internet so it can be used remotely. No practical purpose whatsoever, just wanted to have a play doing it. I've used a UDS-10 so far, but just got a SBL2e-100 from Netburner which also provides some LVTTL connections which you can control using a Telnet connection. So I'll be able to reset the TM990 remotely as well. Stuart. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted March 13, 2013 Share Posted March 13, 2013 I have a serial to tcp/ip ethernet box used for alarm panel updates to ip that i use to telnet from the geneve or TI and a US Robotics Vanything modem hooked to them as well. (switch boxed so i can pick which system and which device is connected) But since I have had HDX i rarely use both. I did dial into hidden reef the other day though from the TI to test a term program I found when going through my disks.. Quote Link to comment Share on other sites More sharing options...
