LDA#$AF Posted February 17, 2003 Share Posted February 17, 2003 What's the best way to use the Atari with a 15-pin monitor instead of a television - or can you point me to a location where this is discussed? I am currently using an ATI TV card in my PC then sending the Atari output to the TV card, but it's doesn't give that great of a picture - although it's suitable for watching TV. Is there a TV card that will give me a better picture or some other hardware that works well? Quote Link to comment Share on other sites More sharing options...
Chaos Protocol Posted February 17, 2003 Share Posted February 17, 2003 The most usefull method would probably be through a tv card, monitors run off of RGB and atari (and all other game systems) run off of composite (which is basically S-Video) in order to convert Composite to RGB you need an Up Converter which can be found online for around us$250 (too pricey for my blood) although it would give the best picture and with an input selector you could hook up many game systems for hi-res graphics. so it wouldf look like this: game system1--- game system2-----input switch----Up converter----monitor game system3---/ another thing you could use with this setup is an A/B switch between the converter and the monitor you that you could still use the monitor with your computer I know that you can find input switches at Wal-mart for about us$20 (although it had the names for the current game systems written on the buttons) and an A/B switch can be found online at http://www.cablesnmor.com/goto/video-switch-box.html without the converter the setup would only cost around us$30 but the converter is the expensive part... I know there used to be one called a Cheese Box that was around us$69 anyhow, hope this helps, as you can tell I've thought about all this before Quote Link to comment Share on other sites More sharing options...
