Triads Posted April 4, 2013 Share Posted April 4, 2013 IM sure this has been discussed somewhere/sometime, but my search-fu is not like it used to be, grasshopper. I have a UDS10 and when I try to logon to my BBS thru telnet, I get an ATA then 20 seconds or so I get the +++ and get Disconnected. Im wondering if anyone, like Darklord can help with the lantronix settings. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted April 5, 2013 Share Posted April 5, 2013 Try to set your mode to D6 And your disconnect mode to 40 and if that does not work try 80 Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted April 5, 2013 Share Posted April 5, 2013 IM sure this has been discussed somewhere/sometime, but my search-fu is not like it used to be, grasshopper. I have a UDS10 and when I try to logon to my BBS thru telnet, I get an ATA then 20 seconds or so I get the +++ and get Disconnected. Im wondering if anyone, like Darklord can help with the lantronix settings. Here are the settings I use with the UDS10 on my STacy, to call *out* with: darklord@darkforce:~$ telnet 192.168.1.129 9999 Trying 192.168.1.129... Connected to 192.168.1.129. Escape character is '^]'. *** Lantronix Universal Device Server *** Serial Number 0629604 MAC address 00204A0673A4 Software version V5.8.0.1 (041112) LTX Password :---- Press Enter for Setup Mode *** basic parameters Hardware: Ethernet Autodetect IP addr 192.168.1.129, gateway 192.168.1.1,netmask 255.255.255.0 Telnet config password set *** Security SNMP is enabled SNMP Community Name: public Telnet Setup is enabled TFTP Download is enabled Port 77FEh is enabled Web Server is enabled ECHO is enabled Enhanced Password is disabled *** Channel 1 Baudrate 19200, I/F Mode 4C, Flow 02 Port 10001 Connect Mode : D6 Auto increment source port disabled Remote IP Adr: --- none ---, Port 00000 Disconn Mode : C0 Flush Mode : 00 Terminal name: STacy *** Expert TCP Keepalive : 45s ARP cache timeout: 600s Monitor Mode @ bootup : enabled HTTP Port Number : 80 Change Setup: 0 Server 1 Channel 1 5 Expert 6 Security 7 Factory defaults 8 Exit without save 9 Save and exit Your choice ? HTHs! Quote Link to comment Share on other sites More sharing options...
