the11thdoctor Posted April 8, 2013 Share Posted April 8, 2013 I recently picked up a 1040ST and a couple of different hard drives. Now what? I have a hard drive for the Amiga 500, does the 1040ST hard drives work similar in that I can load that puppy up with software and go to town? If so, is there a program I can use to access the data on a PC with SCSI adapter or a Mac? I am lost. Quote Link to comment Share on other sites More sharing options...
TommyIII Posted April 8, 2013 Share Posted April 8, 2013 Search HDDRIVER. http://www.seimet.de/atari/en/hddriver.html Quote Link to comment Share on other sites More sharing options...
tjlazer Posted April 8, 2013 Share Posted April 8, 2013 do you have a ACSI to SCSI host adaptor for your ST? You need the HDDRIVER software or ICDTOOLS to mount the HD. With HDDRIVER you can format the drive with FAT to be able to read it on a PC. You can use a Zip 100 drive and it works great! Then you can transfer ST software over. But most software is in ST or MSA format so you will just need to transfer it to a real 720k disk and go that route! You can do that on a PC very easily! Use Google or search on here for more details. Quote Link to comment Share on other sites More sharing options...
AnakiMana Posted April 9, 2013 Share Posted April 9, 2013 I would also look into the PP (Peter Putnik) Driver. http://atari.8bitchip.info/pphdr.php Are your hard drives original Atari drives, or do you use SCSI through a add-on card or something? Quote Link to comment Share on other sites More sharing options...
the11thdoctor Posted April 9, 2013 Author Share Posted April 9, 2013 One is a Supradrive 20mb and the other is an ICD (not sure of size) both just connect to 1040ST but the ICD has a SCSI connection on it. Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted April 9, 2013 Share Posted April 9, 2013 I would check out the PP driver - it's worth asking ParanoidLittleMan if his driver will support your drives before you buy it. Then you can get games from his website, or the dbug site. PP driver:- http://atari.8bitchip.info/pphdr.php PP hard disk installed (and adapted games), just like whdload games etc.:- http://atari.8bitchip.info/fromhd.php dbug hard disk installed (and adapted) games:- http://dbug.kicks-ass.net/ Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted April 9, 2013 Share Posted April 9, 2013 (edited) And if you want a nice easy way to get games to and from your ST, and more reliable storage with more space, take a look at Lothareks new UltraSatans:- http://lotharek.pl/product.php?pid=94 Using PP driver you can easily take the SD card out of the drive and read and write to C: using a PC. hddriver will probably do the same job but it's more expensive. Still worth checking out. EDIT: Or there's a floppy emulator you can replace your floppy drive with - that takes SD cards as well and is easy to use to get files to and from the ST. http://lotharek.pl/product.php?pid=48 Edited April 9, 2013 by GadgetUK Quote Link to comment Share on other sites More sharing options...
the11thdoctor Posted April 9, 2013 Author Share Posted April 9, 2013 Thanks for all the info. I was able to get the ICD connected up and booted. It is already full of stuff. It will take me a while to go though it all. Quote Link to comment Share on other sites More sharing options...
