+slx Posted April 12, 2013 Share Posted April 12, 2013 Sorry if this has already been discussed but the search function didn't show any results for SSD. I was thinking about upgrading my TT with an SSD but can't find one with SCSI connector. Is there an easy way to adapt from the connectors available inside the TT to a 'normal' SSD? Anyone done this already. I have a mega ST as well but as it already has an old IDE/TOS 2.06 adapter board I assume it will be simpler as I'll only need a 50-pin/power to 40-pin adapter. Quote Link to comment Share on other sites More sharing options...
atarian1 Posted April 13, 2013 Share Posted April 13, 2013 SSD? You mean solid state drive? Don't bother with the popular SATA drives used in most computers these days as it is overkill for the TT. Best if you just use an SD card drive. I suggest the Suska Gigadrive with internal SCSI adapter. These were designed for ST/TT but could be used on other SCSI computer interfaces. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted April 13, 2013 Share Posted April 13, 2013 (edited) SSD on TT would be expensive overkill . You need SSD, what self is not cheap, then need some SATA-SCSI converter, what I don't know even is exists on market. If yes, price is very high for sure. And what would be benefit of that ? Only faster access times, because no mechanic. Transfer speed will be low, because it is 24 years old TT. You can get almost same with UltraSatan - fast access times and good speed - on TT's ACSI port. Not to mention that SD cards are cheap and available at every corner. P.S. there are no SSDs with 40 pin IDE (PATA) on market, as I know. And even, if yes, you can not use it with TT . "I'll only need a 50-pin/power to 40-pin adapter." - wrong idea, 40 pin is IDE, 50 pin is SCSI . Not possible without converter device - SCSI-IDE converter, what is not cheap. Edited April 13, 2013 by ParanoidLittleMan Quote Link to comment Share on other sites More sharing options...
tjlazer Posted April 17, 2013 Share Posted April 17, 2013 How about this? http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5574883395&toolid=10001&campid=5336500554&customid=&mpre=http%3A%2F%2Fwww.ebay.com%2Fitm%2FAdtron-192MB-50-Pin-3-5-SCSI-Solid-State-Data-Drive-SSD-S35F-192CAB1-%2F200915977709%3Fpt%3DUS_Internal_Hard_Disk_Drives%26hash%3Ditem2ec78685ed Quote Link to comment Share on other sites More sharing options...
lp060 Posted April 18, 2013 Share Posted April 18, 2013 (edited) Main site: http://gfa.atari-use...rs.net/TT030/ My SSD solution: http://gfa.atari-users.net/TT030/htm/hd.htm Other SSD solutions: http://gfa.atari-use...0/htm/ssd.htm Edited April 18, 2013 by lp060 1 Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted April 18, 2013 Share Posted April 18, 2013 Of course, SCSI-CF is also solution. lp060 - can you say something about prices - for me more interesting than pictures Or SCSI-IDE-CF - some people certainly use it. That SCSI SSD of 192MB seems not good deal - too low capacity. Quote Link to comment Share on other sites More sharing options...
lp060 Posted April 18, 2013 Share Posted April 18, 2013 (edited) I only provide the info, its up to whoever reads it to source out the parts, be it ebay or some dealer. Most of the stuff on that page is end of life (obsolete) and prices mean nothing, especially on ebay. I've seen those Microtech units go as high as 400 USD. The ones that are still available have links to the dealers where you should be able to determine the price. It basically comes down to the individual and how much they are willing to pay. Edited April 18, 2013 by lp060 Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted April 19, 2013 Share Posted April 19, 2013 I checked some prices at Artmix. SCSI-CF is 129 $ + 16 $ shipping. There is SCSI-SATA board too for 149 $ . Not too high prices, indeed. In any case, I think that SCSI-CF is better choice than SSD - much cheaper, and nothing slower on TT. Quote Link to comment Share on other sites More sharing options...
TommyIII Posted April 19, 2013 Share Posted April 19, 2013 That place looks like a gold mine for people who use old Samplers like AKAI MPC 60/3000, ensoniq ASR etc... Quote Link to comment Share on other sites More sharing options...
krupkaj Posted April 20, 2013 Share Posted April 20, 2013 (edited) Thanks for pointing to the site. I have just made an order of SCSI-CF to my TT Edited April 20, 2013 by krupkaj Quote Link to comment Share on other sites More sharing options...
+slx Posted April 24, 2013 Author Share Posted April 24, 2013 "I'll only need a 50-pin/power to 40-pin adapter." - wrong idea, 40 pin is IDE, 50 pin is SCSI . Not possible without converter device - SCSI-IDE converter, what is not cheap. Sorry but I wasn't too clear on that. My Mega ST has a 1990s internal alternate ROM/IDE interface board which (as far as I recall) has a "normal" IDE interface as used for 3,5" PATA drives (and one such aging 80MB drive installed). I suppose I should be able to hook up a PATA IDE (such as http://geizhals.at/?cat=hdssd&xf=2646_IDE%7E251_Module#xf_top) using a normal 3,5" to 2,5" adapter. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted April 24, 2013 Share Posted April 24, 2013 I have myself Transcend IDE Flash modul - and it works with Ataris. Don't see why you want 3.5 to 2.5 adapter, when can get IDE Flash with 40 pin connector .. Quote Link to comment Share on other sites More sharing options...
+slx Posted April 25, 2013 Author Share Posted April 25, 2013 (edited) I have myself Transcend IDE Flash modul - and it works with Ataris. Don't see why you want 3.5 to 2.5 adapter, when can get IDE Flash with 40 pin connector .. You're right. I thought 3,5"IDE drives had 50-pin and 40-pin was just for 2,5" drives. I thought all those IDE SSDs have 2,5"-type connectors combining data and power (like in notebooks). Does your Transcend drive need an extra power connector or does it run off whatever voltage is on the IDE bus? Edited April 25, 2013 by slx Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted April 25, 2013 Share Posted April 25, 2013 In case of 40-pin IDE pin 20 is used as 5V lead - but likely your old IDE adapter has no 5V there. Then you can simply use usual molex power connector. By me Transcend works without extra power conn., because I added 5V on pin 20 of self made IDE adapter. Or maybe, if it is accessible, you can self solder 5V on IDE 20 - if there is such at all - often it is cut off, as key-pin. Quote Link to comment Share on other sites More sharing options...
