WIZZARD77 Posted May 4, 2013 Share Posted May 4, 2013 (edited) I recently recieved a 7800 with a composite mod done on it. The picture is clear but the colors bleed to the right about 2 pixels in 2600 mode everything looks fine in 7800 mode. The left 21 pixels are in b&w and they over bleed off of the right most pixels. I changed out R17 with a 2.2k resistor and it helped a little and colors are brighter. Is there somthing I can change to align the colors? Thanks in advance. Edited May 4, 2013 by WIZZARD77 Quote Link to comment Share on other sites More sharing options...
kenfused Posted May 4, 2013 Share Posted May 4, 2013 I have an 8 bit domain board that does that in 7800 mode (I haven't played enough 2600 on it extensively to pay attention if it does it in 7800 mode). Green is the worst and appears about 2 pixels to the right, blue is also a little bad. I don't notice it as much with the other colors but they still probably bleed some or are not quite as noticeable (been a while since I have played it much). It appeared the same even when it was transferred to a different 7800. I would put a different upgrade board in it if it would help. I have thought about trying to pull the rf modulator out to see if that helps. The 8 bit domain board I had for the 5200 looked great in composite. Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted May 4, 2013 Author Share Posted May 4, 2013 The RF modulator has been removed. Mine is the same as yours with the blue and green shifted to the right the most. My mod seems hommade , no board. I plan to use this mostly for 2600 stuff so I hope I can figure this out. Quote Link to comment Share on other sites More sharing options...
Greg2600 Posted May 4, 2013 Share Posted May 4, 2013 is there a couple of pots on the board that can be adjusted? my 2600 needed that, though the 78 was fine. Yurkie did them. I thought though that you really need to have a switch between the 26/78 modes? Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted May 4, 2013 Author Share Posted May 4, 2013 (edited) I thought that the pots only adjust the tint? By the way the mod seems to be the 'easier composite' mod mentioned on the forums here. Edited May 4, 2013 by WIZZARD77 Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted May 4, 2013 Author Share Posted May 4, 2013 UPDATE! I recieved the 7800 from a forum memeber here and while doing some research I found pictures of the mod they did. check it out post #180 if it will help http://atariage.com/forums/topic/127926-easier-7800-composite-video-mod/page__st__175?do=findComment&comment=2484860 . Its a nice clean mod. Quote Link to comment Share on other sites More sharing options...
twoquickcapri Posted May 5, 2013 Share Posted May 5, 2013 What type of TV are you using? The picture was very nice on my Sony CRT. Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted May 5, 2013 Author Share Posted May 5, 2013 (edited) Its a 32 in lcd. The picture is sharp just the colors seem to bleed to the right. I did some seaching and other people seem to be having the same problem. In 7800 mode its perfect, just 2600 mode is a little dark and the color shift thing. Tried on my brothers TV old CRT picture is perfect. Edited May 5, 2013 by WIZZARD77 Quote Link to comment Share on other sites More sharing options...
Greg2600 Posted May 5, 2013 Share Posted May 5, 2013 (edited) As I was saying, many modders have used a cut-off switch to go from 7800 to 2600 mode. I think without doing that, there's issues I think with video. I would also try it on another LCD TV. Edited May 5, 2013 by Greg2600 Quote Link to comment Share on other sites More sharing options...
Trebor Posted May 5, 2013 Share Posted May 5, 2013 Its a 32 in lcd. The picture is sharp just the colors seem to bleed to the right...Tried on my brothers TV old CRT picture is perfect. While you *may* receive some interference from the TIA chip, and a mod that offers the service with a switch is here... http://electronicsen...onServices.html ... Regardless, I believe your issue is more due to using an LCD than a CRT, as you stated on the CRT the picture is perfect. I experienced horrible color issues on two different systems with two completely different Composite mods. Both look great on a CRT, only fair with off colors on LCD/LED/Plasma televisions (All different makes and models). See here: http://atariage.com/...25#entry2699592 Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted May 6, 2013 Author Share Posted May 6, 2013 I fired up the iron last night and composite modded a 2600 I had laying around, same results. Must be the TV. The 7800 side looks pixel perfect but 2600 stuf just doesn't synch right on my TV. mabey I'll have to go s-video. Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted May 6, 2013 Share Posted May 6, 2013 While you *may* receive some interference from the TIA chip, and a mod that offers the service with a switch is here... http://electronicsen...onServices.html ... Regardless, I believe your issue is more due to using an LCD than a CRT, as you stated on the CRT the picture is perfect. I recently had my 7800 modded by this service - with the switch - and it ROCKS. But I never tried in on LCD as I prefer CRT for classic gaming. One day, I'll have to try it. Quote Link to comment Share on other sites More sharing options...
