ParanoidLittleMan Posted May 8, 2013 Share Posted May 8, 2013 I doing some help to people currently developing Atari emulators - Steven Seagal and Nikolas Pomarede - Steem and Hatari . There are still problems with floppy emulation with some titles, and it can be improved. The situation at moment is that only IPF emulation is enough accurate in sector reading speeds . Even Pasti is not good enough with it. Since I'm short with working Ataris at moment, I ask little contribution: just to make simple test in few minutes. All what need is working Atari ST, STE, Mega ST, Mega STE (at 8MHz) with floppy disk in good shape (don't use some with valuable datas on, test writes little on disk) . Test takes about 15 seconds. Usage and some tech. info included. Please post here your machine type and the result. Thanx. FDCT.ZIP. Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted May 9, 2013 Share Posted May 9, 2013 Not ignoring you btw, I will test this on STe at weekend and report back. My STFM has HxC in it and STe isnt connected up atm. Quote Link to comment Share on other sites More sharing options...
Thorvald Posted May 10, 2013 Share Posted May 10, 2013 (edited) 10580 T (Sorry, disregard, this is on 16mhz, now I know how to change it) 10 runs at 8mhz: 12596 T 12568 T 12568 T 12568 T 12540 T 12596 T 12596 T 12596 T 12596 T 12596 T On Atari Mega STE Edited May 10, 2013 by Thorvald Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted May 11, 2013 Share Posted May 11, 2013 Note: this is a Sony model in my STe. This drive was recently cleaned, and had the rotation timing cap replaced. 12540 T 12540 T 12568 T 12540 T 12512 T 12540 T 12568 T 12540 T 12540 T Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted May 12, 2013 Author Share Posted May 12, 2013 Thanx guys. Btw. this test is not much depending from rotation speed. Purpose is to determine WD1772 command exec. delay. Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted May 12, 2013 Share Posted May 12, 2013 OK, thanks for the info - just wanted to clarify the situation of the drive. It works flawlessly but since the timing cap is replaced and heads cleaned the drive is operating like new. This is a factor that might need to be considered if you were looking at read and write speed etc since many drives out there aren't going to perform like they did 20 years ago etc. Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted May 12, 2013 Share Posted May 12, 2013 It struck me a little odd that there are variations in these results btw. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted May 12, 2013 Author Share Posted May 12, 2013 (edited) Variations are small, and it is normal. I have RPM measuring SW here http://atari.8bitchi...o/astopensw.php (near bottom). For most of my drives I got 299-300. Edited May 12, 2013 by ParanoidLittleMan Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted May 12, 2013 Share Posted May 12, 2013 Variations are small, and it is normal. I have RPM measuring SW here http://atari.8bitchi...o/astopensw.php (near bottom). For most of my drives I got 299-300. Yes, that's normal, but in the Sony drives the timing cap starts to loose capacitance and it gradually changes - it can still be working but it tends to actually rotate slower (or faster). The symptom of the Sony in my STe when I got it was that the rotation was wildy inaccurate - it was spinning much faster than normal. Quote Link to comment Share on other sites More sharing options...
