Magic Knight Posted May 16, 2013 Share Posted May 16, 2013 (edited) Ok another silly question but.... does anyone know what this mod would be for?? The only thing i can tell is that it has a red light when the switch is one way and green the other. The Red switch stops you writing to the disk. Is this a Happy controller? or something else (i thought the happy controller needed two swriches). or maybe there is some other mod that does this etc. does this ring a bell with anyone? Edited May 16, 2013 by Magic Knight Quote Link to comment Share on other sites More sharing options...
mimo Posted May 16, 2013 Share Posted May 16, 2013 its a write enable/disable switch. You can write on the reverse side of a floppy without having to notch it. Quote Link to comment Share on other sites More sharing options...
Magic Knight Posted May 16, 2013 Author Share Posted May 16, 2013 its a write enable/disable switch. You can write on the reverse side of a floppy without having to notch it. Cool - thanks Mike Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted May 16, 2013 Share Posted May 16, 2013 (edited) I like to see one setup for XF551. Edited May 16, 2013 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
russg Posted May 17, 2013 Share Posted May 17, 2013 (edited) its a write enable/disable switch. You can write on the reverse side of a floppy without having to notch it. There's a double sided mechanism in it? Must be to write on both sides. Or just allows writing even if the disk isn't notched. Edited May 17, 2013 by russg Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted May 17, 2013 Share Posted May 17, 2013 There's a double sided mechanism in it? Must be to write on both sides. Or just allows writing even if the disk isn't notched. The latter, this allows you to flip the floppy over to write to the backside without having to notch the disk... Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 17, 2013 Share Posted May 17, 2013 (edited) There's a double sided mechanism in it? Must be to write on both sides. Or just allows writing even if the disk isn't notched. The latter. It simply bypasses the write protect notch, and always allows writing to the disk. D'oh - beaten by seconds. Edited May 17, 2013 by Stephen Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted May 17, 2013 Share Posted May 17, 2013 D'oh - beaten by seconds. I had the distinct feeling that I'd get the popup saying "There is another reply to this thread" before I clicked Quote Link to comment Share on other sites More sharing options...
