GadgetUK Posted May 22, 2013 Share Posted May 22, 2013 (edited) Just thought I would point this out, someone on EBAY selling a small kit thats similar to PeST. I've just recieved mine - not built it yet. http://bit.ly/12Npsd7 Works on ST / Amiga / Falcon and allows use of PS/2 type mouse. Edited May 22, 2013 by GadgetUK Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted May 25, 2013 Author Share Posted May 25, 2013 (edited) Here's mine assembled. It came with a piece of white tubing to conceal the PCB but nothing to stop it floating out of the ends, so I used two gromets squashed flat so it snuggly fits and holds each end in. I configured mine for my Amiga, I might get another for the ST - it's just a case of switching two wires around so if you've got a small enough double throw switch you could put a toggle for ST / Amiga. Edited May 25, 2013 by GadgetUK 1 Quote Link to comment Share on other sites More sharing options...
+rdemming Posted May 26, 2013 Share Posted May 26, 2013 Hi GadgetUK, It seems an interesting device but the 9-pin mouse connector seems far too big to fit in the mouse port of a 1040ST because of the screws at the side of the connector. Did you use a mouse extension cable or does it fit? Robert Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted May 26, 2013 Author Share Posted May 26, 2013 That's a good point, tbh I only ever use mouse and joystick extenders with the ST as its a pain swapping them and you only end up needing to resolder the ports again after lots of use... Quote Link to comment Share on other sites More sharing options...
Gunstar Posted May 27, 2013 Share Posted May 27, 2013 (edited) I'd thought about getting something like this, similar stuff has been around for decades, I think you can buy PS/1&2 mice adapters from Best E. and B&C. But instead, I think I'm going to get a USB adapter that's out for Atari 16/32 computers, which ironically, the only thing they are currently cable of is using cordless USB mice with them (the only driver developed that is) and I have one for my PC that I could use with my Falcon. I think they plug into the cartridge port. Of course I have a lot of PS/1&2 mice around also... But I've no immediate need, my ST mouse is still working. Edited May 27, 2013 by Gunstar Quote Link to comment Share on other sites More sharing options...
+rdemming Posted May 28, 2013 Share Posted May 28, 2013 That's a good point, tbh I only ever use mouse and joystick extenders with the ST as its a pain swapping them and you only end up needing to resolder the ports again after lots of use... It is indeed painful to swap. Thats why I added an extra 9 pin connector at the side of my 1040ST were I can plug in a joystick. Using a toggle switch I can switch between the mouse and the joystick. Robert Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted May 28, 2013 Author Share Posted May 28, 2013 (edited) Very nice! How exactly is that toggle switch working, are you buffering input through some logic gate or something? Edit: toggling ground perhaps? Edited May 28, 2013 by GadgetUK Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted August 9, 2013 Author Share Posted August 9, 2013 Since i've got into PIC programming I am thinking about producing a PS/2 socket which could be fitted into an ST case, and have it auto switch between the primary joystick port. Just need to think of the best place to mount such a PCB. I am also wondering what other interesting things we could do with PIC chips in an ST, any ideas? Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted August 9, 2013 Share Posted August 9, 2013 The only trouble is that it's now been *years* since new PS/2 mice have been available. A modern USB adaptor would be ideal. This adaptor.... eBay Auction -- Item Number: 120784673053 .....has been written about many times in this thread..... http://atariage.com/forums/topic/163201-usb-to-atari-mouse-adapter/ .....but it's not really "USB." It's appealing to the PS/2 character of old mice that are *both* USB and PS/2, but it doesn't require the USB-to-PS/2 adaptor. It works great, and I highly recommend it, but the price has been rising steadlly, while commensurately, the number of mice that are compatible continues to dwindle. I say get them while you can, and make for sure that it's an optical mouse. Otherwise, you may as well get a new/rebuilt Atari STM1 original mouse. Quote Link to comment Share on other sites More sharing options...
