boxpressed Posted May 24, 2013 Share Posted May 24, 2013 I have an Atari 800 that I'm using for parts because it has no sound and acted as though the space bar was always pressed down. I needed a POKEY for my Cuttle Cart 2, so I harvested the one from the 800. The CC2 wouldn't work after I installed the POKEY but worked fine after I removed it. I went to Wikipedia and read that the POKEY is also responsible for scanning the keyboard. Is it possible that the bad POKEY was causing the space bar issue? I read elsewhere that many 800s had bad space bars because Defender players used it so ofter for hyperspace. Thanks for any advice. Quote Link to comment Share on other sites More sharing options...
+tf_hh Posted May 24, 2013 Share Posted May 24, 2013 (edited) POKEY uses a simple 8x8 matrix for the keys. So if only one key is failed, then this mostly a mechanical issue of the keyboard itself - sometimes often with the Atari 800, correct. You will find a lot of hints to fix this here on AtariAge. Only a strange idea... are you sure that you put the POKEY in the right direction into your cart? Why I´m writing this... a lot of very old POKEYs - mostly used in the 400/800 computers - have an upside-down marking on the IC - so if you use the marking as navigation, the IC is inserted wrong in these cases. Examine your POKEY again. There´s a notch on the "left" side, which indicates pin 1. Otherwise you will find a little dot on the lower left side - this also indicates pin 1. When you locate pin 1 on the lower left side and the marking is upside down.. try again Edited May 24, 2013 by tf_hh Quote Link to comment Share on other sites More sharing options...
boxpressed Posted May 24, 2013 Author Share Posted May 24, 2013 Thanks for the quick reply. I guess the keyboard has failed, then. It's the Mitsumi keyboard that I've read people complaining about. I'm almost positive that I put the POKEY in the CC2 correctly. I didn't notice the dot, but the "notch" is on the same side, and I used the diagram in the CC2 manual. Because there was no sound, maybe the POKEY *and* the keyboard are bad. Quote Link to comment Share on other sites More sharing options...
