+SvOlli Posted May 25, 2013 Share Posted May 25, 2013 Before I go boldly reinventing the wheel again: Let's say, I've got a sprite of which I know that it is on position 55, and I want to move that sprite to position 60. Then I need a routine that converts that to the correct HMxx value. As a first shot, I'd come up with something like: clc lda newpos adc #$07 ; for later offset in table sec sbc oldpos tay lda hmtable,y ; table containing the 16 possible values for sprite movement from 7-to-left to 8-to-right sta HMxx Anyone found already a nice cpu cycle optimized solution for this question? Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted May 25, 2013 Share Posted May 25, 2013 Nothing great, but I think you can go at least 2 cycles faster like this: ;HMxx LEFT_7 = $70 LEFT_6 = $60 LEFT_5 = $50 LEFT_4 = $40 LEFT_3 = $30 LEFT_2 = $20 LEFT_1 = $10 NO_MOTION = $00 RIGHT_1 = $F0 RIGHT_2 = $E0 RIGHT_3 = $D0 RIGHT_4 = $C0 RIGHT_5 = $B0 RIGHT_6 = $A0 RIGHT_7 = $90 RIGHT_8 = $80 sec lda newpos sbc oldpos and #$0F ; If X=$0F here, use SBX #0, and lda HmoveTab,X tay lda HmoveTab,Y sta HMxx HmoveTab: .byte NO_MOTION ; Y=0 .byte RIGHT_1 .byte RIGHT_2 .byte RIGHT_3 .byte RIGHT_4 .byte RIGHT_5 .byte RIGHT_6 .byte RIGHT_7 .byte RIGHT_8 .byte LEFT_7 ; Y=9 .byte LEFT_6 ; A .byte LEFT_5 ; B .byte LEFT_4 ; C .byte LEFT_3 ; D .byte LEFT_2 ; E .byte LEFT_1 ; F Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted May 25, 2013 Share Posted May 25, 2013 This might work, still have to test it some more... sec lda newpos sbc oldpos asl adc #2 asl asl asl sta HMxx There is also the problem of wrap around, i.e. old position = 2, new position = 158, want LEFT_4 for HMxx. I'm not sure if any of these routines handle that. Quote Link to comment Share on other sites More sharing options...
Joe Musashi Posted May 25, 2013 Share Posted May 25, 2013 Nothing great, but I think you can go at least 2 cycles faster like this: sec lda newpos sbc oldpos and #$0F ; If X=$0F here, use SBX #0, and lda HmoveTab,X tay lda HmoveTab,Y sta HMxx HmoveTab: .byte NO_MOTION ; Y=0 .byte RIGHT_1 .byte RIGHT_2 .byte RIGHT_3 .byte RIGHT_4 .byte RIGHT_5 .byte RIGHT_6 .byte RIGHT_7 .byte RIGHT_8 .byte LEFT_7 ; Y=9 .byte LEFT_6 ; A .byte LEFT_5 ; B .byte LEFT_4 ; C .byte LEFT_3 ; D .byte LEFT_2 ; E .byte LEFT_1 ; F If the rest of the code allows, you could also split up the table and arrange it so that LEFT is at the top of a page and RIGHT at the bottom. This would get rid of the AND $0F. Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted May 25, 2013 Share Posted May 25, 2013 Actually, reversing the old and new postions seems to work: sec lda oldpos sbc newpos asl asl asl asl sta HMxx Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted May 26, 2013 Author Share Posted May 26, 2013 sec lda oldpos sbc newpos asl asl asl asl sta HMxx That was the same idea, I had in bed last night: ; a already contains position from calculation sec eor #$ff adc oldpos asl asl asl asl sta HMxx And it leaves X and Y untouched. Quote Link to comment Share on other sites More sharing options...
