accousticguitar Posted June 13, 2013 Share Posted June 13, 2013 Thanks accousticguitar! Having a wee bit of memory issue here. I'm not that experienced with memory saving tricks so I'm asking, is there anything I can do with my code to save some memory? Ram or rom? Although I'm not sure I could help either way. Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted June 13, 2013 Author Share Posted June 13, 2013 (edited) Rom I believe. It says "-992 bytes of ROM space left in bank 1" I'm using a lot of multiples in each screen. Perhaps there is a way to only have the codes in level 1 and have the rest of the levels grab the codes and re-use them? Edited June 13, 2013 by Rabbit 2600 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted June 13, 2013 Share Posted June 13, 2013 Thanks accousticguitar! Having a wee bit of memory issue here. I'm not that experienced with memory saving tricks so I'm asking, is there anything I can do with my code to save some memory? SOURCE - default.bas I have no idea how or why this kind of declaration is working/compiling. dim _P1_L_R = player1x.a I don't think bB can handle decimals like that. if _P1_U_D < _P0_U_D then _P1_U_D = _P1_U_D + 0.04 I guess what I'm saying is, you might be running into compiler errors instead of actually running out of RAM. Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted June 13, 2013 Author Share Posted June 13, 2013 I don't know either why it works, I just know it does =) Hm, perhaps. This is the whole message I get after adding the 4th screen: "DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left in bank 1 bytes of ROM space left in bank 2 -992 bytes of ROM space left in bank 1 segment: 1fd4 eqm vs current org: 23b4 default.bas.asm (4552): error: Origin Reverse-indexed. Aborting assembly Errors were encountered during assembly." Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted June 13, 2013 Share Posted June 13, 2013 I have no idea how or why this kind of declaration is working/compiling. dim _P1_L_R = player1x.a I don't think bB can handle decimals like that. if _P1_U_D < _P0_U_D then _P1_U_D = _P1_U_D + 0.04 Read all about it: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#fixedpoint Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted June 13, 2013 Author Share Posted June 13, 2013 Ahh, so it's called fixedpoints. Now I know =) Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted June 13, 2013 Author Share Posted June 13, 2013 Could perhaps a gosub or something be used to save me some memory? Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted June 13, 2013 Share Posted June 13, 2013 Could perhaps a gosub or something be used to save me some memory? yes, anything that is repeated can be handled like that and it will save a lot of rom. Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted June 13, 2013 Author Share Posted June 13, 2013 Okay. Then that is what I should focus on. I'm totally inexperienced with gosubs. Would this work? Level_1 _sub1 dim _P1_L_R = player1x.a dim _P1_U_D = player1y.b dim _P2_L_R = player2x.c dim _P2_U_D = player2y.d dim _P3_L_R = player3x.e dim _P3_U_D = player3y.f dim _P4_L_R = player4x.i dim _P4_U_D = player4y.j dim _P0_L_R = player0x.k dim _P0_U_D = player0y.l return Level_2 gosub _sub1 Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted June 13, 2013 Share Posted June 13, 2013 For starters, I doubt you need to define the players more than once (but like I say, I'm really rusty). player1: %00011110 %00011011 %00111101 %00111100 %01111110 %01111110 %01111110 %11111111 %11011011 %11000011 %10100101 %10111101 %10011001 %10111101 %10011001 %10001101 end player2: %00011110 %00011011 %00111101 %00111100 %01111110 %01111110 %01111110 %11111111 %11011011 %11000011 %10100101 %10111101 %10011001 %10111101 %10011001 %10001101 end player3: %00011110 %00011011 %00111101 %00111100 %01111110 %01111110 %01111110 %11111111 %11011011 %11000011 %10100101 %10111101 %10011001 %10111101 %10011001 %10001101 end player4: %00011110 %00011011 %00111101 %00111100 %01111110 %01111110 %01111110 %11111111 %11011011 %11000011 %10100101 %10111101 %10011001 %10111101 %10011001 %10001101 end Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted June 13, 2013 Share Posted June 13, 2013 Thanks R.T. I knew about it but completely ignored it in my own programming. Talk about tunnel vision! A big help is defining boolean variables where possible. In my current game each screen has various properties. I use one 8-bit variable and end up with 8 separate switches for different aspects of the room: dim roomstyle = c def openeast=roomstyle{0} def openwest=roomstyle{1} def opennorth=roomstyle{2} def opensouth=roomstyle{3} def solid=roomstyle{4} def loweropen=roomstyle{5} def doorexit=roomstyle{6} def toprowglow=roomstyle{7} Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted June 13, 2013 Share Posted June 13, 2013 I don't think you want the subroutine in level 1. It should be below the levels in my opinion. It could get caught in a loop the way you have it now. I would try something like this. (Of course it gets more complicated with multiple banks. I don't quite remember how that works but I think you also have to specify which bank the subroutine is in). Level_1 gosub SR1 (playfield, game logic, drawscreen, etc.) goto Level_1 Level_2 gosub SR1 (playfield, game logic, drawscreen, etc.) goto Level_2 SR1 dim _P1_L_R = player1x.a dim _P1_U_D = player1y.b dim _P2_L_R = player2x.c dim _P2_U_D = player2y.d dim _P3_L_R = player3x.e dim _P3_U_D = player3y.f dim _P4_L_R = player4x.i dim _P4_U_D = player4y.j dim _P0_L_R = player0x.k dim _P0_U_D = player0y.l return Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted June 13, 2013 Author Share Posted June 13, 2013 Okay, I took out the sprites and colors from all levels except the first one. That gave me some much needed space. Gonna see if I can get the hang of gosub now. Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted June 13, 2013 Author Share Posted June 13, 2013 Hm, I just came up with an idea. Instead of having a bunch of separate screens, couldn't 1 screen be used instead, and each time you leave and re-enter the room pfpixels would be randomized and give the appearance of many different rooms? Quote Link to comment Share on other sites More sharing options...
bogax Posted June 13, 2013 Share Posted June 13, 2013 Hm, I just came up with an idea. Instead of having a bunch of separate screens, couldn't 1 screen be used instead, and each time you leave and re-enter the room pfpixels would be randomized and give the appearance of many different rooms? not with the multisprite kernel the playfield is in rom and the playfield itself can't be changed you can only change the whole playfield to a different one is there any difference between the levels besides playfields? if not you should have a single loop and change only the playfield when you change levels even if other stuff does change you should probably have a single loop and just change the stuff that needs when you change levels. I told you before I'll tell you again take al that crap out of the loop you only have to set the playfield once when you change it you don't need to do it every time you go through the loop same for the players. there are things you have to set every time you do a drawscreen but if you don't need to set something why waste time doing it? 1 Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted June 13, 2013 Share Posted June 13, 2013 not with the multisprite kernel the playfield is in rom and the playfield itself can't be changed you can only change the whole playfield to a different one is there any difference between the levels besides playfields? if not you should have a single loop and change only the playfield when you change levels even if other stuff does change you should probably have a single loop and just change the stuff that needs when you change levels. I told you before I'll tell you again take al that crap out of the loop you only have to set the playfield once when you change it you don't need to do it every time you go through the loop same for the players. there are things you have to set every time you do a drawscreen but if you don't need to set something why waste time doing it? Good points. Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted June 14, 2013 Author Share Posted June 14, 2013 (edited) Very good point bogax. It's a bad habbit I've adopted and I will do my best to break away with it. And the only difference is the playfields. Edited June 14, 2013 by Rabbit 2600 Quote Link to comment Share on other sites More sharing options...
