idflyfish Posted June 15, 2013 Share Posted June 15, 2013 Hello, I was wondering if anyone would know where a fella might purchase a cable to connect my nanoPeb to my TI-99/4a? I am planning on making a simple lego case for it and I don't want to connect it directly to the computer. Quote Link to comment Share on other sites More sharing options...
idflyfish Posted June 15, 2013 Author Share Posted June 15, 2013 Here's one. Anyone use something like this and has a recommendation? http://www.iec-usa.com/cgi-bin/iec/framefly?;L1170 Quote Link to comment Share on other sites More sharing options...
Manic1975 Posted June 15, 2013 Share Posted June 15, 2013 Look at topic I started: http://atariage.com/forums/topic/212991-cf7-box/ There I put pictures of my CF7+ in the box and there are pictures of cable to conect cf7 with TI 99/4a. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted June 15, 2013 Share Posted June 15, 2013 Look at topic I started: http://atariage.com/...212991-cf7-box/ There I put pictures of my CF7+ in the box and there are pictures of cable to conect cf7 with TI 99/4a. Unfortunately, that cable will not work with the nanoPEB. Connecting the nanoPEB to the side port of the console would require a card-edge at the end of the CF7+ cable that has the IDE connector. ...lee Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted June 15, 2013 Share Posted June 15, 2013 Here's one. Anyone use something like this and has a recommendation? http://www.iec-usa.c...framefly?;L1170 That cable has 36-pin connectors for the cartridge port. What you need is a similar cable with 44-pin connectors for the side I/O port. ...lee Quote Link to comment Share on other sites More sharing options...
idflyfish Posted June 15, 2013 Author Share Posted June 15, 2013 Right then. 44 pin card-edge on one end. I'll keep looking. Quote Link to comment Share on other sites More sharing options...
Manic1975 Posted June 15, 2013 Share Posted June 15, 2013 (edited) That cable has 36-pin connectors for the cartridge port. What you need is a similar cable with 44-pin connectors for the side I/O port. ...lee My CF7+ on TI side has 44 pin connector. But first two and last two pins are not connected to IDE cable. Same is on CF7+ side. Also I saw pictures where people have connected nano PEB on IDE cable. Lee do you know how to use longer IDE cable? My is short but I don't know is there any way to use longer one. If I put longer my CF7 stop to work correctly. Edited June 15, 2013 by Manic1975 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted June 15, 2013 Share Posted June 15, 2013 I'm also looking for a cable, but it's not easy to find. Just finding a 44 pin card edge connector is difficult. Perhaps that's why the connector on my nanoPEB looks like it was cut from a larger connector and then the cut edge was melted? Perhaps you need to make your own adapters for a standard ATA/IDE cable? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted June 15, 2013 Share Posted June 15, 2013 ... Lee do you know how to use longer IDE cable? I do not. My is short but I don't know is there any way to use longer one. If I put longer my CF7 stop to work correctly. My guess is that there's too much signal loss with longer cables, but I must defer to others here who are better versed in hardware matters. ...lee Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted June 15, 2013 Share Posted June 15, 2013 (edited) Here's the IEC cable you want to extend the side port: http://www.iec-usa.com/cgi-bin/iec/framefly?;L1172 All of their cables work well, and they've supported the TI since the early 80s! Edited June 15, 2013 by Ksarul Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted June 15, 2013 Share Posted June 15, 2013 Note that you may want to ask them for a short one (say, 6-12 inches) when you order. That should deal with signal propagation issues if the 18-inch cable is too long. They will do custom builds, as their cables are generally fabricated on an as-needed basis. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted June 15, 2013 Share Posted June 15, 2013 I'm also looking for a cable, but it's not easy to find. Just finding a 44 pin card edge connector is difficult. Perhaps that's why the connector on my nanoPEB looks like it was cut from a larger connector and then the cut edge was melted? Perhaps you need to make your own adapters for a standard ATA/IDE cable? You are correct. Cable-mount card-edge (0.1" on center, I believe) connectors with more than 44 contacts are, indeed, easier to find. ...lee Quote Link to comment Share on other sites More sharing options...
unhuman Posted June 15, 2013 Share Posted June 15, 2013 Now I want one too! Quote Link to comment Share on other sites More sharing options...
