IntellivisionDude Posted June 17, 2013 Share Posted June 17, 2013 http://www.youtube.com/watch?v=FLD-M8KpMvk 2 Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted June 19, 2013 Share Posted June 19, 2013 i still think corrosion is a probability of your key problem. isopropyl alcohol and a tooth brush would probably fix it. a key that does multiple key hits would probably be caused by that. a bad chip, maybe but with a keyboard where liquid could easily get in seems more likely. have you ever tried the keyboard on another ecs to verify if it is ecs or the keyboard isthe problem? Quote Link to comment Share on other sites More sharing options...
IntellivisionDude Posted June 19, 2013 Author Share Posted June 19, 2013 i still think corrosion is a probability of your key problem. isopropyl alcohol and a tooth brush would probably fix it. a key that does multiple key hits would probably be caused by that. a bad chip, maybe but with a keyboard where liquid could easily get in seems more likely. have you ever tried the keyboard on another ecs to verify if it is ecs or the keyboard isthe problem? Nope have not. Maybe one day when i'm feeling more daring i'll attempt to take it apart. lol Quote Link to comment Share on other sites More sharing options...
Ignorama Posted June 19, 2013 Share Posted June 19, 2013 Is it possible to play Melody Blaster with the ECS only? If yes, is there a shedule which explains the keys? Quote Link to comment Share on other sites More sharing options...
Intymike Posted June 19, 2013 Share Posted June 19, 2013 Is it possible to play Melody Blaster with the ECS only? If yes, is there a shedule which explains the keys? It works only with the keyboard and this needs the ECS. Quote Link to comment Share on other sites More sharing options...
Ignorama Posted June 19, 2013 Share Posted June 19, 2013 (edited) @ MikeI tested it myself and it works with my ECS. Its unplayable, because the keys are completely upside down, but all keys are available. Melody Blaster uses 34 keys, the keyboard has 49 keys, but 15 are unused. I figured out the 39 games which you need for playing Melody Blaster, but it also recognized that there are 15 keys left over and every key makes a different sound. So every single key from the Piano-Controller is availabe on the typewriter keypad (both systems have 49 keys)So the ECS is a full working keyboard-controller, its just very very hard to play with it. I am going to make a nice graphic which key on the ECS keypad plays which tonal, I'll post it probably tomorrow. Edit: I attached my sketch. Its hard to read, but if you are good in reading ugly handwritings you may understand it. I will make a better readable version. And now enjoy Melody Blaster with ECS only (by the way: Leertaste is the space key in Germany) Edited June 19, 2013 by Ignorama Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted June 19, 2013 Share Posted June 19, 2013 @ MikeI tested it myself and it works with my ECS. Its unplayable, because the keys are completely upside down, but all keys are available. Melody Blaster uses 34 keys, the keyboard has 49 keys, but 15 are unused. I figured out the 39 games which you need for playing Melody Blaster, but it also recognized that there are 15 keys left over and every key makes a different sound. So every single key from the Piano-Controller is availabe on the typewriter keypad (both systems have 49 keys)So the ECS is a full working keyboard-controller, its just very very hard to play with it. I am going to make a nice graphic which key on the ECS keypad plays which tonal, I'll post it probably tomorrow.Edit: I attached my sketch. Its hard to read, but if you are good in reading ugly handwritings you may understand it. I will make a better readably version. And now enjoy Melody Blaster with ECS only (by the way: Leertaste is the space key in Germany) well if thats the case then intvdude you need to play the game with a keyboard instead of synthesizer and verify your ecs is ok Quote Link to comment Share on other sites More sharing options...
Ignorama Posted June 19, 2013 Share Posted June 19, 2013 Thats the point I forgot to mention: Every single key from the keyboard belongs to one specific key from the Synthesizer, so this is the best way to check if the Keyboard is working or not. Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted June 19, 2013 Share Posted June 19, 2013 Thats the point I forgot to mention: Every single key from the keyboard belongs to one specific key from the Synthesizer, so this is the best way to check if the Keyboard is working or not. i assume you could probably hook up 2 controllers as well and get the same effect Quote Link to comment Share on other sites More sharing options...
Ignorama Posted June 20, 2013 Share Posted June 20, 2013 Here is the "manual" how to play Melody Blaster with ECS only. I dont have a Synthesizer, so I cant test, but I am pretty sure that you can play every ECS game with the Synthesizer instead of the keyboard. Complete new gameplay experiences 3 Quote Link to comment Share on other sites More sharing options...
IntellivisionDude Posted June 20, 2013 Author Share Posted June 20, 2013 I just tested it and my ECS is not the problem. Each key played and sounded correct. Quote Link to comment Share on other sites More sharing options...
Ignorama Posted June 20, 2013 Share Posted June 20, 2013 (edited) @ IntellivisionDude So you can confirm that my graphic is correct? I made a little mistake while drawing it and so I had to fix that with Paint, but I wasnt sure if it was really a mistake or maybe the key-layout for Melody Blaster changes radomly on the ECS. Edited June 20, 2013 by Ignorama Quote Link to comment Share on other sites More sharing options...
IntellivisionDude Posted June 20, 2013 Author Share Posted June 20, 2013 @ IntellivisionDude So you can confirm that my graphic is correct? I made a little mistake while drawing it and so I had to fix that with Paint, but I wasnt sure if it was really a mistake or maybe the key-layout for Melody Blaster changes radomly on the ECS. I already put the ECS away. Sorry @Pimp, i took apart the synthesizer and took off a couple of the trouble keys but don't see any corrosion or anything. Quote Link to comment Share on other sites More sharing options...
IntellivisionDude Posted June 20, 2013 Author Share Posted June 20, 2013 I put the synthesizer back together. I'm afraid i'll mess it up more. The keys are a pain to put back on and the clips look like they can break easy. Quote Link to comment Share on other sites More sharing options...
Ignorama Posted June 20, 2013 Share Posted June 20, 2013 I wonder of the developers of Guitar Hero and Rock Band were inspired by Melody Blaster. Of cause they are improved versions, but the gameplay is still the same. Quote Link to comment Share on other sites More sharing options...
+JasonlikesINTV Posted June 20, 2013 Share Posted June 20, 2013 I wonder of the developers of Guitar Hero and Rock Band were inspired by Melody Blaster. Of cause they are improved versions, but the gameplay is still the same. Don't forget one of the greatest games of all time: Parappa the Rapper I used to love that on PS1! Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted June 20, 2013 Share Posted June 20, 2013 I already put the ECS away. Sorry @Pimp, i took apart the synthesizer and took off a couple of the trouble keys but don't see any corrosion or anything. the corrosion would probably be by a chip or something. not neccessarily by the keys since the contacts are farther spread apart there. Quote Link to comment Share on other sites More sharing options...
voltron Posted September 5, 2013 Share Posted September 5, 2013 http://www.youtube.com/watch?v=FLD-M8KpMvk We need an intellidrunk version of this video. Quote Link to comment Share on other sites More sharing options...
IntellivisionDude Posted September 6, 2013 Author Share Posted September 6, 2013 We need an intellidrunk version of this video. Quote Link to comment Share on other sites More sharing options...
