Astharot Posted July 17, 2013 Share Posted July 17, 2013 Hello everyone, a friend give me his gram Kracker for a check because no work.. after many control i discovered that eprom with program no work well and battery is dead.. there is a gentelman that have the program in bin format of eprom .. ? I hope that change eprom the GK return at work again,, The eprom had write on GK01 v1.0 Thank for all help that give me. Hermann Quote Link to comment Share on other sites More sharing options...
OX. Posted July 17, 2013 Share Posted July 17, 2013 (edited) Not an expert on Gram Krackers but don't eproms only have a guaranteed life of about 15 years so would say that definitely needs a re-burn and the battery life will probably be far less so yes renew that also, old hardware like this will always needs reinvigorating as time takes it's toll. Sounds like it's done very well to get this far. Edited July 17, 2013 by OX. Quote Link to comment Share on other sites More sharing options...
marc.hull Posted July 18, 2013 Share Posted July 18, 2013 (edited) Hello everyone, a friend give me his gram Kracker for a check because no work.. after many control i discovered that eprom with program no work well and battery is dead.. there is a gentelman that have the program in bin format of eprom .. ? I hope that change eprom the GK return at work again,, The eprom had write on GK01 v1.0 Thank for all help that give me. Hermann You should probably dump the EPROM and compare it to the binary first to make sure your not chasing a dead end. If it is the EPROM then that is easy enough itself. As I am sure you have seen the GK is actually two boards (at least the one I had for a bit) mounted together with snap header pins and sockets. very easy to bend or break a pin when assembling or dissembling. Pretty much the same as a blown trace at that point. Good luck and keep posting your progress. Edited July 18, 2013 by marc.hull Quote Link to comment Share on other sites More sharing options...
RXB Posted July 18, 2013 Share Posted July 18, 2013 I seem to remember someone that said they had the GRAMKRACKER EPROM code, do not remember where it was. Quote Link to comment Share on other sites More sharing options...
