3DOMan Posted July 24, 2013 Share Posted July 24, 2013 The topic pretty much says it all. It will manage to load both games, but starts crashing out, giving disk read errors. The rest of the games on the system work just fine. Somebody suggested the lid sensor might be a problem. Seems logical so far. How do I go about cleaning/fixing this? Or could it be a more tehcnical problem, maybe the system is due for a laser replacement? Or need a pot adjusted? Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted July 24, 2013 Share Posted July 24, 2013 I doubt it is the lib sensor as I see no reason why that would be only be consistent problem to specific disks and not all disks. Could be a laser problem, have you tried cleaning your disks in case it is just a finger print problem? Quote Link to comment Share on other sites More sharing options...
3DOMan Posted July 24, 2013 Author Share Posted July 24, 2013 That was my thought initially, except Baldies is literally brand new right out of the package, and Battlemorph isn't terribly scratched either Quote Link to comment Share on other sites More sharing options...
3DOMan Posted July 25, 2013 Author Share Posted July 25, 2013 (edited) In an update to this, I managed to fix it. The little contact plate where the lid sensor is was all bent downward, probably from years of use. I re-bent it the opposite direction(carefully) so now it makes better contact when you close the lid. And now it loads Baldies just fine. Testing Battlemorph next. Battlemorph works, it will load all of the levels except the PLANET PENTER level. The others work just fine though. Has anybody else ever encountered this problem? I'm beginning to think I may just have a defective disc? The disc is not horribly scratched or anything. Odd Edited July 25, 2013 by 3DOMan Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted July 26, 2013 Share Posted July 26, 2013 Battlemorph works, it will load all of the levels except the PLANET PENTER level. The others work just fine though. Has anybody else ever encountered this problem? I'm beginning to think I may just have a defective disc? The disc is not horribly scratched or anything. Odd Might get more answers to that if you post in the Jaguar forum. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted July 26, 2013 Share Posted July 26, 2013 He might also get a knife in the back from all the people complaining about all the other people complaining about the shoddy Jaguar CD More on topic - copy the CD with Discjuggler to a CDR and try the copy - a modern drive will most likely read the disc correctly (even with scratches) whereas the JagCD will just go 'ah feck. crash ????????' Quote Link to comment Share on other sites More sharing options...
3DOMan Posted July 26, 2013 Author Share Posted July 26, 2013 I thought that myself. Though I heard JagCD does not handle CD-Rs well. I trust you are speaking from experience? Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted August 12, 2013 Share Posted August 12, 2013 OK I had this exact same problem. It would read every game except Battlemorph. I could load it but it would only load certain levels. I changed the drive mech and everything is perfect. It also runs much quieter. There used to be a guy in the jaguar forums with a link to buy them in his signiture. Quote Link to comment Share on other sites More sharing options...
