orion1052003 Posted July 24, 2013 Share Posted July 24, 2013 I have been trying to do some of the chapter exercises in the Molesworth book, and have run into trouble on the BARGRAPH program that mixes Assembly with XB. The program wants you to load a file from an Editor/Assembler disk DSK1.BSCSUP and an object file DSK1.BGRAPH/O "from your "practice disk" that has the typed-in BARCODE basic program on it. I copied the E/A file over to the practice disk to avoid disk-swapping. I got an error in line 320. It was the same error when I actually did swap out the disks when prompted, so that should not be an issue. Other particulars are the BARGRAPH program was in TI BASIC and I tried to convert it to XB, the object file DSK1.BGRAPH has something to do with drawing the bar graph on screen, I assembled DSK1.BGRAPH/S in the E/A and got zero errors. Here is the current listing at the bottom. Any suggestions appreciated. 10 !BARGRAPH 100 REM BAR GRAPH DEMONSTRATION 110 REM TI BASIC W/MINI-MEMORY OR 120 REM EDITOR/ASSEMBLER MODULE 130 REM BY PHIL WEST AND BERNIE ELSNER 140 CALL CLEAR 150 RANDOMIZE 160 PRINT "PLACE FILE BGRAPH/O IN" 170 PRINT "DISK DRIVE ONE THEN PRESS ENTER" 180 INPUT E$ 190 PRINT "LOADING MACHINE LANGUAGE PLEASE WAIT" 200 CALL INIT 210 CALL LOAD(28706,0,0,0,0,0,0,0,0) 220 CALL LOAD("DSK1.BGRAPH/O") 230 PRINT "WHICH MODULE ARE YOU USING? ENTER" 240 PRINT " E - FOR EDITOR/ASSEMBLER M - FOR MINI-MEMORY" 250 INPUT E$ 260 IF E$="M" THEN 350 270 IF E$<>"E" THEN 250 280 PRINT "PLACE EDITOR/ASSEMBLER" 290 PRINT "DISK A IN DRIVE ONE THEN PRESS ENTER" 300 INPUT E$ 310 CALL CLEAR 320 CALL LOAD("DSK1.BSCSUP") 330 REM RESERVE SPACE FOR CHARACTER DEFINITION 340 REM IN MACHINE LANGUAGE ROUTINE 350 FOR I=104 TO 159 360 CALL CHAR(I,"") 370 NEXT I 380 CALL CLEAR 390 CALL SCREEN(15) 400 PRINT "MICRO RETAIL PROFITS 1982-84" 410 PRINT " (Q)UIT OR ®EPEAT" 420 F=L 430 FOR 1=1 TO 28 440 F=F*1.195 450 CALL LINK("BGRAPH",I,1,F) 460 NEXT I 470 FOR D=L TO 800 480 NEXT D 490 FOR 1=1 TO 28 500 CALL VCHAR(1,1+2,32,20) 510 CALL LINK("BGRAPH",I,6,F) 520 F=F/1.195 530 NEXT I 540 FOR D=L TO 800 550 NEXT D 560 CALL HCHAR(1,1,32,640) 570 REM GENERATE RANDOM PARAMETERS 580 FOR 1=1 TO 28 590 B=INT(RND*7+1) 600 C=INT(RND*160+1) 610 REM DRAW BAR WITH M/L ROUTINE 620 CALL LINK("BGRAPH",I,B,C) 630 NEXT I 640 CALL KEY(0,K,S) 650 IF K=82 THEN 380 660 IF K<>81 THEN 640 670 END Quote Link to comment Share on other sites More sharing options...
RXB Posted July 24, 2013 Share Posted July 24, 2013 XB and TI Basic do not use the same INIT routines. TI BASIC uses EA INIT version XB uses the XB version So you need to look at the back of the EA manual to convert the values in Assembly to the right address for it to work. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted July 25, 2013 Share Posted July 25, 2013 The XB loader also can't handle compressed object files, IIRC the Editor/Assembler one can. But all the linked subroutines (if it uses any) will be wrong. Porting a mixed application from BASIC to XB will require modifying the assembly in most cases, too. Quote Link to comment Share on other sites More sharing options...
RobertLM78 Posted July 25, 2013 Share Posted July 25, 2013 The XB loader also can't handle compressed object files, IIRC the Editor/Assembler one can. But all the linked subroutines (if it uses any) will be wrong. Porting a mixed application from BASIC to XB will require modifying the assembly in most cases, too. That's interesting to know - so no 'C' option for assembling something you want to run from XB? Quote Link to comment Share on other sites More sharing options...
RXB Posted July 25, 2013 Share Posted July 25, 2013 Not that I know of. When C99 was being distributed I talked to the Author of C99 and asked about XB vs EA and his reply was "Only EA". Quote Link to comment Share on other sites More sharing options...
Tursi Posted July 25, 2013 Share Posted July 25, 2013 Not that I know of.When C99 was being distributed I talked to the Author of C99 and asked about XB vs EA and his reply was "Only EA". He's talking about the C=Compressed Object File option of Editor/Assembler. Although, that statement was true. The original C99 startup code explicitly required the Editor/Assembler cartridge as it manually loaded the E/A subroutines. You could use your own startup code to get around that. Quote Link to comment Share on other sites More sharing options...
orion1052003 Posted July 25, 2013 Author Share Posted July 25, 2013 I used the RL options. Here is the source, Any specific thoughts on what to change? Where are the INIT routines i need to change the addresses of? The right ones are on the last page or back cover of the e/a? * BAR-GRAPH ROUTINE * FOR USE WITH MINI-MEMORY FROM TI BASIC * BY PHIL WEST AND BERNIE ELSNER * DEF BGRAPH VSBW EQU >2020 VMBW EQU >2024 NUMREF EQU >200C XMLLNK EQU >2018 ERR EQU >2034 * D1 DATA >0000 DATA >0000 DATA >0000 DATA >003C DATA >3C3C DATA >3C3C DATA >3C3C DATA >3C3C D2 DATA >1040 DATA >60A0 DATA >C0D0 DATA >F000 BGRAPH CLR R0 LI R1,>0001 BLWP @NUMREF BLWP @XMLLNK DATA >1200 MOV @>834A,R3 CI R3,>0000 JGT C B @E C CI R3,>001D JLT F B @E F INC R1 BLWP @NUMREF BLWP @XMLLNK DATA >1200 MOV @>834A,R4 CI R4,>0000 JGT G B @E G CI R4,>0008 JLT H B @E H INC R1 BLWP @NUMREF BLWP @XMLLNK DATA >1200 MOV @>834A,R5 CI R5,>0000 JGT J B *R11 J CI R5,>00A1 JLT K B @E K LI R2,>0008 LI R0,>0640 B LI R1,D1 A BLWP @VMBW A R2,R0 INC R1 CI R1,D1+8 JLT A CI R0,>0800 JLT B LI R0,>0319 LI R1,D2 LI R2,>0007 BLWP @VMBW SLA R4,3 AI R4,>00C0 SWPB R4 LI R6,>0020 LI R0,>0261 A R3,R0 N CLR R7 MOV R4,R1 M BLWP @VSBW DEC R5 P CI R5,>0000 JGT L B *R11 L AI R1,>0100 INC R7 CI R7,>0008 JLT M S R6,R0 JMP N E LI R0,>1300 BLWP @ERR END ."!. .... Quote Link to comment Share on other sites More sharing options...
orion1052003 Posted July 25, 2013 Author Share Posted July 25, 2013 . 99/4 ASSEMBLER VERSION 1.2 PAGE 0001 0001 * BAR-GRAPH ROUTINE 0002 * FOR USE WITH MINI-MEMORY FROM TI BASIC 0003 * BY PHIL WEST AND BERNIE ELSNER 0004 * 0005 DEF BGRAPH 0006 2020 VSBW EQU >2020 0007 2024 VMBW EQU >2024 0008 200C NUMREF EQU >200C 0009 2018 XMLLNK EQU >2018 0010 2034 ERR EQU >2034 0011 0012 * 0013 0000 0000 D1 DATA >0000 0014 0002 0000 DATA >0000 0015 0004 0000 DATA >0000 0016 0006 003C DATA >003C 0017 0008 3C3C DATA >3C3C 0018 000A 3C3C DATA >3C3C 0019 000C 3C3C DATA >3C3C 0020 000E 3C3C DATA >3C3C 0021 0010 1040 D2 DATA >1040 0022 0012 60A0 DATA >60A0 0023 0014 C0D0 DATA >C0D0 0024 0016 F000 DATA >F000 0025 0018 04C0 BGRAPH CLR R0 0026 001A 0201 LI R1,>0001 001C 0001 0027 001E 0420 BLWP @NUMREF 0020 200C 0028 0022 0420 BLWP @XMLLNK 0024 2018 0029 0026 1200 DATA >1200 0030 0028 C0E0 MOV @>834A,R3 002A 834A 0031 002C 0283 CI R3,>0000 002E 0000 0032 0030 1502 JGT C 0033 0032 0460 B @E 0034 00EA' 0034 0036 0283 C CI R3,>001D 0038 001D 0035 003A 1102 JLT F 0036 003C 0460 B @E 003E 00EA' 0037 0040 0581 F INC R1 0038 0042 0420 BLWP @NUMREF 0044 200C 0039 0046 0420 BLWP @XMLLNK 0048 2018 0040 004A 1200 DATA >1200 0041 004C C120 MOV @>834A,R4 004E 834A 0042 0050 0284 CI R4,>0000 0052 0000 0043 0054 1502 JGT G 0044 0056 0460 B @E 0058 00EA' 0045 005A 0284 G CI R4,>0008 005C 0008 . 99/4 ASSEMBLER VERSION 1.2 PAGE 0002 0046 005E 1102 JLT H 0047 0060 0460 B @E 0062 00EA' 0048 0064 0581 H INC R1 0049 0066 0420 BLWP @NUMREF 0068 200C 0050 006A 0420 BLWP @XMLLNK 006C 2018 0051 006E 1200 DATA >1200 0052 0070 C160 MOV @>834A,R5 0072 834A 0053 0074 0285 CI R5,>0000 0076 0000 0054 0078 1501 JGT J 0055 007A 045B B *R11 0056 007C 0285 J CI R5,>00A1 007E 00A1 0057 0080 1102 JLT K 0058 0082 0460 B @E 0084 00EA' 0059 0086 0202 K LI R2,>0008 0088 0008 0060 008A 0200 LI R0,>0640 008C 0640 0061 008E 0201 B LI R1,D1 0090 0000' 0062 0092 0420 A BLWP @VMBW 0094 2024 0063 0096 A002 A R2,R0 0064 0098 0581 INC R1 0065 009A 0281 CI R1,D1+8 009C 0008' 0066 009E 11F9 JLT A 0067 00A0 0280 CI R0,>0800 00A2 0800 0068 00A4 11F4 JLT B 0069 00A6 0200 LI R0,>0319 00A8 0319 0070 00AA 0201 LI R1,D2 00AC 0010' 0071 00AE 0202 LI R2,>0007 00B0 0007 0072 00B2 0420 BLWP @VMBW 00B4 2024 0073 00B6 0A34 SLA R4,3 0074 00B8 0224 AI R4,>00C0 00BA 00C0 0075 00BC 06C4 SWPB R4 0076 00BE 0206 LI R6,>0020 00C0 0020 0077 00C2 0200 LI R0,>0261 00C4 0261 0078 00C6 A003 A R3,R0 0079 00C8 04C7 N CLR R7 0080 00CA C044 MOV R4,R1 0081 00CC 0420 M BLWP @VSBW 00CE 2020 0082 00D0 0605 DEC R5 0083 00D2 0285 P CI R5,>0000 . 99/4 ASSEMBLER VERSION 1.2 PAGE 0003 00D4 0000 0084 00D6 1501 JGT L 0085 00D8 045B B *R11 0086 00DA 0221 L AI R1,>0100 00DC 0100 0087 00DE 0587 INC R7 0088 00E0 0287 CI R7,>0008 00E2 0008 0089 00E4 11F3 JLT M 0090 00E6 6006 S R6,R0 0091 00E8 10EF JMP N 0092 00EA 0200 E LI R0,>1300 00EC 1300 0093 00EE 0420 BLWP @ERR 00F0 2034 0094 END 0000 ERRORS ."!. .. 0091 00E8 10EF JMP N 0092 00EA 0200 E LI R0,>1300 00EC 1300 0093 00EE 0420 BLWP @ERR 00F0 2034 0094 END 0003 ERRORS ."!. . Quote Link to comment Share on other sites More sharing options...
orion1052003 Posted July 31, 2013 Author Share Posted July 31, 2013 Rich, what page in the E/A were you referring to? I'm just a novice less than a beginner in Assembly. What is a simplified explanation of what I must do to make the program work? Do I just need to change the CALL INIT statement? Where are the values in the program that should be changed to make it an XB INIT instead of a TI BASIC E/A INIT? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted July 31, 2013 Share Posted July 31, 2013 Rich, what page in the E/A were you referring to? I'm just a novice less than a beginner in Assembly. What is a simplified explanation of what I must do to make the program work? Do I just need to change the CALL INIT statement? Where are the values in the program that should be changed to make it an XB INIT instead of a TI BASIC E/A INIT? As Rich said, CALL INIT loads different utility routines in TI Basic than what it does in XB. The chapter you want in the E/A manual is §24.4, p. 410. Among other things, it gives you the EQUates you need for any ALC you want to write. Your EQUates at the beginning of BGRAPH are correct for XB referencing. Also, there is no difference between TIB and XB regarding the actual call to INIT—it takes no parameters. It is the same statement in your program in both languages. It happens to load different utilities in TIB than it does in XB and those utilities that perform the same functions, such as VMBW, are loaded at different addresses—hence, the need to consult §24.4. In an earlier post, you got an error in line 320 of your XB program. I'm not really sure what's going on, but my guess is that the error is during the loading of BSCSUP—that there may be an error in the file you're attempting to load. If it's trying to load in high memory, it may be stepping on your XB program and causing the error. I think that ALC for XB is limited to the lower 8KB of the memory expansion unit unless it's AORGed to high memory, in which case you need to exercise extreme care that you don't step on the XB program. ...lee Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted July 31, 2013 Share Posted July 31, 2013 @orion1052003... I know what the problem is with line 320—BSCSUP contains the TI Basic support utilities and they probably are stepping all over your XB program. You should remove that statement because those utilities are useless to XB and XB versions are already loaded by XB's "CALL INIT". ...lee 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted July 31, 2013 Share Posted July 31, 2013 Yep. Was just going to post to the same effect. If you're working with XB then you should not be loading BSCSUP. 1 Quote Link to comment Share on other sites More sharing options...
RobertLM78 Posted July 31, 2013 Share Posted July 31, 2013 I happen to be working through the Molesworth book now myself, so I'm glad this topic has been raised - very informative. Thank you all . Quote Link to comment Share on other sites More sharing options...
