KontraXIII Posted August 3, 2013 Share Posted August 3, 2013 Hi All, I was recently given a box boxes of Atari ST goodies and within it I found a working SM124 monitor. It has a metal switch on the back which looks like it has probably been put on by someone. The guy I got it from doesn't know what it does so I was hoping someone here may know? When I switch it the Atari reboots, one way it will work as a high res black and white monitor and the other it shows a blank screen. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted August 3, 2013 Share Posted August 3, 2013 Huh, that looks odd. I guess I'd (carefully! watch your voltages) take it apart and see what its hooked up to. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted August 4, 2013 Share Posted August 4, 2013 There was solution with switch where you could watch ST low or medium res. on SM124. Of course as B&W. Maybe it is it. You could see it by checking connector for Atari - if it is not original, and has RGB lines connected, then it should be it. Quote Link to comment Share on other sites More sharing options...
KontraXIII Posted August 6, 2013 Author Share Posted August 6, 2013 I opened it and found that the switch goes to GND between Video and Audio shown in the picture. Does anyone know what this would do when switched? Quote Link to comment Share on other sites More sharing options...
ctirad Posted August 30, 2013 Share Posted August 30, 2013 Look inside the DIN connector. I bet the GND wire is soldered to the pin 4 which tells the ST which kind of monitor is connected. Someone just wanted to switch between SM124 and TV without unplugging the cable. Quote Link to comment Share on other sites More sharing options...
