karokoenig Posted August 14, 2013 Share Posted August 14, 2013 http://home.comcast....2600-daptor.htm Thanks for that tip. I contacted him. It's probably gonna be a very expensive thing for me. Anyone an idea how to get something similar in Europe? Quote Link to comment Share on other sites More sharing options...
Tjoppen Posted August 14, 2013 Share Posted August 14, 2013 Please include this patch. I changes the background color on the playfield/GRPx widgets to COLUBK instead of black, which makes debugging easier. 0001-Use-COLUBK-instead-of-kBGColor-as-background-for-GRP.patch.txt Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 16, 2013 Share Posted August 16, 2013 OK, this patch is applied. It's a good idea, and I didn't consider it before. This will be in the 3.9.1 release. There are several other good ideas in this thread, and I may get to some of them for the 3.9.1 release ... Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 16, 2013 Share Posted August 16, 2013 Tell DASM to create a symbol file. The name has to be identical to the binary created, except for the extension which has to be ".sym" So if your file is test.bin use: -stest.sym Also, Stella 3.9.1 will (partially) support DASM list files, which you generate very similar to symbol files: So if your file is test.bin use: -stest.sym -ltest.lst This is very useful to differentiate symbolic constants from symbolic addresses. Eventually, the lst support may be further extended (theoretically, the lst file contains the entire disassembly, so Stella could use it to make the output very accurate, essentially source-level debugging). But that is some time away, if ever ... 1 Quote Link to comment Share on other sites More sharing options...
Tjoppen Posted August 19, 2013 Share Posted August 19, 2013 OK, this patch is applied. It's a good idea, and I didn't consider it before. This will be in the 3.9.1 release. Thanks Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 19, 2013 Share Posted August 19, 2013 Actually, I may have to modify the patch slightly, since it's still somewhat confusing when taking object precedence into account. But I understand your intent, and that the having black meaning 'nothing' (and not the colour black) is confusing. I think I'll just leave it blank in that case. Quote Link to comment Share on other sites More sharing options...
Tjoppen Posted August 19, 2013 Share Posted August 19, 2013 it's still somewhat confusing when taking object precedence into account It is? COLUBK is always furthest back.. Random idea and note to self for a potentially better debug display: show the whole line as the TIA would generate it if no registers were changed. Maybe some little arrows pointing to where all graphics objects are, and where the beam is. Quote Link to comment Share on other sites More sharing options...
enthusi Posted August 19, 2013 Share Posted August 19, 2013 Random idea and note to self for a potentially better debug display: show the whole line as the TIA would generate it if no registers were changed. Maybe some little arrows pointing to where all graphics objects are, and where the beam is. That'd be wicked indeed. Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 19, 2013 Share Posted August 19, 2013 If, for example, GRP0 contains 'nothing' (ie, a zero), then what will be 'drawn' for that register is the stuff under P0 (which will differ depending on the priority currently in use). So always filling it with COLUBK is also misleading, since P0, PF, or BK are possible values. I think it makes more sense in this case to simply make the pixel 'transparent' in the UI, since that's more like what's actually happening. I make it transparent by using the background dialog colour (ie, it simply blends into the background). There are a few cases where it makes sense to use COLUBK. One is in normal priority mode, when PF is empty. In that case, it indeed should show the value of COLUBK, since that's the only thing under it in priority. As for showing a full TIA line and/or arrows, etc., mockups of desired functionality are welcome. I have a little trouble picturing how this would look and/or work, but I'm open to suggestions. Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted August 20, 2013 Share Posted August 20, 2013 I found a problem due to the current change of the bank switching: I'm calling different banks through a subroutine that analyses the top three bits of the PC. So bank 0 is called at $1xxx, bank 1 at $3xxx, ..., bank 7 at $Fxxx. But the debugger assumes that the ROM as always used at $Fxxx, which makes it hard to set breakpoints. I usually forget to set the correct address by hand, right mouse button -> set breakpoint doesn't work. Maybe just masking out $1fff during the comparision would do the trick. Quote Link to comment Share on other sites More sharing options...
Tjoppen Posted August 20, 2013 Share Posted August 20, 2013 stephena: What about displaying the actual GRPx/PFx bits as well? Colored boxes + 0/1. And yeah, if I find the time I might mock something up for an even more awesome graphics debug display. Quote Link to comment Share on other sites More sharing options...
