Opry99er Posted August 14, 2016 Share Posted August 14, 2016 What about not "as-is"? Is the process the same as putting XB programs on FR99? (Save as merged, compile in EA to create E/A5 bin, use ti99dir to add v9t9 headers, use Module creator to make a non-inverted cartridge ready bin for fr99) Perhaps I was not clear enough. My bad. RXB is a language, just like regular XB. The Wilhelm compiler compiles BASIC and TIXB code, with certain caveats. The things about RXB that make it unique and different from vanilla XB are new subprograms and features that allow the user more freedom with the language. The CALL MOVES example is one of them. The Wilhelm compiler does not look for this subprogram. Therefore, using it would not have any benefit if the goal is to compile your code for a FR99 conversion. The advances of RXB over vanilla TIXB are numerous. Unfortunately, the current compiler simply doesn't understand what they are trying to do, because the creator of that compiler never programmed his compiler to accept these language changes. Perhaps one day Rich will make us an RXB compiler. Anyway, RXB has some awesome features, but they cannot currently be exploited if you intend to compile your code. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 14, 2016 Share Posted August 14, 2016 http://www.ebay.com/itm/SAMSUNG-19-034-LCD-TV-COMPUTER-MONITOR-SYNCMASTER-910MP-/322227776217?&_trksid=p2056016.l4276 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted August 14, 2016 Share Posted August 14, 2016 Ooooooohhhh...... Any Geneve users out there? 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted August 14, 2016 Share Posted August 14, 2016 Those monitors work nicely with V9938/V9958 video cards on a /4A as well. . .and the seller has a bunch of them! Quote Link to comment Share on other sites More sharing options...
Shift838 Posted August 14, 2016 Share Posted August 14, 2016 (edited) and these are fairly easy to make a RGB SCART cable to work with the Geneve. A few pots on the right pins and s small voltage throws it in RGB mode. If any Geneve users pick one up, the pots are key as I have seen each ohm setting be different to get a great picture. The pots allow you to adjust to what is required for your unit! And it's not a bad price even with shipping. Edited August 14, 2016 by Shift838 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted August 14, 2016 Share Posted August 14, 2016 oh, do you have the pin-out for a scart-cable ? Quote Link to comment Share on other sites More sharing options...
Opry99er Posted August 14, 2016 Share Posted August 14, 2016 Decent value here with 15 minutes left. I had my eye on it, but lack of funds... http://www.ebay.com/itm/232041489040 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted August 14, 2016 Share Posted August 14, 2016 It would definitely be a good idea to post the pin-out for the SCART cable with the potentiometers on it here, as this question comes up every time someone finds one of these monitors, @shift838. 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted August 15, 2016 Share Posted August 15, 2016 i'm getting ready to do my master dance on the treadmill so I will work on getting the wiring posted when I get back. I need to dig it out in my emails. I know I have it. I even did a small circuit board (hand wired pcb) with pots and connections for the DIN and SCART when I did mine a few years ago. (damn I should have kept the Geneve!) 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted August 15, 2016 Share Posted August 15, 2016 This is what was provided to me by Tony Knerr (Gazoo) a few years ago. I ended up putting mine in a project box with. I used a SCART cable that I purchased from AMAZON or ebay for fairly cheap. I clipped one of the ends off and stripped wires. I used a cotinuity tester to find what wires went to what pins. I know people that have done this exact same thing but without using a project box and just put the pots on the cable and after set they taped them down securely to the cable. I wanted mine to easily be adjustable. So I bought some 1k pots that were long shaft that had a flat head slot for adjustment so they would stick up enough through the project box. I should have taken pictures, but i did not. so the instructions provided to me that I went by are: You have to supply between 1 and 3 volts to pin 16 to activate the RGB interface. (I think it's in the manual; I useda 3v power supply) Connect audio to both right and left inputs. Sync goes to pin 20 Match up R, G, & B inputs Tie all grounds together at SCART plug Put 1k pots in series on the R, G, B, and sync lines. Just the wiper and one of the fixed connections, don't tie the other side to ground. You have to fiddle with the pots to get a nice clear picture. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted August 15, 2016 Share Posted August 15, 2016 Here's a PEB with a BIN price of $137--shipped. It has a Disk Controller, 32K, and Flex Cable. It looks a bit beat up, but it does power on. 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 15, 2016 Share Posted August 15, 2016 Here's a PEB with a BIN price of $137--shipped. It has a Disk Controller, 32K, and Flex Cable. It looks a bit beat up, but it does power on. Holy cow. If that is available for the next 24 hours I might be able to work something out and snag it. Oh the pressure. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted August 15, 2016 Author Share Posted August 15, 2016 I suppose i could do this if the routine is not very big. Need to see how to detect the F18 for this to work. And should be fine if it does not take much space. Excellent! Thanks Rich. You know, InsaneMultitasker did an incredible job with 80 column mode in his TIMXT communications program for calling the BBS's. He even has a routine for switching back to 40 column mode upon exiting the program. I imagine his code could be 'borrowed' and applied to this purpose. Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 15, 2016 Share Posted August 15, 2016 Here's a PEB with a BIN price of $137--shipped. It has a Disk Controller, 32K, and Flex Cable. It looks a bit beat up, but it does power on. I GRABBED IT! 6 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted August 15, 2016 Share Posted August 15, 2016 Awesome, dude. You've got the world by the huevos now, amigo! 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted August 15, 2016 Share Posted August 15, 2016 Next purchase you will need to make is an rs232 card. This will allow serial interfacing so you can transfer programs. You'll need an interface program on the TI. Do you have XB2.7? That will allow you to use cfhdxs1, which means you already have a transfer program on the TI. If not, you will need a copy of MFM or cfhdxs1 on diskette or something of the like for the TI. 2 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted August 15, 2016 Author Share Posted August 15, 2016 You'll need an interface program on the TI. Do you have XB2.7? That will allow you to use cfhdxs1, which means you already have a transfer program on the TI. I believe he has a FlashROM 99, but as of this moment CFHDXS1 is not in the FR99 repository. Maybe someone who has a copy will convert it and put it in there. It looks like the need is there now, and probably will be again in the future.. 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted August 15, 2016 Share Posted August 15, 2016 Wow, I hadn't even thought of that! Can MFM be put on the FR99 as well?? Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 15, 2016 Share Posted August 15, 2016 Whoa. One thing at a time. Let this thing arrive undamaged and turn on and stare back at me first. Well, I have to say, it was a hard sell but convinced my more reasonable half to say ok. So I'm not sure how soon I'll be purchasing anything more (at least not for a couple of months).I am getting a donated TI-99/4a in the box by end of October. I'll probably do the internal 32k on mine and use the peb on that when it comes. Otherwise; before October, I'll need a box of floppies ASAP though. Already working on it. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted August 15, 2016 Share Posted August 15, 2016 Cool... Floppies are easy to come by, but the 5.25s arent always reliable. I have had a few flake off onto my drive head... THAT was a disaster. Fun times await you 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted August 15, 2016 Author Share Posted August 15, 2016 Wow, I hadn't even thought of that! Can MFM be put on the FR99 as well?? If it's an E/A5 it should be convertible, but for some nagging reason I'm thinking it's in Extended BASIC, if so, no. I hope I'm wrong. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted August 15, 2016 Author Share Posted August 15, 2016 Whoa. One thing at a time. Awww, you gotta get with the program see attached short video for the TI users motto. I want it all NOW!.mp4 3 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 15, 2016 Share Posted August 15, 2016 Awww, you gotta get with the program see attached short video for the TI users motto. I stand corrected. shoogottimang! Quote Link to comment Share on other sites More sharing options...
Mitkraft Posted August 15, 2016 Share Posted August 15, 2016 If anybody is still looking for a PEB and Just posted a TI lot in the marketplace that has a Console, PEB, and Video modulator that I purchased from a former TI Employee here in Houston and include the boxes they came in from the company store. http://atariage.com/forums/topic/255942-ti-994a-console-peb-video-modulator-and-printer-from-former-ti-employee/ 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted August 15, 2016 Author Share Posted August 15, 2016 Well, I have to say, it was a hard sell but convinced my more reasonable half to say ok. So I'm not sure how soon I'll be purchasing anything more (at least not for a couple of months). Okay when you're ready, it'll be your lucky day. I got a hold of my friend who is also an Atari Age member that has hooked up more than a few people up here with TI stuff. I mentioned you just got a P-Box and were in need. Anyway Dan, who goes by CantStopClicking can hook you up with EVERYTHING you need to just plug and go. He'll be able to sell you the entire assembly, drive(s), frame, correct cabling and even the power connector. No fuss, no muss. If interested, just click the link and leave him a personal message. As others will attest, he does good work and is very reasonable when it comes to pricing. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
